Herb Posted July 26, 2019 Report Share Posted July 26, 2019 I have my rv permanent in a campground every time I come my holding tank smell so bad I have tried everything to fix this but the next week it is the same way any idea on how to correct this Quote Link to comment Share on other sites More sharing options...
FL-JOE Posted July 26, 2019 Report Share Posted July 26, 2019 By saying you have it "permanent" I will assume that it never moves. The first thing I would check is the most obvious for an RV that sits in one spot for long periods of time. Your black tank is vented up through the roof. There will be a cap on a PVC type pipe that is up there. Some of the caps just pull off and then some are fastened. Remove the cap and make sure the pipe is clear. Maybe wasps or some other creatures have nested in there thus blocking the vent pipe. I will also assume you always keep your black tank closed until it is time to empty it and rinse it out? Quote Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
Herb Posted July 26, 2019 Author Report Share Posted July 26, 2019 Replaced the vents with cyclone rotating I have tried everything Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted July 26, 2019 Report Share Posted July 26, 2019 It more than likely is a stuck open vacuum breaker on your grey water tank system. If you haven't replaced them, look for them under the kitchen sink and bathroom sinks. You would be surprised at how bad a grey tank can smell. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Kirk W Posted July 27, 2019 Report Share Posted July 27, 2019 7 hours ago, GeorgiaHybrid said: It more than likely is a stuck open vacuum breaker on your grey water tank system. I very much agree with this suspicion. You will have one of them under each of your sinks and they are very easy to replace and inexpensive. Another question is, do you leave the dump valves open while you are gone? If you do that you may well get sewer gas pushed back into the RV from the park sewer system. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
$ Spot Posted July 27, 2019 Report Share Posted July 27, 2019 12 hours ago, Herb said: I have my rv permanent in a campground every time I come my holding tank smell so bad I have tried everything to fix this but the next week it is the same way any idea on how to correct this 8 hours ago, Herb said: Replaced the vents with cyclone rotating I have tried everything 8 hours ago, GeorgiaHybrid said: It more than likely is a stuck open vacuum breaker on your grey water tank system. If you haven't replaced them, look for them under the kitchen sink and bathroom sinks. You would be surprised at how bad a grey tank can smell. could this work? https://www.menards.com/main/search.html?sf_categoryHierarchy=&search=air+admitance+valve Spot Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted July 27, 2019 Report Share Posted July 27, 2019 $Spot, I'm not sure but I think the black pipe is a slightly different diameter than the white stuff. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted July 27, 2019 Report Share Posted July 27, 2019 If you mean this one, it will work but may need an adapter for size. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Chad Heiser Posted July 27, 2019 Report Share Posted July 27, 2019 We had a similar issue with smell in our trailer. I started hunting for the source and realized there was a P-Trap in the washing machine drain line. It is a standard open pipe P-Trap. We don’t use the washing machine very often, so water doesn’t go down that pipe very often. What I found was happening was the water in the P-Trap was evaporating and allowing the smell to come up through the pipe. Now I manually poor a little bit of water down that drain pipe every now and again to keep the P-Trap full and have not had any issues with smell since then. This is a long way of saying, make sure your P-Traps aren’t drying out when your rig is not in use. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
jc2 Posted July 27, 2019 Report Share Posted July 27, 2019 (edited) This is what u need. Any big box store will have. We keep 1-2 on hand. Hand tighten firmly and may have to wrap a rag aound it to loosen with channel lock plyers. https://www.homedepot.com/p/Oatey-1-1-2-in-ABS-PTC-In-Line-Cheater-Vent-39012/100204205 Edited July 27, 2019 by jc2 Quote 2010 Newmar Dutch Aire 4304-Spartan Chassis-Cummins ISL 425hp-2013 Chevrolet Equinox AWD Towed-SKP# 120487-FMCA #402879- Link to comment Share on other sites More sharing options...
Barbaraok Posted July 27, 2019 Report Share Posted July 27, 2019 Also, when leaving for an extended period of time, try 1/2 filling some small ziplock bags with water and place over drains. At half-filled, they will conform to the drain. Ours have lasted 6 months with no leakage. I also put one in the bottom of the toilet as it is so dry in Mesa, AZ that the water will eventually evaporate out of the toilet. Quote Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Herb Posted July 27, 2019 Author Report Share Posted July 27, 2019 The smell is when you flush the toilet it is coming from the tank I have done everything I could do to make it go away I have bought every chemical there is and nothing works Quote Link to comment Share on other sites More sharing options...
filthy-beast Posted July 27, 2019 Report Share Posted July 27, 2019 (edited) 12 minutes ago, Herb said: The smell is when you flush the toilet it is coming from the tank I have done everything I could do to make it go away I have bought every chemical there is and nothing works Try using more water. We had that problem as well. Now we let a generous amount of water run after each flush. I also run a good amount water right after dumping the tank. Edit: If campground water has a smell of it's own that will also be part of the problem. Also don't run bathroom vent fan while flushing. wait until after you close the value to turn on the fan. Edited July 27, 2019 by filthy-beast Quote 2020 Platinum F350 6.7L CC DRW, 2021 Riverstone Legacy 37mre 5th wheel Link to comment Share on other sites More sharing options...
Zulu Posted July 27, 2019 Report Share Posted July 27, 2019 When all else fails . . . Bleach Quote SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
bobsallyh Posted July 27, 2019 Report Share Posted July 27, 2019 Since it is when you flush, could it be coming inside from the roof if roof vents (14"x 14") are open? WE usually have our vents open and sometimes when flushing, if we have a fantastic fan running, it will bring in odors from the tank vent. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted July 27, 2019 Report Share Posted July 27, 2019 3 hours ago, Herb said: The smell is when you flush the toilet it is coming from the tank I have done everything I could do to make it go away I have bought every chemical there is and nothing works I am wondering if this might be your problem? 2 hours ago, bobsallyh said: if we have a fantastic fan running, it will bring in odors from the tank vent. Any exhaust fan operating will cause you to have a low pressure in the bathroom with atmospheric pressure in the tank via the roof vent lines. That will always cause odors to enter the RV. No matter what you may put in the tank, you still dump in human waste and that has unplesant odors. The problem is the odor entering the RV. If you were to use a vent fan that pulled air into the RV rather than push it out, that would probably prevent your problem. No vent fan operating usually will do the same. Do you keep the black tank dump valve open or closed? It should be kept closed except when emptying the tank. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
