Lou Schneider Posted January 20 Report Share Posted January 20 (edited) Once I bought new tires for my Ford F-350 and the shop inflated them to the full sidewall pressure which was 50% above the pressure on the truck's placard. It was a 60 mile drive home (unloaded) and the truck felt very unstable, like it was sliding and fishtailing. I almost brought them back the next day but I caught the error and setting them to the correct pressures solved the problem. Edited January 20 by Lou Schneider Quote Link to comment Share on other sites More sharing options...
rickeieio Posted January 29 Author Report Share Posted January 29 Yep. Take the sidewall pressure and the door jamb sticker both as guidelines, but not an absolute. In the case of my f-150, I need to run 48 psi for the load per tire as shown on a scale and the tire manufacturers chart. Door sticker calls for 36 psi. That may work for an empty truck, but I have a bed mat, optional big fuel tank, cross box, and several hundred pounds of tools and "stuff". Next "myth".... never drag a file or hacksaw backwards across the work material? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Danfreda1 Posted January 29 Report Share Posted January 29 True but you don’t need to completely lift it off the material being filed or cut. Easy with a file to lift but on the backstroke just lift up on the pressure Quote Link to comment Share on other sites More sharing options...
Deezl Smoke Posted January 30 Report Share Posted January 30 (edited) Fireball tool made a video about 2 years ago using an old shaper to test the old file backwards myth. Normally I'd post a link, but I can't seem to get the video to play on youtube. It just opens then goes white screen. But if you search youtube for fireball tool file, it should come up. It was a very interesting video. I'll not spoil the results, you'll have to watch it.😉 Ok, it was my computer. I got it to play. So here's the link. Edited January 30 by Deezl Smoke Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
rickeieio Posted January 30 Author Report Share Posted January 30 Back in the day, we had a power hacksaw in the shop. Like a chop saw, but with a big reciprocating blade, oiler dripping on it. Those blades lasted forever, even though they were dragged back every cycle with the full weight of that support arm. Oil made the difference. Also, if you look up filing machines, there's a lot of different variations, some quite large. None reduce pressure on the return stroke. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Danfreda1 Posted January 30 Report Share Posted January 30 Not all Rick, we had some in different shops (hacksaw type saw) that lifted a very small amount. Maybe not enough to see but it you put a trained finger on it you could feel. Most of our saws were the horizontal bandsaws with at least a 1 inch blade Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted February 1 Report Share Posted February 1 (edited) On 1/30/2024 at 9:50 AM, rickeieio said: Back in the day, we had a power hacksaw in the shop. Like a chop saw, but with a big reciprocating blade, oiler dripping on it. Those blades lasted forever, even though they were dragged back every cycle with the full weight of that support arm. Oil made the difference. Also, if you look up filing machines, there's a lot of different variations, some quite large. None reduce pressure on the return stroke. Our jack-xxx saw in the shop had a cam that slightly lifted the blade for the return stroke. Our blades didn't last long sawing the brake-die steel to length. It arrived already heat-treated to RC20. But with mild steel you're right the blades lasted a long time. Edited February 1 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Ray,IN Posted February 1 Report Share Posted February 1 (edited) Myth or Truth, You can sharpen a file with vinegar? No fair using a search engine. Edited February 1 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rickeieio Posted February 1 Author Report Share Posted February 1 2 hours ago, Ray,IN said: Myth or Truth, You can sharpen a file with vinegar? No fair using a search engine. Sorta....I've tried it, and it helps. Not like new, but much better than they were. But, I'll say, I was trying to revive files that had been wet, and rusted. The vinegar took off most of the rust, so the file seemed better. There are better ways to remove rust. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Ray,IN Posted February 1 Report Share Posted February 1 18 hours ago, rickeieio said: Sorta....I've tried it, and it helps. Not like new, but much better than they were. But, I'll say, I was trying to revive files that had been wet, and rusted. The vinegar took off most of the rust, so the file seemed better. There are better ways to remove rust. The vinegar method is very old, long before Naval Jelly and like chemicals were invented. Left exposed to vinegar "fumes' long enough, it does actually erode the teeth enough on the tips to sharpen them. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
