Vegas Teacher Posted May 14, 2018 Report Share Posted May 14, 2018 I am only able to get to my truck on the weekends as it is now on the West side of Pahrump. I am taking the advice of those on the forum and getting my hands dirty, turns out when you work on one of these truck you get your whole body dirty. It is the beginning of the school day and even after "Goop" "Fast Orange" "Lava" and finger nail brush I am still finding pockets of oil and grease I missed, however it was not missed by the parent this morning at the parent teacher conference this morning when they said who are you and my daughter does not have auto shop. So anyway I am in Pahrump, Flyer tried to get some rusted on bolts off of my semi this weekend. He had a 20 volt 1/2 inch impact with 1800ft * Lbs of break away power. We soaked them in everything known to man but they did not budge. I am looking for somebody who has a 1 inch impact. Flyer said the same thing happened to him on his truck 1/2 inch got laughed at, 3/4 inch got slight movement but it was not until they used the 1 inch impact that stuff came off. So to follow his lead I am wanting to start at the 1 inch air impact. I am looking for a good mobile mechanic to help me. It is for the shocks on the back of the cab. They are frozen in place. I will be able to work on it next Saturday. The nut is 21mm's and the bolt on the back is in the neighborhood of 19 or 20 mm's. I do not have the impact wrench and I do not have an air compressor. So I need a good mobile mechanic. Please P.M. me and I will give you my phone number and we can talk more. Link to comment Share on other sites More sharing options...
mr. cob Posted May 14, 2018 Report Share Posted May 14, 2018 12 minutes ago, Vegas Teacher said: I am only able to get to my truck on the weekends as it is now on the West side of Pahrump. I am taking the advice of those on the forum and getting my hands dirty, turns out when you work on one of these truck you get your whole body dirty. It is the beginning of the school day and even after "Goop" "Fast Orange" "Lava" and finger nail brush I am still finding pockets of oil and grease I missed, however it was not missed by the parent this morning at the parent teacher conference this morning when they said who are you and my daughter does not have auto shop. So anyway I am in Pahrump, Flyer tried to get some rusted on bolts off of my semi this weekend. He had a 20 volt 1/2 inch impact with 1800ft * Lbs of break away power. We soaked them in everything known to man but they did not budge. I am looking for somebody who has a 1 inch impact. Flyer said the same thing happened to him on his truck 1/2 inch got laughed at, 3/4 inch got slight movement but it was not until they used the 1 inch impact that stuff came off. So to follow his lead I am wanting to start at the 1 inch air impact. I am looking for a good mobile mechanic to help me. It is for the shocks on the back of the cab. They are frozen in place. I will be able to work on it next Saturday. The nut is 21mm's and the bolt on the back is in the neighborhood of 19 or 20 mm's. I do not have the impact wrench and I do not have an air compressor. So I need a good mobile mechanic. Please P.M. me and I will give you my phone number and we can talk more. Howdy VT, "IF" you can use it without burning the truck up, an OXY-ACT touch commonly called a "Fire Wrench" will be of great assistance when working on such things. Dave Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted May 14, 2018 Report Share Posted May 14, 2018 Wrestled some drive tires this weekend. Glad my uncle has equipment I can barrow. 1" impact and tire tools. Link to comment Share on other sites More sharing options...
runaway parents Posted May 14, 2018 Report Share Posted May 14, 2018 Try a 3/4 inch breaker bar and a six foot piece of 11/2 pipe to extend the handle this will break the bolts loose ore break them off.( who said give me a lever and I can move the world) Break them loos then go back to rattle gun to finish removing them. if you cant get them with a 6 foot get a longer pipe. DISCLAMER you are using a tool for what it is not designed for if breaker bar breaks it will be violent and sudden do not have any parts of your body in the line of fire it going to hurt a lot if the pipe hits you .Putting a pipe on a ratchet or breaker bar is over loading it put enough pressure on it. it will break . Link to comment Share on other sites More sharing options...
