Scampers Posted September 11, 2020 Report Share Posted September 11, 2020 (edited) Hi all, New to our class A motorhome. Having attending the Escapade a few years back in Tucson and re-reading the RVers Ultimate Survival Guide tires are one of the most critical links for travel saftery. It does seem far too many big rigs I have seen on the road are really traveling faster that tires are rated and as speeds increase above 70 MPH the load rating decreases. Scary. In any case I need to buy a compressor so I can keep the tires correctly topped up. Our small 12 VDC compressor used for our 19' travel trailer will not do the job. What do folks use as a compressor? I am also going to install a TST temp and pressure monitoring system. Bat Dude Edited September 11, 2020 by Scampers Auto correct was wrong Quote Link to comment Share on other sites More sharing options...
Ranger Smith Posted September 11, 2020 Report Share Posted September 11, 2020 Most rigs . . . If it is a diesel pusher have a tap in the front where you can hook up an air hose to fill the tires. Quote Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 11, 2020 Report Share Posted September 11, 2020 I used a Power Tank, a bottle of compressed CO2 with a special regulator. Easily fills tires to 150 psi. It is silent so you can check and fill tires without disturbing your neighbors. Takes less space than an AC electric compressor. But it is pricey. Quote Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Kirk W Posted September 11, 2020 Report Share Posted September 11, 2020 1 hour ago, Scampers said: New to our class A motorhome. ............................... In any case I need to buy a compressor so I can keep the tires correctly topped up. It is good to hear that you found one that suits your needs. We have a long history with gas powered class A RVs, so enjoy yours and don't be intimidated by others. 😊 The best choice of air compressor depends on several things, but key in my mind is whether or not you have a generator as the ability to power it with 120V-AC at any time or location, very much improves the choices. I started out using one of the 12V inflators and later changed to a 120V powered one with an air tank because they can be used for so many other purposes. Of course, part of this issue is the weight and space that what you choose requires. If you select one with a tank it is important to verify that not only the maximum air pressure is above what your tires require, but also that the pressure that the compressor turns on is above that requirement. The first one I had turned off at 100# but my tires required 90# and the start pressure was at 85# which caused a real headache for me. I later replaced it with one that started at 120# and shut off at 140# which was much more satisfactory. For 12V you do not want to get one of the cheap ones as those will overheat if run long enough to fill the larger tires of a class A when they need much pressure. Also, the higher priced ones will not take as long as do the smaller, lower priced ones. I find that there are dozens of brands available on Amazon under inflaters, but I prefer a known name like the Brigs & Stratton, or something similar. Makita portable cordless model that is impressive and will provide up to 120#. Campbell Hausfeld makes a 120V version that is about the same as I used and my son now uses it, some 20 years after I purchased it. What we eventually setteled on was a 120V compressor from Campbell Hausfeld with a 3 gallon tank. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ranger Smith Posted September 11, 2020 Report Share Posted September 11, 2020 4 minutes ago, Kirk W said: It is good to hear that you found one that suits your needs. We have a long history with gas powered class A RVs, so enjoy yours and don't be intimidated by others. 😊 Who is intimidating him??? Quote Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
Pat & Pete Posted September 11, 2020 Report Share Posted September 11, 2020 I've used a Porter Cable pancake compressor for the last 10 years . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
TexasPSDX Posted September 11, 2020 Report Share Posted September 11, 2020 1 hour ago, Pat & Pete said: I've used a Porter Cable pancake compressor for the last 10 years . Same compressor I carry. Does the job. Quote Ron 2020 Ram Longhorn 6.7 4D SB 1989 Avion 34V Link to comment Share on other sites More sharing options...
bobsallyh Posted September 11, 2020 Report Share Posted September 11, 2020 Funny, but I just posted on Kirk's post from Quartzite last January. The friend that was with me bought a Viar 400 series. Came with several attachments, all in a bag. He is happy with it as he tried it on a mutual friend's 22.5 motorhome tires. Said it worked well. https://www.viaircorp.com/portables Quote Link to comment Share on other sites More sharing options...
bockofma Posted September 11, 2020 Report Share Posted September 11, 2020 Times 2 on the Viair. I've been using one for many years, and it does a good job...including the 110 PSI required on my fifth wheel tires. Quote 2007 Volvo VNL 670 2007 NuWa HitchHiker Champagne Link to comment Share on other sites More sharing options...