spindrift Posted February 1 Report Share Posted February 1 5 minutes ago, Ray,IN said: it does actually erode the teeth enough on the tips to sharpen them. LOL...I'm somewhat hesitant to ask how this was determined. Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted February 1 Report Share Posted February 1 Anyone else chalk your files before starting on aluminum, brass, bronze and other soft material? Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Ray,IN Posted February 1 Report Share Posted February 1 (edited) 27 minutes ago, spindrift said: LOL...I'm somewhat hesitant to ask how this was determined. So I was told, the teeth are eaten away by vinegar, since the teeth tips are the thinnest part, they are "sharpened". I have no empirical evidence to support that though. Georgiahybrid, I'd forgotten about that technique to reduce clogging with soft metal. Edited February 1 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rickeieio Posted February 1 Author Report Share Posted February 1 Naval Jelly is phosphoric acid in a jell form. Same acid as in Coke. You can buy it dry too. Works great to remove rust. Ever heard about dropping a nail in a can of Coke, and the next day it's dissolved? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Ray,IN Posted February 3 Report Share Posted February 3 The nail, no, but I have heard of placing a 1" cube of meat in a coke and a few days later there is a greasy film on top of the coke, but no meat left. The original Coke/Coca Cola contained cocaine, I've seen a gallon jug of coke from perhaps a century ago and the label listed the ingredients. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
noteven Posted February 17 Report Share Posted February 17 Myth: it’s horsepower not torque. It’s why heavy haul companies are replacing 2050lbs-ft torque Cummins’s’z with really Tuned up 6.7 Powerstrokes Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
rickeieio Posted February 17 Author Report Share Posted February 17 Right...... Our old ISX made 480 ponies at the ground. Our new-to-us PACCAR is rated 455 at the crank, but more torque at 1,100-1450 rpm. I like this kinda torque. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 21 Report Share Posted February 21 On 2/17/2024 at 12:23 PM, noteven said: Myth: it’s horsepower not torque. It’s why heavy haul companies are replacing 2050lbs-ft torque Cummins’s’z with really Tuned up 6.7 Powerstrokes "Myth: it’s horsepower not torque." Bar none one of my favorites.👍 Why do the hp and torque graph curves cross at roughly 5252 rpm? Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
rickeieio Posted February 21 Author Report Share Posted February 21 6 minutes ago, Deezl Smoke said: "Myth: it’s horsepower not torque." Bar none one of my favorites.👍 Why do the hp and torque graph curves cross at roughly 5252 rpm? Time to bust out the ol' slide rule. Torque x RPM = HP/5252 But where did 5252 come from? I haven't driven enough new stuff to be sure, but it seems the newer motors are making more torque, but keeping the rpm lower, thus the great pulling power with low hp figures. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 21 Report Share Posted February 21 1 hour ago, rickeieio said: Time to bust out the ol' slide rule. Torque x RPM = HP/5252 But where did 5252 come from? I haven't driven enough new stuff to be sure, but it seems the newer motors are making more torque, but keeping the rpm lower, thus the great pulling power with low hp figures. It's fun to know where the number came from. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
spindrift Posted February 21 Report Share Posted February 21 1980s GM diesels were converted gas engines... Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
rickeieio Posted February 22 Author Report Share Posted February 22 11 hours ago, spindrift said: 1980s GM diesels were converted gas engines... Don't you mean, swapped out to gas? I know several people who bout those, and dropped in gas motors later. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Av8r3400 Posted February 22 Report Share Posted February 22 12 hours ago, spindrift said: 1980s GM diesels were converted gas engines... The 5.7L GM diesel was based off the Oldsmobile gas engine block - Fact. They even marketed a smaller 4.3 (260") V8 and 4.3 (262") V6 version also off the gas engines. Quote Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 22 Report Share Posted February 22 10 hours ago, rickeieio said: Don't you mean, swapped out to gas? I know several people who bout those, and dropped in gas motors later. Been there, done that, got the tee shirt. The rig in my avitar was a 6.2L that I later swapped out for a 454cid. Easiest swap ever. 3 line fuel pump, ignition power to the coil, and homemade radiator hoses. Throttle cable, just a simple part swap. The torque converter on the 6.2 has different perimeters, but still works. The 6.2 has a vacuum pump to operate the trans and hvac, so simple to plumb that hose in the manifold on the 454. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Lance A Lott Posted February 22 Report Share Posted February 22 As to files, I was always told not to put them in a pile because they dulled each other. Quote Link to comment Share on other sites More sharing options...
