Pete Kildow Posted May 21, 2021 Report Share Posted May 21, 2021 Buddy of mine that runs his own diesel shop. Even though he has a mag drill. He only uses a pilot hole then reamer. Tells me its faster and less work to set up. He's good at his job. So I'm taking his word at this. Also he had to drill holes a few times per week. But I'm going to borrow his mag drill. LOL Quote Link to comment Share on other sites More sharing options...
rickeieio Posted May 22, 2021 Author Report Share Posted May 22, 2021 Tried little brother's mag drill. It's a big old dawg. Wrestled it up in place, and couldn't get enough of the base on the frame for it to stick. Go to "plan B" So, drill 1/4" pilot holes, drill them out to 11/16", then ream to 3/4". Yes, I know 1/4" is too large, but it allowed the use of 1/4" bolts for alignment pins. I knew an old gentleman from Kentucky who said: "A poor man has poor man's ways." If you don't have the right tools, figure out another way. I have the rear two on each side done, but the front two need to be done from under the frame. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
jenandjon Posted May 23, 2021 Report Share Posted May 23, 2021 On 5/21/2021 at 2:43 PM, Pete Kildow said: Buddy of mine that runs his own diesel shop. Even though he has a mag drill. He only uses a pilot hole then reamer. Tells me its faster and less work to set up. He's good at his job. So I'm taking his word at this. Also he had to drill holes a few times per week. But I'm going to borrow his mag drill. LOL That reamer works very well. But dont use it in a Milwaukee drill. It will shut down on you as soon as you work it too hard. Use a old Dewalt. That baby will be smoking and still running. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
rickeieio Posted May 24, 2021 Author Report Share Posted May 24, 2021 This old Stanley drill is older than I. It doesn't grunt, it just wraps you up like a pretzel. It acts like it has a 30# flywheel. Feels like it too. Notice the 3/4" pipe for a handle. I made sure it went through the ladder rungs. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
alan0043 Posted May 24, 2021 Report Share Posted May 24, 2021 13 hours ago, rickeieio said: This old Stanley drill is older than I. It doesn't grunt, it just wraps you up like a pretzel. It acts like it has a 30# flywheel. Feels like it too. Notice the 3/4" pipe for a handle. I made sure it went through the ladder rungs. Hi Rick, Sounds like you need to be careful with that drill. You could go for a ride or worse yet, break your wrist. It will be nice to see the finished bed. Keep the pictures coming. Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
rickeieio Posted May 24, 2021 Author Report Share Posted May 24, 2021 Finished frame drilling today. I had to take the hitch and spacer plates out, re-assemble them so I could scribe the front hole on the plate, drill that with pilot, then bolt the spacer in the frame to drill out the final hole. I cheated. I step drilled 7/32, 1/2, and finally 13/16, all with a DeWalt 1/2" drill. None of my bigger drills would go in the space and leave room for my hands. Frequent stops to let it cool. and rest my digits. It doesn't like running really slow, but the bits appreciate it. I could have taken the wheels off and done it from the outside, but my back's been bothering me, so I chose the lesser of evils. On a bright note, it's funny watching the shop cat walk through the floor dry I have down to catch the oil from drilling, cuz it's mixed with drill shavings. She's not used to that. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 24, 2021 Report Share Posted May 24, 2021 20 minutes ago, rickeieio said: On a bright note, it's funny watching the shop cat walk through the floor dry I have down to catch the oil from drilling, cuz it's mixed with drill shavings. She's not used to that. Save that Floor Dry for winter, built-in studded paw traction. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rickeieio Posted May 28, 2021 Author Report Share Posted May 28, 2021 I spent the morning taking measurements and drawing out the bed on graph paper. Then I drew out the individual pieces and cut them out, so I can lay them out on a scale drawing of steel sheets, to see what sizes will be most efficient. I know, there are programs for that, but it would take longer for me to learn it than to draw/cut/ re-arrange. Call me a dinosaur...... Now it's time to make some decisions. Do I slope the rear of the bed, or keep it level all the way back? Susan says to slope it so "Round Boy" has easier access to the hitch. But, leaving it flat gives the option of bigger tool boxes. Which leads to the next question....Where to buy boxes. I'd like to just buy the doors and latches and build the boxes to size, but am having no luck so far. