Mastercraft Posted May 26, 2017 Report Share Posted May 26, 2017 The Volvo Ishift trucks I understand are available with Hill Start Assist. So, for a truck that doesn't have that feature, is it a software change only or is there hardware required to go along with it? 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 26, 2017 Report Share Posted May 26, 2017 That is a great question. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
rdickinson Posted May 26, 2017 Report Share Posted May 26, 2017 Mine is an 09 and told it couldn't be programmed in. This was from the guy who didn't make it to the WCR 2 yrs ago....not sure though. Link to comment Share on other sites More sharing options...
Scrap Posted May 26, 2017 Report Share Posted May 26, 2017 For an Ultrashift it takes a set of 3 valves, some frame plumbing, a harness layer or two, a dash switch, and some trans and dash programming to activate it. Have no idea on an I-Shift/Volvo but imagine it is a somewhat similar type of thing. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted May 26, 2017 Report Share Posted May 26, 2017 34 minutes ago, Scrap said: For an Ultrashift it takes a set of 3 valves, some frame plumbing, a harness layer or two, a dash switch, and some trans and dash programming to activate it. Have no idea on an I-Shift/Volvo but imagine it is a somewhat similar type of thing. That is like a heart surgeon saying "It's simple really, crack the ribs, tie this off here, pull this over there, remove the heart and replace it with a donor heart and install in the reverse order". I love how you make things sound so simple and then show me just how simple it is 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
Jack Mayer Posted May 26, 2017 Report Share Posted May 26, 2017 Same on a Volvo....it involves more than programming. What, exactly, I don't know....but it is not an easy retrofit. I've driven three Volvo's with it...and own one. I initially did not like it. But I've warmed to it. If I order a new truck it will be on it. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
13speed Posted May 26, 2017 Report Share Posted May 26, 2017 I have had it on company work trucks and on my 630. I will not be getting it on my new VNR. Every time you stop it grabs and holds and I find it can be jerky in tight maneuvers. Its a automatic trans, you just slide from the brake pedal to the gas the clutch is done automatically so I don't see the need. If you were very heavy and on super steep grades all day every day then maybe but other than that it is more of a nuisance IMHO. Chris, Tracey, Aria & Lola 2018 Volvo VNR 400, D13 I-Shift 2018 NH 48' Majestic Link to comment Share on other sites More sharing options...
Star Dreamer Posted May 26, 2017 Report Share Posted May 26, 2017 My brake pedal on my Ultrashifts works just perfectly as a hill start assist as long as I have two feet. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted May 27, 2017 Report Share Posted May 27, 2017 It would seem somewhat redundant on an automated transmission, but could be a godsend on a manual in certain situations. "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted May 27, 2017 Report Share Posted May 27, 2017 I have the hill start assist on mine but if need be, I can always switch it off on the dash. With that capability, I don't understand why you wouldn't have it on a truck. 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
Heavymetal Posted May 27, 2017 Report Share Posted May 27, 2017 12 hours ago, GeorgiaHybrid said: I have the hill start assist on mine but if need be, I can always switch it off on the dash. With that capability, I don't understand why you wouldn't have it on a truck. Ditto! 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
13speed Posted May 27, 2017 Report Share Posted May 27, 2017 13 hours ago, GeorgiaHybrid said: I have the hill start assist on mine but if need be, I can always switch it off on the dash. With that capability, I don't understand why you wouldn't have it on a truck. Because it is something that you always have to turn off over and over. If it just stayed off it would not be a big deal. It is just not needed with a automated trans. If you already have it then no biggie but like I had said I would not spec it on a new truck. Chris, Tracey, Aria & Lola 2018 Volvo VNR 400, D13 I-Shift 2018 NH 48' Majestic Link to comment Share on other sites More sharing options...
Broncohauler Posted May 27, 2017 Report Share Posted May 27, 2017 I have it on a company truck and like it. I do turn it off for moving trailers around our docks, and it stays off until you get back up to road speed. Dont know about retro fitting? But would order it on a new truck. Link to comment Share on other sites More sharing options...
noteven Posted May 27, 2017 Report Share Posted May 27, 2017 2016 and up Triumph Tiger Explorer XCa (1200cc Big "adventure" bike) has hill start assist ... two up with luggages etc it is a fine piece of kit for those uphill starts ... Broncohauler - you turn off hill start assist to reverse downhill into docks yes? Use the brakes ("breaks" on interweb) to control collison speed? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 27, 2017 Report Share Posted May 27, 2017 21 hours ago, Star Dreamer said: My brake pedal on my Ultrashifts works just perfectly as a hill start assist as long as I have two feet. Dave Unfortunately it doesn't work that way on the I-Shift, due to the fly-by-wire throttle, the throttle will not advance to the point of clutch engagement with the brakes engaged. You have to release the brake pedal and time the throttle application to just before the brake actually releases. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted May 27, 2017 Report Share Posted May 27, 2017 3 hours ago, 13speed said: Because it is something that you always have to turn off over and over. If it just stayed off it would not be a big deal. It is just not needed with a automated trans. If you already have it then no biggie but like I had said I would not spec it on a new truck. Don't know what type of switches you have on your truck but when I turn mine off they stay off. The only switches I have that will revert are the non-latching electric over air switches and then only when the ignition is off. As soon as the key is turned, they will back to the position selected. 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
Scrap Posted May 27, 2017 Report Share Posted May 27, 2017 On 5/25/2017 at 9:00 PM, GeorgiaHybrid said: That is like a heart surgeon saying "It's simple really, crack the ribs, tie this off here, pull this over there, remove the heart and replace it with a donor heart and install in the reverse order". I love how you make things sound so simple and then show me just how simple it is You are just a set of portable wheel lifts away from making it all easy......... Link to comment Share on other sites More sharing options...
Broncohauler Posted May 28, 2017 Report Share Posted May 28, 2017 10 hours ago, noteven said: 2016 and up Triumph Tiger Explorer XCa (1200cc Big "adventure" bike) has hill start assist ... two up with luggages etc it is a fine piece of kit for those uphill starts ... Broncohauler - you turn off hill start assist to reverse downhill into docks yes? Use the brakes ("breaks" on interweb) to control collison speed? we have dock locks that grab your tire. They can be a challenge to get in and out of, so you turn it off to be smoother rolling in and easier to pull out with out being hung up waiting for the brakes to release Link to comment Share on other sites More sharing options...
