griffinmike Posted July 20 Report Share Posted July 20 How many of you have frequent blowouts and how many axles does your 5er have? Quote Link to comment Share on other sites More sharing options...
lappir Posted July 21 Report Share Posted July 21 The second trip North from South Florida to Iowa I had 3 blow outs before leaving Florida. I had a triple axle toyhauler and thankfully two spare wheels and tires. The Tires were New Goodyears the year before. Thankfully Goodyear covered the replacement cost and repaired the damage caused to the trailer by the tires. The issue was the ambient temperatures in Florida I believe. It was much warmer than I had traveled before and I started in the early morning and not the usual later in the afternoon near evening. It's my thought anyway. My current trailer with the dual tandem air ride and semi trailer tires is sooooooo much better. Of course the tires are a lot more expensive too. Rod Quote Link to comment Share on other sites More sharing options...
TXiceman Posted July 21 Report Share Posted July 21 Rod, which GY tires did you have and what is the load you are carrying on each tire? I have GY G614 on three 7000# Mor/Ryde axles and so far, not one issue. These tires are 3 yeas old. Previous tires were Hankook F19 Maxivantage and ran then for almost 6 years and no issues. Ken Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted July 21 Report Share Posted July 21 Nearly all ST tire mfgrs. recommend running the air pressure listed on the sidewall. Some years ago the Carlisle ST tire warranty stated that, and ignoring running sidewall listed pressure voided the warranty. Quote Link to comment Share on other sites More sharing options...
franco-bolli Posted July 21 Report Share Posted July 21 I haven't had a tire blow out in over 15 years.. Pulled an 8k Actric Fox 24-5L for 6 years, no blow outs with Costco (greenball?) tires at the time. I've had a flat or two, but those were relatively slow leaks. More recently I changed out the Marathon tires on my TT which were aging out and installed GY Endurance tires for the latest 7400+ trip. No issues. They run at 80PSI and I did see some high pressures during the day accross Nebraska and Missouri up to 90 PSI and tire temps at 100 degrees according to the TPMS. In the mornings, they were back down to 80 psi. oddly, the truck spare tire with a TPMS sensor on it, read 100 degrees at times. BTW, I had an alignment done on the trailer, prior to the trip. I had seen treadwear on the inside of the drivers rear trailer tire. No issues with this trip I know the tires and suspension were working overtime, with all the crappy roads in eastern Nebraska, Missouri, Kentucky and Tennessee. They took some hard hits when pot holes appeared at the entry and exit of bridges. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted July 22 Report Share Posted July 22 Never had a blowout but have had 1 flat. It was one of the early Goodyear that had so many problems. My previous DRV. Had leaks recently due to failing tire stems. All on one side at same time. Strange just one side and all on that side. Needless to say I replaced all six. I do use Michelin XPS. They are getting some age on them and tiny cracks. Hold air great and dealer said crack not deep enough to replace. Teton close to 21k. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted July 22 Report Share Posted July 22 1 hour ago, GlennWest said: Never had a blowout but have had 1 flat. It was one of the early Goodyear that had so many problems. My previous DRV. Had leaks recently due to failing tire stems. All on one side at same time. Strange just one side and all on that side. Needless to say I replaced all six. I do use Michelin XPS. They are getting some age on them and tiny cracks. Hold air great and dealer said crack not deep enough to replace. Teton close to 21k. 21K, some salesmen would tell you that's 3/4T towable.🙄 Quote Link to comment Share on other sites More sharing options...
TXiceman Posted July 22 Report Share Posted July 22 A neighbor recently had a G rated tire put on his Redwood as it was recommended by another guest here and the large tire dealer. So far, he has come back to a trailer with 2 to 4 tires flat after a couple of weeks. The tire dealer put in what he called "heavy duty" rubber valve stems. The dealer has come out and checked the tires, replaced the valve stems with more rubber valve stems....yet it leaks down. The tires and rims were thoroughly leak checked and the only leak was the valve stem. This has been going on for two months and the trailer has not been on the road yet. I told him to tell the tire dealer he wanted metal valve stems. Ken Quote Link to comment Share on other sites More sharing options...
