Deezl Smoke Posted December 18, 2023 Report Share Posted December 18, 2023 16 hours ago, spindrift said: Even Fleetguard punts on that one. Just a quick reminder in general that I am in no way claiming to be a mechanic or engineer or.......I can only offer personal experience and/or opinions. There. I'm sorry that we have to give these blasted disclaimers all the time anymore, but tizwutiz. This is a link to a youtube video of a very well known and respected "certified" Caterpillar mechanic/technician, explaining engine oil and fuel filter pre-filling. It's about 8.6 minutes long. In it Josh discusses his rational behind prefills and no prefills. He even mentions conflicting procedures within the same repair or maintenance. He also mentions as has been mentioned here in this thread prefilling for rebuilds or long term setting etc. It's well worth the watch even if it conflicts with one's line of thought, just to gain further knowledge. Here's another video from the same author. It's almost 13 minutes long, but it goes in depth about the "bypass filter" systems that were also passively mentioned here in this thread. My chosen career path, farming, and my location, nw Oregon, has surrounded me with all sorts of engineers. From fresh out of skule to long retired. One constant complaint among the engineers is the continuous compromises that have to be made. This is in all aspects of engineering. From structures (civil) to power generation (mechanical and electrical) to computer (software and all that). Pretty much 99.9% of all things engineered is for some sort of sale. Even the USACE put together massive scale projects that are for sale. It is the constant compromises and conflicting designs etc., that drive me (only me, no-one else) to need factory (cya) info confirmed or denied by other sources. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
rickeieio Posted December 18, 2023 Author Report Share Posted December 18, 2023 8 hours ago, Ray,IN said: Cummins diesel engines built in the last 20 years have an oil pressure sensor circuit that will not allow an engine start until the ECM sees oil pressure in the system. Thanks for confirming that Ray. I've suspected it ever since buying the Volvo, with an ISX. It cranked longer than all my previous diesels before firing. So, this brings up another question....where is that sensor? If it's after the filter, the engine will protect itself from starting if a filter was not pre-filled. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
mike5511 Posted December 18, 2023 Report Share Posted December 18, 2023 7 hours ago, Deezl Smoke said: Just a quick reminder in general that I am in no way claiming to be a mechanic or engineer or.......I can only offer personal experience and/or opinions. There. I'm sorry that we have to give these blasted disclaimers all the time anymore, but tizwutiz. This is a link to a youtube video of a very well known and respected "certified" Caterpillar mechanic/technician, explaining engine oil and fuel filter pre-filling. It's about 8.6 minutes long. In it Josh discusses his rational behind prefills and no prefills. He even mentions conflicting procedures within the same repair or maintenance. He also mentions as has been mentioned here in this thread prefilling for rebuilds or long term setting etc. It's well worth the watch even if it conflicts with one's line of thought, just to gain further knowledge. Here's another video from the same author. It's almost 13 minutes long, but it goes in depth about the "bypass filter" systems that were also passively mentioned here in this thread. My chosen career path, farming, and my location, nw Oregon, has surrounded me with all sorts of engineers. From fresh out of skule to long retired. One constant complaint among the engineers is the continuous compromises that have to be made. This is in all aspects of engineering. From structures (civil) to power generation (mechanical and electrical) to computer (software and all that). Pretty much 99.9% of all things engineered is for some sort of sale. Even the USACE put together massive scale projects that are for sale. It is the constant compromises and conflicting designs etc., that drive me (only me, no-one else) to need factory (cya) info confirmed or denied by other sources. There are several good comments to these videos as well. I've been a subscriber to his channel for a while now. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted December 19, 2023 Report Share Posted December 19, 2023 11 hours ago, rickeieio said: Thanks for confirming that Ray. I've suspected it ever since buying the Volvo, with an ISX. It cranked longer than all my previous diesels before firing. So, this brings up another question....where is that sensor? If it's after the filter, the engine will protect itself from starting if a filter was not pre-filled. I suspect that function is assigned to the oil pressure sensor. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rickeieio Posted December 19, 2023 Author Report Share Posted December 19, 2023 I'd never heard of that guy, but like his delivery and common sense approach. Now to check my filter supply for that symbol he points out. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Deezl Smoke Posted December 21, 2023 Report Share Posted December 21, 2023 On 12/7/2023 at 7:40 AM, spindrift said: Hmmm...myth or hack? LOL...maybe I just can't stop thinking about power dividers. https://youtube.com/shorts/hT9j8cIDy9E?si=4aij172hL6fBQdSx I found that product I was looking for. It's called the Robson drive. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Ray,IN Posted December 21, 2023 Report Share Posted December 21, 2023 (edited) 6 hours ago, Deezl Smoke said: I found that product I was looking for. It's called the Robson drive. That is a great idea, It's available in Canads, not in the U.S.A. https://www.bmf.ee/products/accessories/robson-drive-system Edited December 21, 2023 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rickeieio Posted December 24, 2023 Author Report Share Posted December 24, 2023 A myth that needs to be busted is the nasty rumor that there is no Santa Claus. A couple of my grandkids have been trying to convince me that he's just a myth, SAY IT AIN'T SO!!!!!!! Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
