CB Radios and Antennas
maveric
 Share
How many still use and listen to the CB radio?
What CB and style of antenna do you use?
My truck came with a Cobra 29 and the dual mirror mount 4' firesticks. I never use it, so pulled them off. But a couple months ago, we took the truck on a 3500 mile trip to the Washington coast, and part of the route was on interstate highways. It got me thinking that I should put it back in service.
One thing I have noticed, (or I think I have) is that the mirror mounted antenna's seem to make the wind noise more noticeable. In my mind, this is because they add leverage to the tops of the mirrors, which in turn, causes the top of the door to pull away from the weatherstrip. I did notice it was quieter when they were removed.
That being said, I installed a VHF 2 way radio in the truck, and used a roof mounted antenna with a wire whip. I mounted it to the cab, above the door, where the sleeper and the cab connect. it is out of the way, but doesn't make any noise.  I am considering using something similar for the CB, but wanted to see others thoughts on the matter. Or if it is even worth the effort for something that isn't used anymore.
Thanks for bringing this topic up. Invariably we end up needing the CB to find out what the traffic mess is ahead of us. As it stands our new radio only works close up to another truck. No we did not tune the antennas yet to it.
We also monitor it in case there is a malfunction we miss due to our own error (dragging a dolly chain!) or system malfunction we cannot see (leveler valve mount broke and we were wearing the tread off a tire at night in the rain) In both cases the CB helped a lot.
My question is if we bother to go buy a SWR meter we may as well optimize the radio, we have a high power export model that is doing no good without the antennas set up. If you were going to make optimum CB radio service a priority, what would be the best choice of antennas etc on a VNL? Mounting points, wire etc?
Thanks all.
same, leave on all the time, hardly ever any traffic on it. If you have cobra classic 29 for example, built in SWR meter for tuning, no need for external tuner.
To help with the wind noise, you can put springs on the mounts (in between mirror mount and the antenna (be sure to retune after) and that allows the antennas to bend more in the wind and the lay back a bit and it cuts down on the noise. In my old corn binder, antenna noise is the least of the noise worries. :)
I run a Cobra 29 with weather radio and replaced the factory whips with Francis 300 5.5 ft Hot Rods. I do monitor the radio to find out about traffic ahead and other road issues. Most of the time it is silent but there are areas where I turn it off when the idiots get on the air. Sometimes though the conversations are quite comical to listen to and do provide a bit of entertainment. We have also used them to communicate with others while in a caravan
Edited by GeorgiaHybrid
Y'all do realize that your responses to the original question are about as helpful as you make out CB radios and their users in general.
In other words the signal to noise ratio is dropping with every comment.
CB's a tool, most of the time an annoying one until traffic stops dead on the freeway and traffic remains so as far as the eye can see. Then it would be really helpful to hear what mile marker it is at and which lane you need to be in.
In order to do that as well as possible it would be helpful to have some recommendations from those who have optimized their antennas and installations as to what has worked or not worked for them, in our case in a VNL.
We have Volvo antenna splitters etc possibly degrading the signal, but needed for a FM radio signal or have you bypassed the splitter and installed a separate radio antenna? If so, what and where?
I watched a YouTube on replacing the wiring and antennas in the mirrors, looks doable and the video is helpful but still looks like a PITA.
1
If and when I have time to install a decent stereo system, I'll go with independent antennas.  For FM radio you can install a booster behind the ashtray/cup holder (Gen 1 Volvo).  Sirius or XM radio antennas can be run to the passenger A-pillar, up the pillar and back across to the center of the windshield at the top.  This leaves the original coax the factory ran for the CB antennae in the mirrors.
We have the all in 1 Cobra handheld.  It works several feet....
Feeding the new antenna cable thru the door, into the mirror arms and up is fun..... It can make for an exciting and colorful Saturday afternoon.
Edited by Alie&Jim's Carrilite
"Colorful"... my thoughts exactly but probably worth ripping off the duct tape and getting it over with.
It appears that most don't run them anymore. I used to run a cb in all my vehicles when I was in and just out of high school, cuz it was the cool thing to do in a small town. I still have them in my crawlers, but mostly because some of the events we attend require them. We use handheld race radios for most of our comms. For most trips that we run with friends, we use these instead of cell phones or cb.
Guess I am just seeing if it is worth getting the cb working correctly. Almost seems to be a wasted effort.
  • Phil D changed the title to CB Radios and Antennas
 Share