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Star Dreamer Posted May 28, 2021 Report Share Posted May 28, 2021 3 hours ago, rickeieio said: I spent the morning taking measurements and drawing out the bed on graph paper. Then I drew out the individual pieces and cut them out, so I can lay them out on a scale drawing of steel sheets, to see what sizes will be most efficient. I know, there are programs for that, but it would take longer for me to learn it than to draw/cut/ re-arrange. Call me a dinosaur...... Now it's time to make some decisions. Do I slope the rear of the bed, or keep it level all the way back? Susan says to slope it so "Round Boy" has easier access to the hitch. But, leaving it flat gives the option of bigger tool boxes. Which leads to the next question....Where to buy boxes. I'd like to just buy the doors and latches and build the boxes to size, but am having no luck so far. Slope is all about your wants. I sloped ours because I want an easier way to load a vehicle from the rear. The plus of it allows an easier climb up onto the bed. As far as storage boxes go, we made our own so I could get deeper than standard available boxes. We also made our doors, but bought the hinges and latches. Our boxes slide in through the doors and rest on angle support brackets that are tied to the structure of the bed. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
Av8r3400 Posted May 28, 2021 Report Share Posted May 28, 2021 (edited) Honestly, I drilled 8 holes in my frame for my fender brackets with my DeWalt 20v drill. Lots of step-ups in size to the final 1/2" diameter. The hardest one was the first 1/8" pilot hole. I used good cobalt drills and lots of cutting oil. It really wasn't a big deal. Edited May 28, 2021 by Av8r3400 Quote Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
geodog1 Posted May 28, 2021 Report Share Posted May 28, 2021 My boxes are all from RKI. ShortyO Quote Link to comment Share on other sites More sharing options...
rickeieio Posted May 28, 2021 Author Report Share Posted May 28, 2021 I got my steel ordered and paid for today. (ouch) 3"x5"x 1/8" tube for floor support and 3/16" plate for the deck, rear facia, and side rails/fenders.. This is NOT intended to support the car or other heavy loads. That will have it's own "unconventional" support and tie downs. My formed support structure for the car was ordered yesterday. All told, I'll have about $3,000 in steel, not counting boxes. I found a highly regarded tool box maker in northern Indiana, RC Industries. We'll see what their bid looks like. One issue is I want a 22" wide box with a 19 1/2" opening on one box so my ramps will slide in. That box will get modified so the ramps will go under the frame and rest in angle iron cradles. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rickeieio Posted June 1, 2021 Author Report Share Posted June 1, 2021 On 5/28/2021 at 12:20 AM, Star Dreamer said: We also made our doors, but bought the hinges and latches. Would you mind sharing where you got the hardware? I have two compartments that are odd shaped, and very limited on door area. I need to design around the size of the contents. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Star Dreamer Posted June 1, 2021 Report Share Posted June 1, 2021 10 hours ago, rickeieio said: Would you mind sharing where you got the hardware? I have two compartments that are odd shaped, and very limited on door area. I need to design around the size of the contents. I used door latches similar to these, but I bought them thru etrailer but it doesn't look like they carry them now, they have a paddle style. https://www.buyersproducts.com/catalog/truck-and-trailer-hardware-14/latches-445/t-handle-latches-610 For hinges, we used stainless steel piano hinges that we ordered from Discount Steel which is now Coremark Metals. They also did the laser cutting of our bed side panels which included the door faces with the mounting holes for the latches in them. I laid out the drawing and sent them the DXF file to make them. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