spindrift Posted December 24, 2023 Report Share Posted December 24, 2023 40 minutes ago, rickeieio said: A myth that needs to be busted is the nasty rumor that there is no Santa Claus. A couple of my grandkids have been trying to convince me that he's just a myth, SAY IT AIN'T SO!!!!!!! I can bust that myth quite easily. A few days ago I was able to capture a picture of Santa Claus with our grandson. And that's that. Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 24, 2023 Report Share Posted December 24, 2023 (edited) 5 hours ago, rickeieio said: A myth that needs to be busted is the nasty rumor that there is no Santa Claus. A couple of my grandkids have been trying to convince me that he's just a myth, SAY IT AIN'T SO!!!!!!! Rick, No myth. He exists as surely as you and I. He’s that wide eyed stare you see in your 5 year old when he’s tossed in his bed all night to see if the offering of milk and cookies has been rewarded with a new bike. He’s as real as the late nights with a screw driver and crescent trying to assemble that play kitchen set. He’s the warm feeling you get when you take a wish from the Angel Tree and see a young child that has nothing get a warm coat and a teddy bear. No myth when you pick up the tab for a young couple struggling with three kids in a restaurant and realize it’s a rare occasion they can afford to go out or the same with an octogenarian couple who’s endured more than we can know. Finally, I know he exists when on this holiday I am lucky enough to have my beautiful wife, daughter, and grandchildren with me. It’s then I realize, I’m Santa Claus, we all are Santa Claus. Merry Christmas my friend!! Edited December 24, 2023 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted December 24, 2023 Author Report Share Posted December 24, 2023 2 hours ago, SuiteSuccess said: Rick, No myth. He exists as surely as you and I. He’s that wide eyed stare you see in your 5 year old when he’s tossed in his bed all night to see if the offering of milk and cookies has been rewarded with a new bike. He’s as real as the late nights with a screw driver and crescent trying to assemble that play kitchen set. He’s the warm feeling you get when you take a wish from the Angel Tree and see a young child that has nothing get a warm coat and a teddy bear. No myth when you pick up the tab for a young couple struggling with three kids in a restaurant and realize it’s a rare occasion they can afford to go out or the same with an octogenarian couple who’s endured more than we can know. Finally, I know he exists when on this holiday I am lucky enough to have my beautiful wife, daughter, and grandchildren with me. It’s then I realize, I’m Santa Claus, we all are Santa Claus. Merry Christmas my friend!! Dang Carl, yer a lot smarter than we thought. Thanks. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
sandsys Posted December 25, 2023 Report Share Posted December 25, 2023 The Deaconess at our church listened as her son was told by another kid that there is no Santa Claus and no Easter Bunny. He turned to her and said, "Did you lie to me about God, too?" That's the year I asked our daughter if she wanted to help me be Santa Claus for her dad. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
rickeieio Posted January 1 Author Report Share Posted January 1 Over the holidays, I've been tinkering on our truck. One thing scratched off the list is an engine oil change. Guess what? All the filters on our engine are cartridge style. Oil, fuel, and coolant. So, apparently, PACCAR doesn't support the notion of pre-filling a filter on their proprietary MX series engines (built by Cummins in MO.) Now we need a fresh myth to bash.😁 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
lappir Posted January 1 Report Share Posted January 1 30 minutes ago, rickeieio said: Over the holidays, I've been tinkering on our truck. One thing scratched off the list is an engine oil change. Guess what? All the filters on our engine are cartridge style. Oil, fuel, and coolant. So, apparently, PACCAR doesn't support the notion of pre-filling a filter on their proprietary MX series engines (built by Cummins in MO.) Now we need a fresh myth to bash.😁 If they are vertical what difference does it make if they are a spin on vs a cartridge? Does the seal only work on the bolt when it's tightened? I thought in the older cars I could fill them, but it's been a long time since the 70's. Inquiring minds.... Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
spindrift Posted January 1 Report Share Posted January 1 31 minutes ago, rickeieio said: Over the holidays, I've been tinkering on our truck. One thing scratched off the list is an engine oil change. Guess what? All the filters on our engine are cartridge style. Oil, fuel, and coolant. So, apparently, PACCAR doesn't support the notion of pre-filling a filter on their proprietary MX series engines (built by Cummins in MO.) Now we need a fresh myth to bash.😁 Yeaaah...what does Paccar know? 😂😉 Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
rickeieio Posted January 1 Author Report Share Posted January 1 1 hour ago, lappir said: If they are vertical what difference does it make if they are a spin on vs a cartridge? Rod, I believe the oil filter housing drains to the crankcase. With the cap off, air is allowed in so the oil just drains. At least that's how all I've done so far work. But, I'm ready to learn if someone knows different. Tom, PACCAR must know more than we. Rumor is that all new PACCAR trucks have the MX series. Cummins is no longer an option. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
