Interesting Occurrence
SuiteSuccess
Was pulling out of a campsite that was uphill and little bit side hill. Base was gravel and sand and wheels started to spin and then got traction. Truck shook a bit. Got immediate low coolant alert, engine derated, then shut down in less than 15 seconds. I had pre-flighted before leaving and knew had no leaks and plenty of coolant. Rechecked and all good.  Tried restart and started without issue.  My supposition is coolant sloshed around enough it triggered low coolant sensor to cause shutdown.  BTW I replaced the sensor several years ago so think it’s ok. Thoughts?
Edited by SuiteSuccess
2017 DRV 39DBRS3
BTW drove 120 miles after without a glitch.
2017 DRV 39DBRS3
1 hour ago, Darryl&Rita said:
You know the condition of your truck better than I, but that sounds plausible.
Interesting pulled the code on diagnostics and it showed inactive. Just a gremlin hopefully.  Hopefully helpful info for others.
2017 DRV 39DBRS3
Yes the low coolant sensor is happy to do that on the Modern Diesel Truck.
Running it a bit over full (it will self adjust out the overflow) will allow you to show off by patching out leaving a campsite without embarrassing codes and derates 🤣
Mine was doing that and at the most embarrassing times. I started running the coolant level a little higher and the problem stopped. So I'm assuming that the coolant sensor did not like the level I was using.
If it really is a bad sensor AND you are sure the coolant level is good you can pull the wire off the sensor and you are on your way.
Edited by Brad & Jacolyn
Brad and Jacolyn
2009 Smart "Joy"
2004 VNL630 "Vonda the Volvo"
Fulltiming and loving it.
I wonder how many people have coolant sensor problems compared to real low coolant issues. Just because the over flow tank is low doesn't mean the radiator is.  Especially with motorhomes  but trucks also it seems like there are lots of issues with coolant sensor.
2017 New Horizons SOLD
Kenworth taught us the tank with the sensor is a safer way to check (see through) and add coolant if necessary vs opening the radiator cap itself. On a hot engine especially you aren't crawling up off the ground to stick your face above a rad cap.  You check level by looking and replenish standing on the ground.
Also radiators don't have the big top tank any more due to the underhood "cooling package" space being used for larger cores packaged in a lower nose.
Edited by noteven
Agreed.  Often the reservoir tank is a distance away from the radiator and much lower than where the top tank would be.  I had a John Deere which had the tank about 2' behind and a foot below.  You could check it just walking around the machine while doing the pre-flight.
That said, many machines don't have a sensor.  None of my Deeres did, nor have any of our cars and pick-ups.
I looked at my overflow jug over the radiator while fixing the fan issue.
Connector was rotted in half, not connected. No indication on the dash at all.
2003 Jeep Wrangler Rubicon
Jackalopee
  • 4 months later...
Updating this thread.  Pulled truck out of storage to drive and get some fuel. As I was leaving fuel stop about 1/4 mile away got low coolant alarm, derate and 15 secs later, shutdown.  I had “pre-flighted” truck so knew coolant level was okay.  Made it to shoulder, waited couple of minutes and truck restarted without issue and made it back to storage.  This time was on flat, level road and no sloshing.  What’s up?  Well, hit Google and found out in my D12 the overflow tank sensor is a resistance sensor that responds to a float ring that is magnetic.  My tank has not been changed in the 12 years I’ve owned the truck (the coolant has but is overdue).  Apparently some grunge can get on the float and it will stick setting off the alarm.  My plan when warmer is to change out tank, sensor, coolant, and wiring to hopefully solve the issue.
2017 DRV 39DBRS3
  • SuiteSuccess changed the title to Interesting Occurrence
3 minutes ago, rickeieio said:
Nice update, and also nice solution, assuming that fixes it.
Hope so.
2017 DRV 39DBRS3
Interesting,  I've been driving around disconnected and doing visual checks on mine as the derate 30 seconds after pulling out is not fun.  Replaced the sensor but no better,  tried to top off the tank but it levels back down.  Adding new tank to the maintenance cycle!
2017 Jayco Designer 37rs "Fiona"
2007 Volvo 670 "Henry"
I agree with what Rick wrote.
It's been several years since my first trip to Colorado and the "Pony Pack" mounted to the truck rails developed a leak and caused an issue with my coolant level. A couple of years later I found one of the tanks had a small leak also, luckily I was near a dealership and replace it.
I had my coolant checked 2 years ago and the mechanic said I had a few more years with my type of operation. I'll have him check again the next trip there.
Rod
2007 Honda GL 1800
I had same issue on my Volvo 670, darn thing shut down a number of times when I first owned it.  Tag on the top of the reservoir says "Fill to Brim".  Hard corners were setting off the low level alarm and shut the truck down.
  • Volvo 670 / 2006
  • 10-Speed
  • ATV's & Sleds
  • 2017 Host Mammoth Slide-In Camper on Deck
  • Jackalopee
  • Build article published here
