SuiteSuccess Posted November 21, 2016 Report Share Posted November 21, 2016 Anyone have a source for this 1/4" push to connect elbow with 1/4" attached nipple? No luck at dealer or online. Link to comment Share on other sites More sharing options...
HERO Maker Posted November 21, 2016 Report Share Posted November 21, 2016 Carl, is that from your air bag? Or can you remember where it came from? Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 21, 2016 Author Report Share Posted November 21, 2016 From my leveling valve. I just took it off yesterday so didn't forget ? Link to comment Share on other sites More sharing options...
Steve from SoCal Posted November 21, 2016 Report Share Posted November 21, 2016 Looks like it may be a Legris fitting? https://www.legris.com/Legris_ecom/RechercherReferencesTypeArticle.do?codeActivite=BP&codeGroupe=02&codeFamille=01&codeSousFamille=03&codeTypeArticle=3182&codeFiliale=usa&codeLangue=en_US Steve Link to comment Share on other sites More sharing options...
rpsinc Posted November 21, 2016 Report Share Posted November 21, 2016 What about mcmastercarr.com?? Link to comment Share on other sites More sharing options...
NoDirectionHome Posted November 21, 2016 Report Share Posted November 21, 2016 https://www.grainger.com/product/PARKER-Plug-In-Elbow-16W616?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/16W616_AS01?$smthumb$ Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 21, 2016 Author Report Share Posted November 21, 2016 Wow, you guys are great. Thanks so much. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 21, 2016 Report Share Posted November 21, 2016 Carl, be careful if you drive to California after handling that fitting. They have determined that it contains cancer causing chemicals. Good thing that you are not 30 years younger, it can also cause "cause birth defects or other reproductive harm". I don't think you have to worry about that though, you have probably already forgotten about that Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 21, 2016 Author Report Share Posted November 21, 2016 Carl, be careful if you drive to California after handling that fitting. They have determined that it contains cancer causing chemicals. Good thing that you are not 30 years younger, it can also cause "cause birth defects or other reproductive harm". I don't think you have to worry about that though, you have probably already forgotten about that OMG, do I have a target on my back! Randy, then Rocky, now you? You're right I've forgotten more about "that" than you youngsters will ever learn. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted November 21, 2016 Report Share Posted November 21, 2016 McMaster Carr is a great resource. Always worth checking there. On your first order request a catalog sent..... Link to comment Share on other sites More sharing options...
Scrap Posted November 21, 2016 Report Share Posted November 21, 2016 It got dubbed a "stem 90" in the truck parts world. KV2L07-99 for the good one. http://www.ebay.com/itm/Lot-of-5-SMC-1-4-x-1-4-Plug-In-90-Degree-ELBOW-Fitting-Connector-KV2L07-99-/401166410547?hash=item5d6761a333:g:udkAAOSwWC1XpjeP Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 22, 2016 Author Report Share Posted November 22, 2016 Thanks for the replies Jim and Scrap. Link to comment Share on other sites More sharing options...
MrSeas Posted November 22, 2016 Report Share Posted November 22, 2016 What does the "tube" end of the fitting attach too? ( a PTC type fitting perhaps)? Just wondering out loud.... haven't come across one of these on my truck yet. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 22, 2016 Author Report Share Posted November 22, 2016 What does the "tube" end of the fitting attach too? ( a PTC type fitting perhaps)? Just wondering out loud.... haven't come across one of these on my truck yet. Fits down into an existing 1/4" push connect if you need a 90* angle. I found the Barksdale valve that Scrap recommended on eBay for $30 so ordered one to have a spare. Actually is almost identical to the original Hendrickson I had on my steer bag. These connectors will be used on that valve, but may have other uses. Link to comment Share on other sites More sharing options...
lockmup68 Posted November 24, 2016 Report Share Posted November 24, 2016 on this topic, in compiling my list of things to have, spare air/line fittings and line, is one of them. However, I have not found a breakdown of what that should include. Does this sound right? 90 degree fittings straight fittings air line (1/4"?) t-fittings push lock fittings? Any special tools needed? thanks, Shannon Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 24, 2016 Report Share Posted November 24, 2016 Lifesaver kit should contain a couple feet of each 1/4", 3/8", and 1'2" air line, along with a couple of couplings at a minimum. This will allow repairs to any lines that rub or snag. Additional fittings can be nice to have, but these fittings will cover most emergencies, and get you rolling to a shop. Link to comment Share on other sites More sharing options...
alan0043 Posted November 24, 2016 Report Share Posted November 24, 2016 Thanks for the replies Jim and Scrap. Hi Carl, P/M sent. Link to comment Share on other sites More sharing options...
MrSeas Posted November 24, 2016 Report Share Posted November 24, 2016 A good supply of replacement o-rings and brass collet will repair most of your PTC fittings without the expense of replacing the complete fitting. These are the Volvo part #'s Next time you visit the dealer you can pick some up. 1/4 O-ring Old part # 85108484 New part # 85146177 1/4 brass collet part # 85108476 3/8 O-ring Old part # 85108485 New part # 85146178 3/8 brass collet part # 85108474 1/2 O-ring Old part # 85108486 New part # 85146179 1/2 brass collet part # 85108475 5/8 O-ring Part # 85108487 5/8 brass collet part # 85108481 Wet tank O-ring part # 85108488 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 24, 2016 Author Report Share Posted November 24, 2016 Wet tank O-ring part # 85108488 I just replaced my wet tank o rings with just a 3/8" o ring 85146178. Seems to have fixed the leak. Part number is different, something I'm missing? Link to comment Share on other sites More sharing options...
MrSeas Posted November 24, 2016 Report Share Posted November 24, 2016 Wet tank O-ring part # 85108488 I just replaced my wet tank o rings with just a 3/8" o ring 85146178. Seems to have fixed the leak. Part number is different, something I'm missing? The ones I quoted for the wet tank are actually a bit larger than the 5/8 listed. They are o-rings on the external of the fitting to seal the fitting to the tank. Wow my lines in and out of all of my air tanks are 1/2 and 5/8. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 24, 2016 Author Report Share Posted November 24, 2016 Ok I have a 3/8" line which comes into the front of my tank with a push to connect as well as the larger rear feeds. I was referring to the 3/8. Sorry for the confusion. Link to comment Share on other sites More sharing options...
Dollytrolley Posted November 25, 2016 Report Share Posted November 25, 2016 OMG, do I have a target on my back! Randy, then Rocky, now you? You're right I've forgotten more about "that" than you youngsters will ever learn. Shucks......I am soooo old that I have forgotten what I have forgotten.....and I did not know much at best.... Drive on ......(where were we....?) Link to comment Share on other sites More sharing options...