GlennWest Posted June 1, 2021 Report Share Posted June 1, 2021 On 5/28/2021 at 3:54 PM, geodog1 said: My boxes are all from RKI. ShortyO X2 Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rickeieio Posted June 3, 2021 Author Report Share Posted June 3, 2021 Steel was delivered yesterday. I have it stacked on a bunch of pallets by the truck for a makeshift cutting table. I went to a local truck upfitter to see about tool boxes, and they said for the non-standard sizes I want, an outfit called RCIndustries in Elkhart, IN is the best. Got bids. Heart stopper time. $2,800 for 4 boxes, none of them big. Plus, one needs a 20" door in a 24" box. They can't do that, need 2 1/2" on each side of door. And they won't discount for skippng the paint, nor will they ship anything missing one or more sides. But they say they do custom....... Sooo, the one box that's the issue doesn't need to be weather tight, as it's just for ramp storage. If i use the back skirt as a box wall, I can make compartment with a simple door and no seal. The other three boxes can be standard sizes for less than half the price quoted. I have more c-channel ordered, which should be ready late this week. But I'm leaving for a week of playing on motorbikes in the Smokies with some olde phartes. No more truck work until late June.... Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
NTHEWIND Posted June 4, 2021 Report Share Posted June 4, 2021 On 5/15/2021 at 7:20 AM, Av8r3400 said: Jack moved my hitch back to install the bed on our truck, I believe having it cantilever out of the frame a small amount. Going to pick her up this week... Quote Link to comment Share on other sites More sharing options...
NTHEWIND Posted June 4, 2021 Report Share Posted June 4, 2021 very nice build Quote Link to comment Share on other sites More sharing options...
essarebee Posted June 4, 2021 Report Share Posted June 4, 2021 Very nice! Quote Link to comment Share on other sites More sharing options...
essarebee Posted June 4, 2021 Report Share Posted June 4, 2021 But gotta say that I don't like the LED lights. It looks cool, but it says "look at me". I can't stand lights like this. But each to his own! Nice build. Thank you for posting pics! Quote Link to comment Share on other sites More sharing options...
rickeieio Posted June 4, 2021 Author Report Share Posted June 4, 2021 After getting prices on custom boxes, I'm going to buy boxes and cut the back out to get the depth I need, and to make a pass-through. It's about $1,400 cheaper this way. Work has stopped for now. A motorcycle trip is coming up soon. Priorities ya know. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rickeieio Posted July 9, 2021 Author Report Share Posted July 9, 2021 Well, motorcycle trips and a fab shop that put me on the back burner has held things up. But I got word today that the critical pieces I need to start the build will be ready tomorrow. Tool boxes and steel have been taking up space in the shop for over a month. Cutting, drilling, bolting and welding will commence Saturday. Pics will follow. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted July 9, 2021 Report Share Posted July 9, 2021 (edited) On 6/2/2021 at 7:10 PM, rickeieio said: ... the non-standard sizes I want, an outfit called RCIndustries in Elkhart, IN is the best. Got bids. Heart stopper time. $2,800 for 4 boxes, none of them big. Plus, one needs a 20" door in a 24" box. So my 6 custom boxes (2 storage, 2 ramp, one generator. One tool storage with rollout drawers) were $3300 installed. Not cheap, but it was a demanding build for him. Edited July 9, 2021 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted July 12, 2021 Author Report Share Posted July 12, 2021 Finally, the pieces I've been waiting for: Spent some time measuring and double checking figures: So, I spent some time today cutting and grinding these, to be welded tomorrow: This little feller got a workout: Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rickeieio Posted July 13, 2021 Author Report Share Posted July 13, 2021 Got in a little welding, and a lot of grinding. A welder, I'm not...... This sucker is heavy. Right at 90#. Lugged it to where it goes: Fortunately, my redneck a/c was working: Tomorrow I'll make the hdpe slipper buttons so things will slide nice and smooth. So David, do ya think it's "stout" enough? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
