Bed Build Planning
rickeieio
Coulda' punched them before you welded the pieces together. Could cut the welds, punch, then reweld. Get a good nights sleep, a healthy breakfast, then wrestle the works over to the press. Use hex bolts. I'm out of ideas here.
2007 32.5' Fleetwood Quantum
Please e-mail us here.
  • Replies 258
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
If only I'd known where the holes needed to be earlier.....  Such is one downside of not having the ability to use CAD.  I have a vision, and I adapt as I go along.
Wrestling the pieces to the press is not an option.  The press is against a wall, so I would have to bring the press out in the open, then use the fork lift to move the pieces.  But, the fork lift blew a seal in the mast cylinder yesterday.......
It's looking like using a reciprocating saw to rough out the corners, then a machinists screw jack to push a 5/16" square file through might work.
I don't have the bolts yet.  When I get them, I'll see what the actual shoulder measurement is.
KW T-680, POPEMOBILE
Newmar X-Aire, VATICAN
Ya, I was just yanking you chain. There's no easy answer here. An arbor press, hung off the overhead, might be able to generate enough pressure to push through.. A screw jack might, too.
Rick, order up a metric square broach in the size you need and set up a small press to push it thru the material. You can do it with an arbor press but it has to be a BIG one. Mine would make it but I'm not that close... You could also make up hydraulic one from bits and pieces around your shop.
2017 Kenworth T680
2015 DRV 38RSSA Elite Suites
2016 Smart Prime
Do the fasteners HAVE to be carriage bolts?     There are dome covers for hex bolts to make them "look like" rivets or carriage bolts.
https://www.mcmaster.com/bolt-covers/
Well, I was talking to Dan of "Dan and Freda" fame this morning when the light came on.......  I'm bolting one side of an angle and welding the other.  Just reverse the two, welding the angle to the wheel track and just resting the deck on top, making the bolts only holding the deck in place by holding the plate "down" rather than in a vertical plane, so never seeing any shear forces.  Well, almost never.  So now I can use my fancy little stainless button heads and everything will be fine.
Big thanks to all the suggestions, and especially to Dan, who nudged me off center so I could see the fix.
So here's what I have. The angle will now be welded to the outside of the wheel channel, and the deck will be bolted down to that.  Fender skirt and vertical plate at the frame rail will supply rigidity.  This deck section will be in three pieces, fender/center/fender, so I can take out just one section for any service needs.  Channels are also bolted to frame rails.  There's 11" of space between the front channel and the exhaust support.  Just perfect for storing a set of home brewed race ramps.
Susan always says I come up with a plan, but change it six times before I'm finished.  She ain't wrong.  But I guarantee it won't fall apart, and it will work.  Practical?  Probably not, but I have to try in order to be sure.
It's just no fun building it the way everyone else does......
Those changes are called engineering modifications. A friend of ours would call it alternate plan A, alternate plan B, etc
Brad and Jacolyn
Tucker the Wonder dog and Brynn the Norfolk Terrier
2009 Smart "Joy"
2004 VNL630 "Vonda the Volvo"
2008 Hitch Hiker 35 CK Champagne Edition
VED12 465 HP, Freedomline, 3.73 ratio, WB 218"
Fulltiming and loving it.
6 hours ago, noteven said:
Make sure you stay within your truck's GVWR GCWR GAWR WR & RR so you don't go into a force ten tank slapper, crash, and burn.
Signed
Internet warrior RV Weight Police.
just kidding
Well, I do tend to avoid the scales when I'm motoring about on my Moto Guzzi Griso.  The rear axle is overloaded under even moderate acceleration..........
So, today I had a visitor to the shop.  Spindrift, aka Tom Stedulis, stopped in and had lunch with me.  He's a sometimes visitor here, and even though he pulls his rv with a LGT, he does indeed own a real truck:
Tallied up the score sheet today.....  So far, we're at $12,590 and counting.  Just a wee bit over initial estimates.  But, in all fairness, that includes ET hitch at almost $4400 inc. shipping, $2,000 for tool boxes,about $4,000 in steel and bending, and lots of welding gas, grinding wheels, saw blades, bolts, air line, 7 wire cable,tie downs, lights, etc.
I don't expect any more significant cost besides paint.
My cost would be lower if it weren't for the cheap labor, causing more grinding wheels, then more welding, more grinding....
I had one mounting tab I cut off and moved twice, so far (my fault).  Had to grind out about three feet of seam weld because it didn't suit me.  Had a helper that day who said he could weld.  Everybody thinks they can weld, even me.
Edited by rickeieio
Rolled the plasma cutter thingy out of the corner, pulled off the cover, plugged in the cord and air line, and was just about to make a cut when I heard something..  a soft hiss like air leaking.  Ran my hand around the dryer and hoses, and suddenly it got louder.  Coming from inside the machine, of course.  Without further dialog, here's what I found and the solution:
There are still some original lines.  I bent them pretty severely and they didn't crack....yet.
DOT rated line, I assume? Just remember, a 5 minute job is 1 swear word away from becoming a 3 day ordeal.
Darryl,  The original and the replacement are NOT DOT rated.  The clear vinyl is all I had handy so I could get the job done.  I left the cover off just in case........
Marcel, I believe that will be just the ticket.  Just hope it all holds up to the vibration.
Milk crates are perfect for all those aerosol cans of brake-kleen, electrical contact cleaner, chain lube, Kroil, etc.  Fill any empty space with rags.  12" cast iron dutch oven just fits in one too.
So, how do you overload a 5er rated for 21k?
That vinyl tubing has been a life saver, more than once, in the oil patch. Respect it's ratings, and it'll serve faithfully in this usage.
17 hours ago, rpsinc said:
I found this that I am planning on fabbing a pair of doors for and then install as a DROM.  Sure appears that it will store plenty of tools and equipment.  I am hoping to be able to bring my fab tools and an inverter welder.Image 41 - Steelman 16 Drawer 7ft Work Bench Tool Box Storage Cabinet
Looks great , where did you find? I think I have enough room behind my box to mount one. Could you share info and measurements?
Thanks,
Rod
2007 Honda GL 1800
The Gold Volvo is still running and being emptied in July.
