MilesAndSmiles
Compressors comparable to Viair 400p
Within the RV community, particularly on YouTube, you'd think that the only reasonable choice for a 12v air compressor is the Viair 400p. It looks like a great unit, but at $200 (more or less) it aught to be! But how do the alternatives hold up? Harbor Freight has a compressor that has comparable specs for $65. I assume there are others.
All I need to do is re-inflate my Class A tires from time to time (95 PSI), and blow out the water hoses once or twice a year when winterizing.
What's worked for you?
Share this post
Link to post
We have the Viair....yes it's expensive, but when I need to top off our 125# 5th wheel tires or the 110# steer tires on the truck nothing works better!  Just thought I'd give our experiences.  Good luck in your search.
Share this post
Link to post
I have had cheap 12 volt Air Compressor in the past and they worked great for a short time and then quit when I need them.  I now have the VIAIR 450RV and there is no comparison.  I guess I want something I can depend on when I need it.
Edited by sundancer268
Share this post
Link to post
I had two Kobalt 12 volt compressors from Lowe's and both died after a few uses.  Now have a ViAir 400PRV and it is still going over a year later.  You pay your money and take your chances.
Ken
Share this post
Link to post
do you have air brakes on your rv?
you can tap into this source for tons of compressed air. even to change out a tire.
if not then one can not go wrong buying the best, ( buy once, cry only once) but if possible add in a 5 gallon supply tank.
Edited by packnrat
Share this post
Link to post
I tried the Harbor Freight one but it didn't work on 22.5 tires and took way longer on the 35's on my JK Wrangler, so I took it back and bought the Viar , way better!
Share this post
Link to post
I have had a Viair 88p for about six years, still going strong.  It is not at all comparable to the 400, but has handled my Jeep tires dozens of times, and the trailer tires a few times.  Probably about $65 at most places.  I added the 6' hose extension for better reach on all tires.
Share this post
Link to post
Whatever brand or type you choose to use; remember to buy and use an air filter/dryer on the pressure hose. This is more critical on a small tank compressor, as the compressed air doe not have time to cool and condense air before it enters a tire.
I have a 120VAC Fini pancake compressor with built-in regulator, and always use a small air filter when adding air to tires. That moisture is what causes unusual tire pressure rise at interstate speeds.
Share this post
Link to post
I've never used a filter on the portable and have never noticed any change between its air and the very filtered air I have in my home shop.  I refill the Jeep tires pretty regularly since it's off road a lot.
Share this post
Link to post
That is your decision, I just presented the facts as I understand them. You will not notice water in compressed air until it condenses, that happens when compressed air(it heats when compressed) temperature  declines to ambient air temperature.
If you are in the SW it is not usually a concern.
Edited by Ray,IN
Share this post
Link to post
To be clear, the compressed air from one of these inflators will have exactly the same amount of moisture (dewpoint) as the outside air that is being compressed.  The process of compressing the air adds/subtracts nothing. That being said, a filter/drier doesn't hurt a thing, and may reduce the moisture content of the air some under really humid circumstances.
I think that where we see problems on the tank type compressors is when the tank goes for a long period of time without being drained and it accumulates a lot of water. I have drained many cups of water out of park/refuge compressors that obviously hadn't been drained in a long, long time. This amount of water in a tank can introduce a considerable amount of moisture into a tire. It is even a bigger problem if you are trying to paint and get "spits" coming down the line.
Share this post
Link to post
Me too!
Share this post
Link to post
On a humid day in South Jersey my 5 gallon shop compressor will spray water if through a long hose. I run the compressor through a length of copper pipe, then a cheap water separator from HF, then a desiccant filter from NAPA. I use this whenever doing any tire repair or inflating.
Share this post
Link to post
Tank compressors are a different thing from tankless.  I'm not aware of any filter that will remove humidity from a portable tankless compressor without being as big as the compressor and double the cost.  The drier for my plasma torch is big and expensive.
Share this post
Link to post
Compressed air is hot. The compressed air contains as much moisture as in the original air it collected. Cool the air and the moisture condenses. We call that water. It doesn't matter what type of air compressor you use. My post was only about my experiences. I'm glad you have a big plasma something or other.
Share this post
Link to post
Only while or immediately after being compressed. It doesn't stay hot just because it is compressed.
This is where the tank type compressor varies from the tankless.  In a tank-type the air is held at some elevated pressure (say 150 psi). Assuming that it has been there a while it will be a room temperature unless the compressor has been running recently.  But as that 150 psi air comes through the regulator and either into a tire at a lower pressure or into the atmosphere (lower pressure still), it will indeed drop in temperature and may start condensing water, depending on the dew point of the air in the tank.
With a tankless inflator, the air is compressed, goes through a regulator, and is discharged all in one process.  In that case it is highly unlikely (impossible I think?) to discharge the air at lower temperature than the ambient temperature that it went in at, so condensation shouldn't occur.
Share this post
Link to post
Time to Go Away. we have successfully hijacked this thread. I guess the water can't get in the tire from direct compressed air. What a engineering break through. good day to you.
Share this post
Link to post
Not what I said at all.  Whatever moisture is in the atmosphere goes into the tire. Nothing more, nothing less.
Share this post
Link to post
Really?  Then how does air conditioning, or a refrigerator work?
You can't re-write the laws of physics, just because you don't understand them.
Share this post
Link to post
Rv Insurance Benefits.com Logo
AGS Now Hiring
RV Pet Safety