Parrformance Posted May 14, 2018 Report Share Posted May 14, 2018 22 minutes ago, runaway parents said: Try a 3/4 inch breaker bar and a six foot piece of 11/2 pipe to extend the handle this will break the bolts loose ore break them off.( who said give me a lever and I can move the world) Break them loos then go back to rattle gun to finish removing them. if you cant get them with a 6 foot get a longer pipe. DISCLAMER you are using a tool for what it is not designed for if breaker bar breaks it will be violent and sudden do not have any parts of your body in the line of fire it going to hurt a lot if the pipe hits you .Putting a pipe on a ratchet or breaker bar is over loading it put enough pressure on it. it will break . I used a 3/4 inch breaker bar from Amazon,TEKTON 15359 3/4-Inch Drive by 38-Inch Breaker Bar and one of the long pipes the flatbed tractor trailer drivers use to tighten the straps with the buckles welded on the side of the decks.. Turns out this tire knocker has a loop welded on the opposite end of the tool that fits the hand hold on the breaker bar. I will say I was able to get a very impressive bow into the breaker bar, but it did loosen the 550 lb feet of torque on the lug nuts!! I do not imagine the shock bolts are anywhere near 550 lbs of Torque.. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted May 14, 2018 Report Share Posted May 14, 2018 Quote He had a 20 volt 1/2 inch impact with 1800ft * Lbs of break away power. I have a bridge in Brooklyn for sale cheap... Do the math Link to comment Share on other sites More sharing options...
Steve from SoCal Posted May 14, 2018 Report Share Posted May 14, 2018 As Mentioned, heat is the best way to get the nuts loose without the real prospect of shearing the bolts with a big impact. If you don't care to save them, a cut off tool works well. I have 1/2- 3/4 and, 1 inch impact guns, the 1 inch will shear a 16 or 5/8 bolt like nothing. Steve Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 14, 2018 Report Share Posted May 14, 2018 I'm guessing he meant 1800 inch pounds, not foot pounds. That's only 150 foot pounds, so a good breaker bar in 1/2" will have more twist. Step up to 3/4", and stand back. Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 14, 2018 Author Report Share Posted May 14, 2018 1 hour ago, Darryl&Rita said: I'm guessing he meant 1800 inch pounds, not foot pounds. That's only 150 foot pounds, so a good breaker bar in 1/2" will have more twist. Step up to 3/4", and stand back. According to Vegas Flyer it was foot pounds Link to comment Share on other sites More sharing options...
atv_idiot Posted May 14, 2018 Report Share Posted May 14, 2018 How much room do you have near the bolts? ever heard of a torque multiplier? Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 14, 2018 Report Share Posted May 14, 2018 It is 1200 Foot Pounds of breakaway torque. Dewalt 1/2” Impact. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 14, 2018 Report Share Posted May 14, 2018 Heat on the nut helps, even a Benzomatic torch with MAP gas (Yellow tank) will help break rust. Have some water handy if you have been spraying them with any solvent... I have taken a torch and held it on the bolt and let an impact hammer on the nut. The combo heat and vibration might break it loose. On the cleanup side of life, Dawn dish detergent works wonders on a nail brush. If the brush isn't too course, you can scrub your arms, neck, ankles, etc with it. It helps. Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 14, 2018 Report Share Posted May 14, 2018 We tried a breaker bar with a 4’ pipe extension and tried all the normal tricks. it is true that heat would work, however, there is too much grease around the area. Along with about a gallon of PB Blaster that VT douched his truck with. While electric impacts are better than nothing, he just needs a decent air impact or a nut splitter. Link to comment Share on other sites More sharing options...