Second Chance Posted September 11, 2020 Report Share Posted September 11, 2020 We have a Vaiar and really like it. If you get one, be sure and add an in-line water filter/trap if you don't use a tank. Rob Quote 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
palmeris Posted September 11, 2020 Report Share Posted September 11, 2020 (edited) DCC2560T160V MAX* FLEXVOLT® 2.5 GALLON CORDLESS AIR COMPRESSOR KIT 135 psi- portable. i also have a lot of dewalt battery operated tools, drills, impact drivers, sawzall, https://www.dewalt.com/products/storage-and-gear/air-compressors/60v-max-flexvolt-25-gallon-cordless-air-compressor-kit/dcc2560t1 Edited September 11, 2020 by palmeris sdded link Quote Link to comment Share on other sites More sharing options...
Scampers Posted September 11, 2020 Author Report Share Posted September 11, 2020 Tnx all! Seems no way to change my "log in" name as were initially were in a 16' Scamp fiberglass trailer. Now have a 19' Escape fiberglass and now a new Holiday rambler Invicta (gasser). Big wheels 235/80 R 22.5 Michelins like diesel pusher are 110 PSI. So all of the suggestions have been great. Given Ford restricts out 4 down TOAD (Fore Explorer) to 65 MPH that is well within the range of the MH tires which max out at 75 MPH The Escapees people are simply AWESOME with the depth and breadth of knowledge. I may go initially with a thankless model with 120 VAC then see how it goes. Next I need to add the TST system for 6 wheels. Cheers all, Quote Link to comment Share on other sites More sharing options...
fly2low Posted September 12, 2020 Report Share Posted September 12, 2020 I have my TST set up to monitor the 6 coach tires + the 4 toad tires Quote Rich and Carol 2007 Dynamax DQ 340 XL Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted September 14, 2020 Report Share Posted September 14, 2020 Another vote for the Vair. I have the 400 RV which goes to 150 psi. See link below Vair 400 RV Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Mr&Mrs Duet Posted September 17, 2020 Report Share Posted September 17, 2020 I use a Bostich CAP1512. 12 amps, small. fairly quiet. Pressure tops out at 150psi, cut in is above 110psi so it keeps putting air in when I need 95 psi for the rear duals. Usually 20-30 seconds per tire of run time tops up a tire. Quote Keith & JodiFleetwood Expedition 34H Link to comment Share on other sites More sharing options...
podwerkz Posted September 18, 2020 Report Share Posted September 18, 2020 On 9/11/2020 at 8:37 AM, Pat & Pete said: I've used a Porter Cable pancake compressor for the last 10 years . Cool....I've got some old pancakes sitting around I need to inflate. 😎 Quote Nothing to see here. Link to comment Share on other sites More sharing options...
Scampers Posted September 18, 2020 Author Report Share Posted September 18, 2020 Awesome, Just received my Porter Cable from Amazon! Quote Link to comment Share on other sites More sharing options...
whj469 Posted September 20, 2020 Report Share Posted September 20, 2020 I use a tankless compressor, Viair (sp) for my fiver, 110 lbs per tire. Quote Link to comment Share on other sites More sharing options...
Scampers Posted September 20, 2020 Author Report Share Posted September 20, 2020 (edited) My new Porter Cable is tank-less and 120 VAC. New rig is off for what I hope a quick warranty repair-fix. The microwave only runs off of shore power and not also the generator as needed. Also the windscreen is apparently leaking at the top and we had 2+ cups of standing water on the inside in the "trough" of the windscreen. Edited September 20, 2020 by Scampers Quote Link to comment Share on other sites More sharing options...
Philipclopez Posted April 22, 2021 Report Share Posted April 22, 2021 (edited) I'm using VIAIR 400P. The compressor has a sufficient max working pressure of 150 PSI. With this PSI rating, it is enough to pump air to most RV tires. Additionally, the unit only requires 12 volts to supply air to tires. Edited May 3, 2021 by Philipclopez Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 22, 2021 Report Share Posted April 22, 2021 (edited) I actually have 2 different compressors, but generally carry a Harbor Freight 150 psi 12V compressor to top off MH tires. I've carried and used this little compressor since 2008. It gets hot during use just like the expensive Viar units. I could not see the expense of Viar products, so bought this one.I suspect the main difference is duty cycle. The negative is the lack of a moisture trap in the compressed air line and the screw-on air chuck is inconvenient to use with high-pressure truck tires.. I also have a FINI brand pancake type 150 psi compressor that works very well and I can use a moisture trap; but it is noisy compared to the Harbor Freight compressor. Edited April 22, 2021 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
