RHeller1 Posted May 2, 2017 Report Share Posted May 2, 2017 2011 Volvo VNL with an ABS fault code that I cant seem to find anywhere. Any help appreciated MID 136 SID 69 FMI 2 Link to comment Share on other sites More sharing options...
Seniramsu Posted May 2, 2017 Report Share Posted May 2, 2017 Hello RHeller1, I was able to find this: 2013 Volvo 780 "Grunt" D13 I-Shift w/ ET Hitch 2016 Cyclone 4200 Link to comment Share on other sites More sharing options...
RHeller1 Posted May 2, 2017 Author Report Share Posted May 2, 2017 Wow, that was quick! thanks!! Now I just need to figure out what that means...LOL Link to comment Share on other sites More sharing options...
MrSeas Posted May 2, 2017 Report Share Posted May 2, 2017 Are you singled? Check connections/ tone ring on right rear. Link to comment Share on other sites More sharing options...
GlennWest Posted May 2, 2017 Report Share Posted May 2, 2017 Any wheels been off recently? Had king pin bushings replaced in mine and wheel sensor didn't make contact. They push in all the way. Pushed in hard and popped right in place. Light went out before even get out of park. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Scrap Posted May 3, 2017 Report Share Posted May 3, 2017 Brake demand sensors are two transducers in the front and rear circuits of the the treadle valve. Load sensor is the transducer in the rear suspension. FMI =2 is commonly dead or intermittent. When they are changed they usually need a re-calibration using ACOM (Bendix Software). ABS works with this code on but roll stability/ESP doesn't. Link to comment Share on other sites More sharing options...
GlennWest Posted May 3, 2017 Report Share Posted May 3, 2017 When singled my abs box had to be changed. Replaced 4X6 for 4X4 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 3, 2017 Report Share Posted May 3, 2017 Has the truck been singled or is it still tandem? If singled, what did the shop do with the mid axle ABS harness? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
RHeller1 Posted May 3, 2017 Author Report Share Posted May 3, 2017 its still tandem. Link to comment Share on other sites More sharing options...
Mastercraft Posted August 10, 2017 Report Share Posted August 10, 2017 I have this 136 69 2 thing going on with the TCS light on. Claims load sensor erratic. When I am going down the road, the pressure displayed for the rear bags moves around in a 3 psi window. Does that constitute erratic? I don't think the bag pressure is really moving that much. Changed out the sensor on the firewall feedthru....no change. So, do the little sensors put out a DC voltage proportional to pressure or a frequency? I haven't put a scope on it yet. ( Seems like the frequency would be more work for the controller to read). Thanks Rich 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
MrSeas Posted August 10, 2017 Report Share Posted August 10, 2017 On 5/2/2017 at 0:33 PM, MrSeas said: Are you singled? Check connections/ tone ring on right rear. Link to comment Share on other sites More sharing options...
Mastercraft Posted August 10, 2017 Report Share Posted August 10, 2017 Not singled. The tone ring.....it doesn't seem to be related to sensing load on the rear. But I'll have a look tomorrow. Are there additional connections in a harness at the back of the cable? 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
Mastercraft Posted August 14, 2017 Report Share Posted August 14, 2017 Update - I mentioned the rear air bag pressure on the display varies in a 3 or 4 psi window, going down the road. While sitting still, no variation. Did another visual inspection of the leveling valve link.....there is some play where it attaches to the axle. My plan is to eliminate the play, and give it another try on the road......before I get a new link. I guess the brake computer was right......the signal was erratic, but may have been caused by a mechanical issue. 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
Mastercraft Posted August 17, 2017 Report Share Posted August 17, 2017 Update II - Did a electrical tape fix to take the play out of the leveling valve end links, just until I get new ends. Now, going down the road, no variation on the bag psi. Observation - Going uphill, the bag pressure drops 2 or 3 psi, going downhill with engine brake active, bag pressure goes up 2 or 3 psi. Now, is this because the engine torque tends to raise the frame? So, my TCS light is still on and the diagnostic page for the brake ECU says the 136 69 2 fault is active. 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
Scrap Posted August 18, 2017 Report Share Posted August 18, 2017 There's two transducers on the treadle valve for brake demand and one on the rear air bags for load sense (on non-Volvo anyways). They are just a regular 3 wire air pressure transducer and should scope out just like all the rest. They have a calibration that ACOM does when they are first installed and sometimes they just need that, but it has the same fault code. Acom will find the trouble right away. ACOM is free, but the datalink adapter is not. We all had to get new USBLink 2 adapters in the last year so it's got to be a good time to find cheap old used Nexiq's out there somewhere, but I guess I've never looked. And yea, that is torque reaction from a trailing arm air suspension. Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted November 27, 2017 Report Share Posted November 27, 2017 On 8/14/2017 at 6:30 AM, Mastercraft said: Update - I mentioned the rear air bag pressure on the display varies in a 3 or 4 psi window, going down the road. While sitting still, no variation. Did another visual inspection of the leveling valve link.....there is some play where it attaches to the axle. My plan is to eliminate the play, and give it another try on the road......before I get a new link. I guess the brake computer was right......the signal was erratic, but may have been caused by a mechanical issue. I have a 2008 Volvo 780 and the computer is throwing the same code (MID 136 SID 69 FMI 2 ). I looked at my leveling valve link and the bottom end has about 1/8 to 1/4 inch play. The top end has about 1/8 inch play. I don't know if this is the problem . . . but it seems like the end joints should not be that loose. My next question is, what is involved in replacing the link. It would seem like there must be some adjustment to maintain the proper ride height for u-joint alignment. Thanks and I love this forum. I found this link by doing a goggle search on "MID 136 SID 69 FMI 2 " On edit, am I correct in guessing that I make the new link the same as the old link? Link to comment Share on other sites More sharing options...