GlennWest Posted July 22 Report Share Posted July 22 I have rubber stems. Wanted metal but could not get them when this happened. Mine doesn't leak Quote Link to comment Share on other sites More sharing options...
franco-bolli Posted July 22 Report Share Posted July 22 If you have the TPMS system that is a stem screw ontype, metal stems are highly recommended. When I first installed them on the TT, I could see a spot on the wheel that showed contact with the TPMS sensor, probably due to the centrifical force on the sensor. When I replace the tires, I had the stems replaced as well. I also put the "extra" TPMS sensors on the truck wheels, primarily because they react faster than the OEM internal one's do. BUT, the OEM versions are part of the stem, so there is no replacing the rubber stem with a metal one, without screwing up the truck OEM TPMS. I posted a long time ago, that I experienced a leak in one wheel that ( after much searching) turned out to be a defect in the wheel, behind one of the spokes. Fortunatly the folks made the wheel, sent me a replacement. Quote Link to comment Share on other sites More sharing options...
Twotoes Posted July 23 Report Share Posted July 23 Before I bought my Class A I had a 5er toy hauler with 3 axels and 6 tires. Had 2 blow outs within the first 4 months. Had the remaining 4 tires inspected and was told that 2 were ready to blow and the other 2 were unsafe. All were China bombs. Replaced all 6 with Michelin XBS Ribs. Ran another 5 years with no problems. Quote Link to comment Share on other sites More sharing options...
Star Dreamer Posted July 25 Report Share Posted July 25 Our first 5th wheel that we had for about 10 years was a triple axle and we had 9 blowouts and went thru a total of 27 tires. Some lasted 5k miles and some lasted 30k miles. We put on over 100k miles on the trailer. We had it weighed by individual wheel weights and none were overloaded, close but not overloaded. We also had the axles aligned. They were only 15" wheel diameter and very hard to find good tires in that size and they didn't make wheels to work with the lug pattern for a 17.5" diameter. Our next trailer had 8 lug 16" wheels and we replaced them with 17.5" Sailuns as soon as we got it home from the dealership. We transferred those wheels and tires to our current triple axle trailer and they now have 60k miles on them without any blow outs. Some still look good but we are replacing them after this trip as we had a bad alignment done last year and it has worn some of the trailer tires pretty bad. New alignment just done found the issue. Quote Link to comment Share on other sites More sharing options...
bobsallyh Posted July 26 Report Share Posted July 26 We have a 2004 39' Alfa triple axel fiver bought new. At 18 months old had a tire come apart and I can't remember the brand. But after the RV forums and talking to other fiver owners Michelin XPS Ribs were highly recommended. Have used them ever since and had no problems including going to Alaska. The fiver is the only vehicle I use Michelins on as I'm not a fan of the brand. Quote Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted July 30 Report Share Posted July 30 We have a 2006 Carriage at about 16K. When I bought it used I upgraded to disc brakes, 8K wet hub axles, 17.5" steel wheels with semi-trailer tires and Roadmaster suspension. Full time since 2018. The tires will have five years on them this winter and I plan to replace them. The one flat was a valve stem core failure. Quote Link to comment Share on other sites More sharing options...
gjhunter01 Posted July 30 Report Share Posted July 30 (edited) If you tow alot of miles (10k a year), you are bound to have tire problems eventually. It is best to be prepared with the proper tools and to practice changing the tires when you do your annual bearing inspection/grease job. Changing a tire on a busy interstate is not the time to stumble through changing a tire and relying on a tow service can be nerve racking. My wife and I can change a tire in 20 minutes and be back on the road, BTDT over 6 times in our 10 years of FT. I have found that once tires exceed 5 years of age, the blowout risk increases, but there is always that unexpected nail or pot hole to be prepared for. Edited July 30 by gjhunter01 Quote Link to comment Share on other sites More sharing options...
rickeieio Posted July 30 Report Share Posted July 30 Every tire failure we've experienced has been a Goodyear. Two different trailers over the past 13 years. On both trailers, we upgraded to 17.5" wheels. I now have Sailun tires on the 5er, and so far am happy with them. I ran them on my work truck, and had them on our Volvo RV truck as well. Quote Link to comment Share on other sites More sharing options...
gjhunter01 Posted July 31 Report Share Posted July 31 (edited) Tires are considered expendable components and eventually they need to be replaced, just like brake pads do. We have had good results with our 16" Sailun G tires, but they need to be regularly inspected and they too will meet their life span limit by design, either through wear or time. Edited July 31 by gjhunter01 Quote Link to comment Share on other sites More sharing options...