PaHunter Posted May 14, 2018 Report Share Posted May 14, 2018 best thing to soak old rusty bolts with is Kroil, made by a company called Kano. Stuff is amazing. Link to comment Share on other sites More sharing options...
beyerjf Posted May 15, 2018 Report Share Posted May 15, 2018 Time to up the ante. You need to step up to a 1" drive socket, 1" breaker bar and at least a 6' pipe. If your 200 lbs x 6' = 1200 ft lbs of torque doesn't move it, it should be cut off. A full power 1" impact gun with 1/2" air line and 120 psi is only good for about 1000 foot lbs. if you want to have someone hammer on the fastener during the process you can duplicate the impact gun. Just position everything so if it breaks, or the tool does no one gets hurt. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 15, 2018 Report Share Posted May 15, 2018 4 hours ago, VegasFlyer said: It is 1200 Foot Pounds of breakaway torque. Dewalt 1/2” Impact. Interesting specs. 700 ft-lbs max, with 1200 ft-lbs of breakaway torque. Not sure what that means. I see these units, and Milwaukee, all the time at work, and I'm not impressed. I'm not a knuckle dragging hulk, but I can manually out torque the best of the cordless units, with a little less noise. Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 15, 2018 Report Share Posted May 15, 2018 The real difference between a impact gun and a braker bar is the hammering of the impact gun. Those thousands of blows is what loosens a stuck nut. They make a hand impact tool but I have not seen one bigger than 1/2". The torque multiplier is something you should have in your box Anyone try the $200 dollar 1" gun they claim 1800 lb/feet. Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 15, 2018 Report Share Posted May 15, 2018 5 minutes ago, rm.w/aview said: Are you referring to a slug wrench? I have never heard of a slug wrench what is it? I am referring to a tool which you apply torque to by hand and then hit with a hammer. They are not as good as air tools but that all we had when I was a kid. One advantage of the hand tool is that you will not brake the bolt of. I grew up in a Bultaco motorcycle shop and we often had to use this tool to remove bolts in crankcases. Link to comment Share on other sites More sharing options...
Rick & Alana Posted May 15, 2018 Report Share Posted May 15, 2018 A mobile tires service might be an option. Just make sure and tell them what size socket they will need. Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 15, 2018 Author Report Share Posted May 15, 2018 I found a mobile mechanic in Pahrump. They are meeting me on Saturday. If he can't get the bolts off he is not going to charge me, if he can get the bolts off and does not have to do any major work he said he would not charge me either. I really can't ask for more than that. Later, Vegas Teacher Link to comment Share on other sites More sharing options...
runaway parents Posted May 15, 2018 Report Share Posted May 15, 2018 5 minutes ago, Vegas Teacher said: I found a mobile mechanic in Pahrump. They are meeting me on Saturday. If he can't get the bolts off he is not going to charge me, if he can get the bolts off and does not have to do any major work he said he would not charge me either. I really can't ask for more than that. Later, Vegas Teacher Don't think so but I have to ask . Could they be left handed threads? Ran into that trying to remove lug nuts on a old loadstar international . Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 15, 2018 Author Report Share Posted May 15, 2018 9 minutes ago, runaway parents said: Don't think so but I have to ask . Could they be left handed threads? Ran into that trying to remove lug nuts on a old loadstar international . We tried going both ways with the impact wrench, no luck. Link to comment Share on other sites More sharing options...
runaway parents Posted May 15, 2018 Report Share Posted May 15, 2018 I feel your pain . RUST = NOT MUCH FUN . Probably hot wrench time Mr Seas has a recipe for kroil haven't tried it yet but supposed to work great. Painted trk bedIit will be to weeks Thursday and just now finaly got all the paint off my hands. commercial grade paint dosent wash off you have to ware it off. Link to comment Share on other sites More sharing options...
atv_idiot Posted May 15, 2018 Report Share Posted May 15, 2018 May I suggest using Anti-Seize on everything you take apart and put back together.... Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 15, 2018 Report Share Posted May 15, 2018 9 hours ago, runaway parents said: Don't think so but I have to ask . Could they be left handed threads? Ran into that trying to remove lug nuts on a old loadstar international . They are right handed threads. 8 hours ago, runaway parents said: I feel your pain . RUST = NOT MUCH FUN . Probably hot wrench time Mr Seas has a recipe for kroil haven't tried it yet but supposed to work great. Painted trk bedIit will be to weeks Thursday and just now finaly got all the paint off my hands. commercial grade paint dosent wash off you have to ware it off. On a grand scale, they are not that rusted. It appears that someone may have put threadlock on them. We cut one bolt out and it definitely did not look like it was rusted. Link to comment Share on other sites More sharing options...