Shifted Posted November 27, 2017 Report Share Posted November 27, 2017 This is how to set the ride height on a Volvo 770, which I would expect to be the same as a 780: The rear height adjustment is set by 5 holes in the beam under the air bags (there should be 2 on top, 1 in the middle, and 2 on the bottom). These holes are there for large adjustments. To fine tune the height, rotate the valve (remove the nut on the valve, rotate the attachment between the rod and valve, reinstall the nut). Don't bend the rod. The Volvo recommended method of measurement is: 1) Take a measure of the height of the tire (X) 2) Measure the distance from the ground to the bottom of frame (Y) 3) Subtract half of tire height (X/2) from the distance of the ground to the bottom of the frame (Y): Y - X/2 = Z 4) The result (Z) is the desired distance from the center of the drive axle (usually a welding line) to the bottom of the frame. 7.75" is a typical result. Proper height for the front drive axle on a tandem truck is usually 7.75 to 8 inches (from the weld seam in the middle of the drive axle to the bottom of the frame rail). Proper height for the rear drive axle on a tandem truck is usually 7.25 inches (from the bottom of the leveling valve bracket to the bottom of the bag itself where it curves into the bell). When you set the front drive axle height you set only the left/driver's side and then adjust the right side until the truck is level left to right. Adjust the height, drive in circles a couple of times and repeat until level. This only applies if you have dual leveling valves. If you only have one valve, then adjust it on the left/driver's side and the right side should level out by itself. Link to comment Share on other sites More sharing options...
VegasFlyer Posted November 28, 2017 Report Share Posted November 28, 2017 As discussed in another recent thread, the leveling link has been upgraded to a new, superior design that will completely eliminate the play and weak link of the leveling system for the rear suspension. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
RHeller1 Posted January 3, 2019 Author Report Share Posted January 3, 2019 My issue is now odd. If I am making a turn from a dead stop or under 20mph, the truck will have no throttle response until the steer wheels are close to straight again. I am thinking it has something to do with ESC, maybe thinking the rear end is sliding, when in actuality it is not. Once the steers are close to straight again, full power and all is well. No other codes besides MID136 SID69 FMI2. any help here is greatly appreciated. Link to comment Share on other sites More sharing options...
Lance A Lott Posted January 4, 2019 Report Share Posted January 4, 2019 15 hours ago, RHeller1 said: My issue is now odd. If I am making a turn from a dead stop or under 20mph, the truck will have no throttle response until the steer wheels are close to straight again. I am thinking it has something to do with ESC, maybe thinking the rear end is sliding, when in actuality it is not. Once the steers are close to straight again, full power and all is well. No other codes besides MID136 SID69 FMI2. any help here is greatly appreciated. Makes me wish my truck wasn't in winter storage. This sounds like what it does but I haven't driven it since September. When I singled it I put all four sensors in the one axle, two of the wires had to be fixed. The abs and traction lights go out when I first start the truck then come back on soon after. I have yet to determine the exact circumstance. Some times I have no throttle response and it may be during turns, backing up is really bad it feels like the clutch is not engaging and no throttle. The more I think about it the more I think it is in turns. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 4, 2019 Report Share Posted January 4, 2019 16 hours ago, RHeller1 said: My issue is now odd. If I am making a turn from a dead stop or under 20mph, the truck will have no throttle response until the steer wheels are close to straight again. I am thinking it has something to do with ESC, maybe thinking the rear end is sliding, when in actuality it is not. Once the steers are close to straight again, full power and all is well. No other codes besides MID136 SID69 FMI2. any help here is greatly appreciated. What have you checked in the last year? You've been given lots of good tips above, time to get greasy. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
DesertMiner Posted January 4, 2019 Report Share Posted January 4, 2019 Just a thought... ABS sensors are also used as the “sensor” for the “Traction Control” to detect slipping or sliding of a wheel position. How do you guys drive your trucks this way with questionable throttle response? Link to comment Share on other sites More sharing options...
RHeller1 Posted January 4, 2019 Author Report Share Posted January 4, 2019 Mine just started happening this week. No new codes or dash lights. My mid136 sid69 has been an active brake code since I bought the truck last year. Had no driveable issues till now. I have checked all wheel sensors or fitment, replaced the rear wire harness. I would assume a dash light would tell me if an abs sensor was dead...is there a way to ohm them? Link to comment Share on other sites More sharing options...
Lance A Lott Posted January 4, 2019 Report Share Posted January 4, 2019 Mines a 2012 VNM with the D 11 and I Shift. It was fine untill I singled it. It sat for a year after I drove IT home from Texas. It started to show a code for Nox sensors and abs traction control. I think the nox is from water in the stack. I thought the abs was from not havingn the second axle hooked up. I mounted the second set of sensors in the drive axle as well two of the wires were damaged and I repaired them. I got the truck ready to go 2 days before we left for vacation. I put 600 miles on it and learned a few things to mediate the problem. It goes better with the trailer airr charged. I will be working on it again this summer. It is not fun to drive this way. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 4, 2019 Report Share Posted January 4, 2019 4 hours ago, RHeller1 said: Mine just started happening this week. No new codes or dash lights. My mid136 sid69 has been an active brake code since I bought the truck last year. Had no driveable issues till now. I have checked all wheel sensors or fitment, replaced the rear wire harness. I would assume a dash light would tell me if an abs sensor was dead...is there a way to ohm them? Sensors will generate an AC voltage when they "see" the tone ring moving past their surface. If they're removed from the mount, run a piece of steel past the tip, while a meter is clipped to the leads. I typically use a screwdriver. A cordless drill can also work, placing the tip over the motor, not the chuck. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