jenandjon Posted January 1 Report Share Posted January 1 (edited) 17 hours ago, rickeieio said: Rod, I believe the oil filter housing drains to the crankcase. With the cap off, air is allowed in so the oil just drains. At least that's how all I've done so far work. But, I'm ready to learn if someone knows different. Tom, PACCAR must know more than we. Rumor is that all new PACCAR trucks have the MX series. Cummins is no longer an option. I have heard that rumor. I also heard the rumor that Frieghtliner is no longer having Cummins either. If you want a Cummins, you have to go with an International. Edited January 2 by jenandjon Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted January 1 Report Share Posted January 1 I think the Paccar engine was developed in Europe with DAF? European manufactures have used cartridge type filters for a long time. They are less costly and save material by not using a new shell with every change. The manufactures are more focused on packaging today in general so, the idea that cartridge filters are used fit that goal as well. Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Ray,IN Posted January 1 Report Share Posted January 1 55 minutes ago, rickeieio said: Rod, I believe the oil filter housing drains to the crankcase. With the cap off, air is allowed in so the oil just drains. At least that's how all I've done so far work. But, I'm ready to learn if someone knows different. Tom, PACCAR must know more than we. Rumor is that all new PACCAR trucks have the MX series. Cummins is no longer an option. Paccar must rely on the Cummins feature that will not allow an engine start until the ECM "sees" oil pressure. I know I do, I never pre-fill an oil filter. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
spindrift Posted January 1 Report Share Posted January 1 3 minutes ago, Ray,IN said: Paccar must rely on the Cummins feature that will not allow an engine start until the ECM "sees" oil pressure. I know I do, I never pre-fill an oil filter. Ray, Can you tell me exactly what feature this is, and where it's located. I was under the impression that the only Cummins engines with this feature are in the industrial line, not automotive. Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
rickeieio Posted January 1 Author Report Share Posted January 1 10 minutes ago, spindrift said: Can you tell me exactly what feature this is, and where it's located. Not having an intimate knowledge of the ecm, it would be logical that since it monitors oil pressure and initiates a shut-down for pressure loss, it might not allow a start until the pressure sending unit says all systems are "GO". No additional hardware needed. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Ray,IN Posted January 1 Report Share Posted January 1 1 hour ago, rickeieio said: Not having an intimate knowledge of the ecm, it would be logical that since it monitors oil pressure and initiates a shut-down for pressure loss, it might not allow a start until the pressure sending unit says all systems are "GO". No additional hardware needed. I cannot now find my reference link, but I'm sure I read that on the Cummins insite website. You're right, nothing extra required for this function. My personal experience is with my ISC 8.3. Always before the engine would start almost immediately when the key was turned. Back in 2020 We were enroute to Mayo Clinic and had engine problems that required my MH be towed to Cummins Rock Island. The ECM was so old their computers could not connect and read information, so they removed the ECM and took it to their computer room where they had an old computer that could connect After all that they wiped my ECM clean and installed the current programming. From then on my engine will not start for about 10 seconds or more after the key is turned, and the oil pressure gauge immediately jumps to 80 PSI. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 1 Report Share Posted January 1 3 hours ago, spindrift said: Ray, Can you tell me exactly what feature this is, and where it's located. I was under the impression that the only Cummins engines with this feature are in the industrial line, not automotive. Almost any engine series with an ECM strapped to it. ISB, ISC, M11, N14 all come to mind. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rickeieio Posted January 2 Author Report Share Posted January 2 4 hours ago, Steve from SoCal said: think the Paccar engine was developed in Europe with DAF? A bit of digging reveals that DAF is a wholly owned subsidiary of PACCAR. Also, in T-680 trucks, the MX-13 is the standard engine, and the MX-11 is an option. That's it. No Cummins, Detroit, etc. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Deezl Smoke Posted January 2 Report Share Posted January 2 17 hours ago, Ray,IN said: I cannot now find my reference link, but I'm sure I read that on the Cummins insite website. You're right, nothing extra required for this function. My personal experience is with my ISC 8.3. Always before the engine would start almost immediately when the key was turned. Back in 2020 We were enroute to Mayo Clinic and had engine problems that required my MH be towed to Cummins Rock Island. The ECM was so old their computers could not connect and read information, so they removed the ECM and took it to their computer room where they had an old computer that could connect After all that they wiped my ECM clean and installed the current programming. From then on my engine will not start for about 10 seconds or more after the key is turned, and the oil pressure gauge immediately jumps to 80 PSI. 10 seconds is way too long. So when you turn the key to the on position, do you let the system diagnostics run through it's routine before turning to the start position? For example, in the farm prostar/maxxfarce, and my Pete Cummins X15, I turn the key to the on position and listen for all of the clicking and air purges to stop before turning the start position. This can take up to about 4 seconds. Then, turn to start and either engine will fire within about 3-4 revolutions. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
