Wrknrvr Posted November 5, 2018 Report Share Posted November 5, 2018 I am curious if different tires on a HDT will affect the ride on the rear of vehicle. Just curious,. Vern Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 5, 2018 Report Share Posted November 5, 2018 I have read that supper singles ride better because of 2 less side walls. Pressure will probably make more difference. Most of us dont need high pressure for the loads we cary. Link to comment Share on other sites More sharing options...
rickeieio Posted November 5, 2018 Report Share Posted November 5, 2018 Interesting...... Vern, since you're already running singles, the sidewall idea is moot, but the increased volume will drop the pressures. See the current discussion on air bags. However, since you're still tandem, you likely can't safely drop pressures far enough to realize any real benefit, without risking the tire falling off the rim. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
jeffw Posted November 5, 2018 Report Share Posted November 5, 2018 Pressure makes a huge difference. We are not singled, and went from over 100PSI to 70 on the drives and the ride is so much better. 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
ARGO Posted November 5, 2018 Report Share Posted November 5, 2018 Lots of trucking co's tried them, MANY have gone back for several reasons. Myself, with the light loads we have on the drive, I'm worried about lockup on hard braking in the wet. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Wrknrvr Posted November 5, 2018 Author Report Share Posted November 5, 2018 Now what I am curious about is, Is there a difference in the ride of different tires in the same application. As same size tire in the same configuration. Just like car tires act differently in the same size, but different makes on the same vehicle in the same position and all the technical compounds and ??? Also the other post got me to think differently than the air bag discussion. Now remember same application. Just different tire make and model. Well my fishing trip went bad this fall, so I am bored again. Just thinking, Vern Link to comment Share on other sites More sharing options...
Parrformance Posted November 5, 2018 Report Share Posted November 5, 2018 1 hour ago, jeffw said: Pressure makes a huge difference. We are not singled, and went from over 100PSI to 70 on the drives and the ride is so much better. How many miles have you driven with 70 psi? Have you lowered the steer tires at all? 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
jeffw Posted November 5, 2018 Report Share Posted November 5, 2018 It's been that way since mid last year. Maybe 15k? I have the steers at 90 to start. That's based on our front axle weight w/o the trailer on. We could go less pressure there with the trailer on, but that wouldn't work well otherwise. 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
dennisvr Posted November 5, 2018 Report Share Posted November 5, 2018 I do believe that Michelin has softer side walls to give a softer ride, but I don't like them because of the side wall cracking. I talked to a Michelin Rep and he called it Ozone cracking and I asked him if that was the case then why didn't the other manufactures crack like theirs. "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
Steve from SoCal Posted November 5, 2018 Report Share Posted November 5, 2018 Different types of tires in the same size would have different ride properties. An open shoulder lug tire will be lumpier than a rib steer. The tread pattern itself is part of it and, the tread interaction with road surfaces and the tire carcass. Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 5, 2018 Report Share Posted November 5, 2018 1 hour ago, ARGO said: Lots of trucking co's tried them, MANY have gone back for several reasons. Myself, with the light loads we have on the drive, I'm worried about lockup on hard braking in the wet. My truck came with the supper singles and I have wondered the same. So far the answer has been no but I haven put on enough miles to give a educated answer. There is just about the same number of square inches of tread on the road as with duals so unless there is a trapped cusion of water under the tire there should not be much difference for equally loaded truck. Link to comment Share on other sites More sharing options...
beemergary Posted November 5, 2018 Report Share Posted November 5, 2018 56 minutes ago, Parrformance said: How many miles have you driven with 70 psi? Have you lowered the steer tires at all? I lowered mine from 100 psi to 85 and lost the seal. Couldn't get it to seal. Had the truck jacked up and air available. Guy came from a mile away and gave it a blast with an air blaster. That will be $150.00 Not a happy camper. The sidewalls on the tires I have are real stiff. Link to comment Share on other sites More sharing options...
Parrformance Posted November 5, 2018 Report Share Posted November 5, 2018 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
HERO Maker Posted November 5, 2018 Report Share Posted November 5, 2018 That is a real smart guy with the lit smoke in his mouth while spraying that spray!!!! Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Wrknrvr Posted November 6, 2018 Author Report Share Posted November 6, 2018 I found this on the net today. Just thought would provide it for some info on the subject. https://www.acmetires.com/comparison/ . Just a thought,. Vern Link to comment Share on other sites More sharing options...
noteven Posted November 6, 2018 Report Share Posted November 6, 2018 My guess is tire load index or capacity or “ply rating” has the most effect on ride. What I learned at some training at an undisclosed location: Tires are the first suspension component. Inflation psi for the load being carried is important for ride and traction. Modern low rolling resistance tires do not need to be blowed up like a wood wagon wheel to get the best fuel economy. Rule of thumb - Truck tires should be inflated to provide 10% sidewall height reduction rim to tread on the bottom vs rim to tread on portion not on the ground. Manufacturers minimum psi and above should be maintained for on highway use. Psi can be reduced a lot for off highway flotation and traction at low speed. Ideally these trucks have on board inflation systems. Ultimate HDT boondocking truck gadget ever: http://www.tireboss.com/ https://m.youtube.com/user/tirebossvideopage "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
