Vegas Teacher Posted February 1, 2017 Report Share Posted February 1, 2017 So has anybody gone crazy out there and built a 6 x 6 and added a drive train to the front wheels? This is just how my mind works - bigger and better traction especially if I go just a little off of the beaten path. Not crazy I know these things weigh a lot but just a little extra traction here and there. I know this would be custom, just a thought. Plus I am a science teacher and I am always asking questions and looking for things to modify or experiment with LOL! Still looking for that perfect VLN 780, tandem, D13, I-shift, work station, Fridge, Diff Lock, Interlock and APU. I guess I should throw in the sun and the stars at the same time LOL!!!! Later, Vegas teacher Link to comment Share on other sites More sharing options...
noteven Posted February 1, 2017 Report Share Posted February 1, 2017 I've been involved with some 14,600lbs to 23,000lbs front drive axle class 7's and 8's - if you light spec for RV pullin make sure your dentures are glued in and momma's upper undergarment straps are cinched up A better solution maybe would be Tire Boss tire pressure control from Tire Pressure Control International in Edmonton, AB Canada http://www.tirepressurecontrol.com/ Link to comment Share on other sites More sharing options...
Heavymetal Posted February 1, 2017 Report Share Posted February 1, 2017 Not sure I would want to pull my RV anywhere where I needed a 6x6 and the fuel mileage on the road would be really bad, not to mention the ride. I wouldn't mind having one on a GXV style motorhome though to hit some of the Deserts of Texas and some of the BLM lands. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 1, 2017 Report Share Posted February 1, 2017 I've been involved with some 14,600lbs to 23,000lbs front drive axle class 7's and 8's - if you light spec for RV pullin make sure your dentures are glued in and momma's upper undergarment straps are cinched up A better solution maybe would be Tire Boss tire pressure control from Tire Pressure Control International in Edmonton, AB Canada http://www.tirepressurecontrol.com/ This comment brings back memories of pulling with an MDT, particularly driving the truck solo. When describing the ride I used to "suggest" that the truck was only suitable for folks with total artificial dentures so you could remove them before undertaking a solo drive. Never thought of suggesting that momma cinch her upper undergarments up, the suggestion might be taken up but not before one was served a whack on the noggin. Link to comment Share on other sites More sharing options...
Broncohauler Posted February 1, 2017 Report Share Posted February 1, 2017 They make a front axle conversion for class 7-8 trucks. It uses hydraulic portal axles as I recall and about $30k For conversion kit. Much lighter than a true ring in pinon axle also better ride. Link to comment Share on other sites More sharing options...
Buscrusher Posted February 1, 2017 Report Share Posted February 1, 2017 They make a front axle conversion for class 7-8 trucks. It uses hydraulic portal axles as I recall and about $30k For conversion kit. Much lighter than a true ring in pinon axle also better ride. This might be the setup... http://www.tdsdrive.com/ez-tracaxle/ Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted February 1, 2017 Report Share Posted February 1, 2017 So has anybody gone crazy out there and built a 6 x 6 and added a drive train to the front wheels? This is just how my mind works - bigger and better traction especially if I go just a little off of the beaten path. Not crazy I know these things weigh a lot but just a little extra traction here and there. I know this would be custom, just a thought. Plus I am a science teacher and I am always asking questions and looking for things to modify or experiment with LOL! Still looking for that perfect VLN 780, tandem, D13, I-shift, work station, Fridge, Diff Lock, Interlock and APU. I guess I should throw in the sun and the stars at the same time LOL!!!! Later, Vegas teacher I once test drove such a vehicle. The ride was painfully rough. Considering I spend about 99% on the hard road and about 1% on dirt roads, I opted for a "kinder" ride. I routinely take my HDT and 5'er on dirt roads and I was initially was concerned. I am singled short. When on these dirt roads, I drive at "walking speed." The engine just idles me along. I do not get into soft, mushy sand. After a rain, I drive my Rhino (or walk) the road and inspect it, before I take the rig on it. Link to comment Share on other sites More sharing options...
Broncohauler Posted February 1, 2017 Report Share Posted February 1, 2017 This might be the setup... http://www.tdsdrive.com/ez-tracaxle/ Yep that's it? Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted February 1, 2017 Report Share Posted February 1, 2017 That's what some of the loggers use in the eastern swamps of NC. 1 dedicated truck to haul the log trailers from the log deck out to the road. Sometimes miles of deep mud or loose sand. Link to comment Share on other sites More sharing options...
rdickinson Posted February 1, 2017 Report Share Posted February 1, 2017 This has cropped up a time or two before. There is or was an outfit in Oklahoma, I think that did the conversions. 20k ish over a decade ago. It did raise things up some because you lose the dropped front axle and go to a straight axle. 6" or so. How would you deal with the hitch? Link to comment Share on other sites More sharing options...
