lappir Posted April 24 Report Share Posted April 24 Had heard good things about this item, so less than 3 years ago I bought one. Seemed to work as advertised up until a few days ago when I got it out to help with my recent Tool Box project. Charged up the battery at my newly located and hopefully where I will always have my charger (maybe after removing the one for this). Put the battery on and pulled the trigger and it maybe did a half turn before stopping and hasn't move a mm since. I've tried recharging the battery but it shows a full charge. I tried assisting with the move thinking it maybe had a "Dead Spot" but nothing worked. Just got off the phone with the Harbor Freight help and they suggested finding a "Qualified Technician" to investigate further and maybe have parts at their disposal. "Harbor Freight has no replacement parts and since you didn't opt for the "Extended" Warranty replacement is not an option." So I'm preparing to become a "Qualified Tech" and open the stupid thing up. Anyone operated on one yet? Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
lenp Posted April 25 Report Share Posted April 25 Makes for a cool flashlight now! Good luck finding the problem. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
justRich Posted April 25 Report Share Posted April 25 It's probably a bad battery - especially if it's Chinese made. When I opened my Chinese made rechargeable fan I found the battery puffed up (a lithium polymer battery) and the amp hours much less than claimed on their advertising. Dead battery. The manufacturer either lied or their battery supplier cheated them. The lipo batteries will die if their voltage drops below a certain point. I suspect that, over time, they self-discharge to the point where they won't take a charge. Quote ~Rich Link to comment Share on other sites More sharing options...
lappir Posted April 25 Author Report Share Posted April 25 3 minutes ago, justRich said: It's probably a bad battery - especially if it's Chinese made. When I opened my Chinese made rechargeable fan I found the battery puffed up (a lithium polymer battery) and the amp hours much less than claimed on their advertising. Dead battery. The manufacturer either lied or their battery supplier cheated them. The lipo batteries will die if their voltage drops below a certain point. I suspect that, over time, they self-discharge to the point where they won't take a charge. The battery has never been discharged fully and shows a full charge. I haven't taken the volt meter to it yet, but I'm sure it's at max voltage. Thanks for the reply. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Randyretired Posted April 25 Report Share Posted April 25 Sometimes on things like this it is the on switch. Hopefully it is something simple. Likely the battery was made in China since they make nearly all of the lithium batteries. China battery production is second to none. It doesn't seem bad by your description. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 25 Report Share Posted April 25 If you're counting on having equipment worth passing down to future generations, Harbor Freight isn't the place to buy anything with a cord. Pull it apart, focusing on wire connections. A bad solder joint will only get worse with use, before getting bad enough to fail. Check out the trigger switch, if the solder joints all pass inspection. I've had a HF variable speed drill switch fail to all or none mode. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
lappir Posted April 26 Author Report Share Posted April 26 7 hours ago, Darryl&Rita said: If you're counting on having equipment worth passing down to future generations, Harbor Freight isn't the place to buy anything with a cord. Pull it apart, focusing on wire connections. A bad solder joint will only get worse with use, before getting bad enough to fail. Check out the trigger switch, if the solder joints all pass inspection. I've had a HF variable speed drill switch fail to all or none mode. Not planning on passing it down, most likely obsolete by the time I pass. At least I hope so. It's also not corded per se' only the charger has a cord and it's working fine. Haven't torn it apart yet, still thinking about trying an in person return to the store where I bought it. I'll be there in a month. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
