Replacement aftermarket turbos?
Broncitis
I have a 2000 Volvo VNL 610 with a 12.7L Detroit that we have registered as an RV and use to haul our Early Broncos to various shows and off road events around the country a few times a year.
Last fall I was on a trip and had the thermostats go out and could not get the engine up to temp and was freezing with no heat, so I had to make a pit stop in Pittsburgh to my cousins shop where we got those replaced. While we were removing the air intake duct to access the thermostat manifold, my cousin noticed the impeller blades were a bit chewed up on the leading edges and that the bearings had play allowing it to rub the housing.  So, I have decided to replace it before it fails.
My question is if anyone has any experiance with the cheap new aftermarket units such as this one from JM Turbo : https://attaturbo.com/TURBOCHARGER/Detroit/detroit-turbo-turbocharger
I have seen prices range from this $319 up to $1500 for various turbos all said to fit my application.  I realize it it likely made in China and may not be a good as an OEM unit, but I guess my thought is that I do not expect or need it to last 500K-1million miles.  We've put 75K on this rig since we got it 16 years ago.  So, with that said, are these good enough and the best value for my purpose so I can use the additional money for other needed repairs and upgrades?
TIA,
Drew
'66,'67,'76,'77 Ford Broncos
'00 F-350 CC PSD
'00 Volvo 610, Detroit Series 60 500 HP, Eaton Auto Shift, "Saddlebag" Cycle Hauler
40' Southwest Expressline trailer (2 Broncos)
53' Take 3 Wedge (4 Broncos)
http://broncitis-volvo.blogspot.com/
Nick Stamm, from Stryker , Ohio builds the "Frankenstamm "  turbos for just about everything that rolls
If you Call him, tell him I said Hi
This is Not an endorsement of any kind , simply a suggestion.
Nick's Diesel & Repair
Address: 22931 Co Rd E-50,
Stryker, OH 43557
Denver and Ms Judy Geitgey
2006 VOLVO 780
41 ' Redwood
NTPA Event Announcer
dngeitgey@gmail.com
I installed a new USA made Borg Warner turbo on my Cat that was actually for a 12.7 Detroit up to 500hp. $750ish delivered from Turbo Resouce in AZ. Tom is well known in the performance light truck diesel world.
I couldn't trust a cheap Chinese turbo on something that would cost so much to repair if it scattered. Figured this was in the middle cost wise and was quality.
Edit: Part number was 172743.
1999 Peterbilt 385 C12 430/1650 13spd
2006 Dodge 3500 DRW 4x4
2010 Hitchhiker Champagne 36 LKRSB
8 hours ago, Alie&Jim's Carrilite said:
I would be wary of a $3-500 dollar turbo... if it implodes it will cost you an engine.
Hence my desire to replace my apparently worn out one and for asking to see if any one here has used them.  I would think that there has to be some reports good or bad on these. If not here, then perhaps in some trucking forums.
Maybe it does not have as good of class of bearings and it will end up loose like the one I have now in 250K miles instead of 550K miles. I could actually live with that and be willing to make that trade for 1/4 the cost since this rig will never see that many more miles the way we use it.
'00 F-350 CC PSD
6 hours ago, lockmup68 said:
You are screwed, give it up!
LOL
No way, Rubicon, Moab (or St. George), and Buena Vista in July. You need to drag your Bronco out of retirement one of these days!
'00 F-350 CC PSD
5 hours ago, Broncitis said:
LOL
I'm trying to make it to the Roundup. Keeping fingers crossed I'll be in UT in July, Let me know when and where, I'll grab the in-laws JK and come down to see ya.
2007 Teton Scottsdale XT4
Broncitis      What tires do you run on your trailer? I have 17.5 tires on my 5er but I want to get a set that has a good name and not a mountain high price. We are in Va.  Thanks     Pat
The Old Sailor
I wet with a factory one from Detroit through Freightliner. Just because if it failed on the road I can go to any freightliner dealer for warranty.
The Old Sailor
I  run LT265/75R16.
I wish I had 17.5", but this trailer came with 16's when I got it 15 years ago.
I've blown a LOT of tires on this trailer over the years, as many as 8 or 10 in one cross country trip! I usually carry 4-8 spares.  Luckily with this  trailer, shredded tires do not damage it like it would an RV.
The trip to Moab and Baja last May had all the blowouts as a cascading effect  likely from a couple of older tires blowing and then beating the adjuoing ones to death which later threw treads due to brusing the carcasses or blowing out due to wires from the steel  belts penetrating them and running low and shredding.
My original Pressure Pro system had quit working on us and even afer returning it twice they were not able to get it to work. So I had a a newly installed different system on that trip which was total crap and never in 7K miles did pick up all the sensors in one cycle and when I did get low pressures you could not differentiate the very low volume missed sensor beep from a low / blown tire alarm. two times we had two simultations shredded tires by the time we discovered them. One time I probably traveled 100+ miles before knowing I had another.  When they shred I can not even feel it,  unlike a blowout where I hear it.
I ended up buying 6 new tires on that trip and made another 7K mile trip around the country last fall with no issues as all.
I have also got the latest Pressure Pro system, but still need to install it.
'00 F-350 CC PSD
Why on God’s green earth would you continue to run 16s on this trailer and not convert it to 18 ply commercial 17.5s?
Im about to do this with my trailer after only one blowout of my 16s.
Av8r3400
I've swapped out 16's for 17.5's twice.  Obviously, I believe in them, and the safety cushion they bring.  While it's a pretty big investment, it's better than spending equally large sums on a TPMS and still have the problem.  My philosophy, right or wrong, is to buy "overkill" tires and skip the monitor.
I totally agree.
Av8r3400
Or go buy an LT tire that fits your rim.  I ran Firestone Transforce tires on all my boat trailers and all my RV's until I bought the 17.5s.  Never had an issue with them.
Jim's Adventures