Jack Mayer Posted February 1, 2017 Report Share Posted February 1, 2017 One of the major benefits of the HDT as we use them is comfort. Sure, safety is THE major thing, but comfort is a close second. I'd not give up the comfort for a 6x6. If you feel you NEED the all wheel drive I'd stick to a super pickup and a smaller trailer. Everything is a tradeoff, and this is one tradeoff that is not worth it, IMO - both for the comfort and the cost. Link to comment Share on other sites More sharing options...
noteven Posted February 2, 2017 Report Share Posted February 2, 2017 Link to comment Share on other sites More sharing options...
beyerjf Posted February 2, 2017 Report Share Posted February 2, 2017 I believe this is what you are after. Many examples on You Tube Link to comment Share on other sites More sharing options...
Av8r3400 Posted February 2, 2017 Report Share Posted February 2, 2017 I think what you really want is an M932. 6x6, Cummins, Allison, super singles, everything a growing boy needs. Link to comment Share on other sites More sharing options...
Dollytrolley Posted February 2, 2017 Report Share Posted February 2, 2017 So has anybody gone crazy out there and built a 6 x 6 and added a drive train to the front wheels? This is just how my mind works - bigger and better traction especially if I go just a little off of the beaten path. Not crazy I know these things weigh a lot but just a little extra traction here and there. I know this would be custom, just a thought. Plus I am a science teacher and I am always asking questions and looking for things to modify or experiment with LOL! Still looking for that perfect VLN 780, tandem, D13, I-shift, work station, Fridge, Diff Lock, Interlock and APU. I guess I should throw in the sun and the stars at the same time LOL!!!! Later, Vegas teacher Teach, OMG you have flashed me back to my "child-slave" childhood........ Grumps came back from a heavy equipment auction with a...........OSHKOSH 6 x 6 and this made every other truck you ever saw look like a tinker toy........the darn sun-vizor's were 1/2 inch steel plate and everything was HEAVY.... The BEAST had TWO .......HUGE Garwood winches with 1 1/2 wire rope that could drag a fully loaded log truck up a cliff at idle..... It had a 220 cummins straight stack right in front of the windshield and only had forty speeds forward (5 +4+2) and a bunch of speeds in reverse but don't worry the drivers were planetary's with low range about 15:1 so no need to fear speed ........unless you were going down a hill. The rig was "limited" to 200 tons but I fear it was almost at it's limit when grumps loaded it full of tools and dozer parts. The "springs" said "Baldwin" and they were 1" thick X 6 " wide and stacked 18" high......even with 200 tons these 'springs" never EVER flexed..... Did I mention the Beast had arm-strong power steering....trust me you had to have STRONG arms the steer the Beast. The interior was "classic" steam locomotive ....... shifters were every where ...one five speed stick....one brownie shifter (four speeds) , one transfer case engage stick.....one low range stick......THREE sticks for the front winch....THREE sticks for the back winch.....THREE sticks for each PTO....... The drivers windshield wiper was air driven but the passenger side had a hand crank that was as heavy as a crow bar. One day out in the woods I backed the Beast into a boulder bigger than a smart car.......it broke the boulder into pieces.....not a dent in the beast. In the winter the beast had TEN tire chains on it out in the woods and it would push snow until you could not see out the windshield ........ Teach, I think maybe you should search around and find a Osh......by gosh ........it would be a heck of a project for the kids and.....they will never forget the ride.......I haven't..... Drive on.......(Oshkosh......Girlie Truck....NOT) Link to comment Share on other sites More sharing options...
Vegas Teacher Posted February 2, 2017 Author Report Share Posted February 2, 2017 This is what I love. I knew if I threw a topic out like this people would send fun things my way. I know I will always remember my grandpa's '46 chevy 1 1/2 ton grain truck with a dump bed on it. Double clutch and all. But I figure each of us who has the balls to want a semi to pull a travel trailer has thought Well what if.............. From the responses I can see that is true. Keep the pictures, videos and stories coming! Later, Vegas Teacher Link to comment Share on other sites More sharing options...
Broncohauler Posted February 2, 2017 Report Share Posted February 2, 2017 https://www.youtube.com/watch?v=9fzCd0bGs1M Wow thanks for posting. I've driven a superduty on pismo NO way I would take a HDT out there. I've also had my HDT stuck in the sand out in the desert, hopefully never again ?? We had to unhook my trailer and then winched the truck out with my early Bronco a milemarker 8500lb winch double snatch blocked and 2 trucks hook on the back for anchors. Link to comment Share on other sites More sharing options...
Bob86ZZ4 Posted February 6, 2017 Report Share Posted February 6, 2017 No no, what you really want is an M1070 HET. My son drove these all over Iraq. He never got one stuck. And the trailers have 40 tires on them so no problem there. Link to comment Share on other sites More sharing options...
Av8r3400 Posted February 6, 2017 Report Share Posted February 6, 2017 Mmmmmm -- The sweet music of a 8V92 Screaming Detroit!!! That'll make friends in the campground... Link to comment Share on other sites More sharing options...