Randyretired Posted July 31 Report Share Posted July 31 15 hours ago, rickeieio said: Every tire failure we've experienced has been a Goodyear. Two different trailers over the past 13 years. On both trailers, we upgraded to 17.5" wheels. I now have Sailun tires on the 5er, and so far am happy with them. I ran them on my work truck, and had them on our Volvo RV truck as well. I have also had problems with Goodyear tires. We had 2 year old 5er that had been weighed and was less than the maximum for the tires. On 1 trip all 4 tires separated from the tread. I kept the tires at maximum cold pressure. These separations caused considerable damage to the 5er. Discount Tire told me when we visited them about the problem Goodyear had a silent recall on those tires. I am not sure what that is. In any case Goodyear paid for the damage and prorated the tires. That was nice but changing tires along a busy highway isn't my idea of fun. We also had to scour small town tire stores for tires to continue home as each tire blew. I no longer buy Goodyear tires. We have used XPS Ribs for the last 20 years with only one flat. We replace these every 10 years and keep the 5er in the garage when not being used. Based on the recommendations of others I have decided to try Sailun tires. Quote Link to comment Share on other sites More sharing options...
chief916 Posted August 2 Report Share Posted August 2 On 7/30/2022 at 7:21 AM, rickeieio said: Every tire failure we've experienced has been a Goodyear. Two different trailers over the past 13 years. On both trailers, we upgraded to 17.5" wheels. I now have Sailun tires on the 5er, and so far am happy with them. I ran them on my work truck, and had them on our Volvo RV truck as well. I do the same as you. Excellent choice. Back and forth coast to coast twice and Sturgis/Yellowstone and back. Thats one TUFF tire. Quote Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted August 5 Report Share Posted August 5 On 8/2/2022 at 5:45 PM, chief916 said: I do the same as you. Excellent choice. Back and forth coast to coast twice and Sturgis/Yellowstone and back. Thats one TUFF tire. Do you happen to know the expected life in years (not miles)? Mine are 2016 and I am thinking about replacing although lots of tread left. Quote Link to comment Share on other sites More sharing options...
2gypsies Posted August 5 Report Share Posted August 5 27 minutes ago, Jinx & Wayne said: Do you happen to know the expected life in years (not miles)? Mine are 2016 and I am thinking about replacing although lots of tread left. It's time to replace. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted August 6 Report Share Posted August 6 (edited) 8 hours ago, Jinx & Wayne said: Do you happen to know the expected life in years (not miles)? Mine are 2016 and I am thinking about replacing although lots of tread left. Carlisle ST tire mfgr. recommends replacement every 5 years due mainly to lack of regular use. The damage caused by a tire failure often far exceeds the cost of new tires. This is what Goodyear has to say: https://www.goodyearrvtires.com/tire-replacement-guidelines.aspx Edited August 6 by Ray,IN Quote Link to comment Share on other sites More sharing options...
chief916 Posted August 8 Report Share Posted August 8 On 8/5/2022 at 12:32 PM, 2gypsies said: It's time to replace. I don't know how long they will last but I check them for cracks and check the manufacturer date. I will tell you that I treat all my tires with Aerospace 101 spray. Plus I cover my tires when not on the rode. Quote Link to comment Share on other sites More sharing options...
chief916 Posted August 8 Report Share Posted August 8 4 hours ago, chief916 said: I don't know how long they will last but I check them for cracks and check the manufacturer date. I will tell you that I treat all my tires with Aerospace 101 spray. Plus I cover my tires when not on the rode. Sorry...... it's supposed to Aerospace 303. I fat fingered it. Quote Link to comment Share on other sites More sharing options...
