Av8r3400's 730 Build
Av8r3400
I thought I'd start a thread on the build of my newly acquired Volvo VNL64T730 tractor.
I will add to the thread as I accomplish things on the truck that are notable to the forum.
Thanks.
Av8r3400
  • Replies 85
5-09-2017
My first hurdle is of great importance.  The vehicle was titled today - AS A MOTORHOME!
I went to the 2-day per week local little DMV office this morning at 7 am just as they opened for the day.  The clerk didn't even bat an eye.
He said, "Okay we're registering a motor home today, great!"
He later said the VIN came back as a semi tractor and I replied to him that "Yes it did start life as a semi tractor."
He replied, "Oh, it has a truck front end on it?"
I said, "Yes."  And left things at that.
10 minutes later I was out the door with plates and a new title in hand!
Av8r3400
5-10-2017
Ordered wire and junction boxes in preparation for trailer and brake control wiring.
I took the truck over to the shop who is going to single and install the ET for me this afternoon.  The DW seemed very concerned about it when she picked me up.  "Are they going to leave it outside?  Is it locked?  Do they know what they are doing?"  (there are 6-8 trucks parked there right now getting major chassis modifications done)  I think she is worried about "her" truck.
I think it needs a name, better than "it".
We are now truckless again.
I miss it, too...
Av8r3400
Locking Differential.
Thinking a little bit today in my truck-less condition, my new (to me) truck does not have a differential lock on either of the rears.  This is my only regret so far with this truck.  It was one of the few detracting points to her.
Has anyone ever seen or know anything about retrofitting a locking differential (Detroit Locker or other limited slip?) into one of these large, commercial Meritor differentials?  (The door tag calls it a 2.470MT40-14X*C)
Would the entire carrier need to be replaced with an air locking unit?  Can the air-locking mechanism be fitted into my current carrier?
What about the gear ratio (2.47) that I have.  Will that gearset fit onto a different, air-locking, differential carrier?  Or would I need to replace the gearset as well?
Scrap?  Little help?
However, These are pretty much academic questions at this point because the money tree will be just about empty after the Single-ing, ET hitch, Direct-Link and wiring are complete.  I'll run an open, one wheel wonder for now, but in the future I do want to add a traction aiding mechanism of some sort to the rear end.
Av8r3400
Thank you for the quick reply.  Is what you describe even an economically viable option for the non-commercial user?  Sounds like it would be a monumentally expensive project.
I downloaded the Meritor service manual and they do reference a "no-spin" which appears to be a Detroit locker type device.  Have you ever seen one of these used?
Av8r3400
We run off road hauling grain out of soft fields.  Rarely, is getting stuck an issue. None of our work trucks have any anti slip devices. That's one reason to leave our camper truck tandem.
Some where on this forum is a person that had his Volvo done for about $2500 plus programing in Sioux Falls,SD
2017 New Horizons SOLD
What rick said ^
Local fella here in our rolly hill gravel road and mud&snow  country runs a late 90's KW T800 tandem tractor hauling oilfield fluids at 102,000lbs GCW with Reyco spring rear suspension, standard interaxle lock, 18spd, left leg clutch, rattlepillar, and... no diff locks! OMG!
Yea our wheat trucks don't lock either.  But they aren't a big ol fat heavy sleeper Volvo with 2.64's either.  That's a tough first truck to learn on in the dirt!
I'm sure a guy can change out spider gears and get a fork, etc but I've never done it.  I'd bet the itty bitty pinion is going to need some 'while you're in there' work as well when you open it up too.  Then the whole reman decision comes back up again.  Leave it closed and procrastinate is my MO on it......
Vaander Hags in Sioux Falls sold me a freshly rebuilt air locker and installed it for $2,800 out the door (my axle housing did not require trimming).  This price included the longer splined right side axle.
2004 Volvo 630, Cummins ISX, Eaton 10 speed (air assist clutch), 3.71 3.07 rear locker, ET jr, 200" WB, GearMaster
2017 Forest River Sierra 372LOK
Full time June 2017
DW, 2 kids, and 2 dogs
I think I will exercise Scrap's procrastinate option.  I will wait to see if it is really needed...
Next, I'm assembling the parts I need to do the wiring on my truck when it's done at the chassis shop.  I have boxes (like Allen0043 used), 4 conductor wire for the run Direct Link to Jackalopee and 7-conductor wire for the run Jackalopee to the hitch plug.
One of the things I need to get ordered is the Direct Link brake control.  The question I want to pose to the HDT experts here is:
For my 2012 Volvo VNL, do I need to get the 6-pin or 9-pin converter for the interface to the truck?
Since my truck is over an hour away at the chassis shop I can't look directly at it...
Av8r3400
Thank you MrSeas.  I just sent them an email to confirm compatibility.
Av8r3400
It should work with a 2012. But asking them is never a bad thing.
Are you singling by choice, or a requirement of insurance?
If you are going off road much, there is a definite advantage to keeping the truck tandem.
John
Southern Nevada
2008 Volvo 780, D13, I-Shift
2017 Can-Am Maverick X3-RS
I chose to single for several reasons.
  1. Shorter wheelbase for better maneuverability
  2. Overall shorter footprint of the vehicle
  3. Fewer tires, brakes and all of the other systems of the power divider axle to maintain
  4. Better fuel economy
  5. Better ride quality
  6. A look that is less "Commercial".
In my state (Wisconsin) the registration of a motorhome has no limit on the number of axles.  This is also the same with my insurance carrier (Auto Owners).
I do not have plans for any "Off Roading" with the truck and trailer.  At least no further off road than my 1/2 mile gravel driveway or at worst an unpaved campground at Airventure (Oshkosh) every year.  This camp ground is a farm hay field.  It is smooth and well maintained.  It is navigated by many large class A and "super" class C motorhomes during the air show.
My spot (with my EAA Chapter) is not far off the beaten path.  We usually get there Friday before the show and don't leave until Sunday at the end of the show.  It was very entertaining (and educational) a couple of years ago watching million dollar rigs get stuck and be drug around by a tractor...
Av8r3400
I got an update on the single-ing process today...
She's all striped down, I guess that's the easy part.
Av8r3400
