rbertalotto Posted February 18, 2023 Report Share Posted February 18, 2023 Anyone convert from grease axle to oil bath? If so, how has it worked out? Any comments negative or positive? Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
rickeieio Posted February 18, 2023 Report Share Posted February 18, 2023 Just shooting from the hip here..... My thought is that unless you have a very heavy trailer and heavy axles (8K or higher), why bother? Checking them regularly is good practice whether oil or grease, and is much easier with grease. Our trailer is 15 years old, and has quite a few miles on it, with original bearings. It's 21k loaded, on three axles. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rbertalotto Posted February 18, 2023 Author Report Share Posted February 18, 2023 Quote why bother? It just seems like a better solution. Rule of thumb in engineering school was...If it slides=grease / if it rolls=oil..... Much easier maintenance. And if all the big trucks are doing it, it must be better? Looking at the various reviews it seems like 95% love it and those that don't it appears they didn't install the rear seal properly and they leaked. I just respect the opinions of this group and wanted to see who has used them and comments. Thanks! Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 18, 2023 Report Share Posted February 18, 2023 We have trailers with greased bearings, and with oil bath. Each was bought as is, and each works fine for the application. Never looked into changing one for the other, but I suspect we'd just swap out the whole axle. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Ray,IN Posted February 18, 2023 Report Share Posted February 18, 2023 4 hours ago, Darryl&Rita said: We have trailers with greased bearings, and with oil bath. Each was bought as is, and each works fine for the application. Never looked into changing one for the other, but I suspect we'd just swap out the whole axle. I completely agree, and a swap would likely be cheaper in the long run than buying all the parts to do a conversion. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rbertalotto Posted February 18, 2023 Author Report Share Posted February 18, 2023 Quote and a swap would likely be cheaper in the long run than buying all the parts to do a conversion. The conversion kit is $75 per axle...... Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
Ray,IN Posted February 20, 2023 Report Share Posted February 20, 2023 (edited) It's either buy the cheapie conversion kits(I didn't even know such an item was made) or the real OEM oil-bath hubs: https://www.etrailer.com/dept-pg-Trailer_Hubs_and_Drums-pt-Oil_Bath-pc-For_6000_lbs_Axles.aspx Quite a price difference. Edited February 20, 2023 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rbertalotto Posted February 20, 2023 Author Report Share Posted February 20, 2023 2 hours ago, Ray,IN said: It's either buy the cheapie conversion kits(I didn't even know such an item was made) or the real OEM oil-bath hubs: https://www.etrailer.com/dept-pg-Trailer_Hubs_and_Drums-pt-Oil_Bath-pc-For_6000_lbs_Axles.aspx Quite a price difference. Do you know if there is an actusl difference in hubs and bearings? Are there special bearings and hubs specifically for oil? Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
Jaydrvr Posted February 20, 2023 Report Share Posted February 20, 2023 (edited) 43 minutes ago, rbertalotto said: Do you know if there is an actusl difference in hubs and bearings? Are there special bearings and hubs specifically for oil? I've never heard of such a thing. New wheel seal, new cap, you're good. Just don't use a Stemco. You don't even necessarily need to remove the grease. Jay Edited February 20, 2023 by Jaydrvr Quote Link to comment Share on other sites More sharing options...
Second Chance Posted February 20, 2023 Report Share Posted February 20, 2023 We have the MORryde independent suspension with disc brakes. When the naval engineer across from us in the RV park (on a military installation) saw my hubs he exclaimed, "You're set up for oil bath. You should convert them!" I called MORryde and had a 15 minute conversation with them. They recommended against it and listed several reasons (which I don't recall with complete accuracy since this was about three years ago). Since then, I've seen a number of discussions on various forums about this topic with opinions split. Since I already have a maintenance routine that's been working well, I took the path of least resistance (no pun intended) and left the hubs as they are - grease. Rob Quote 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
Kirk W Posted February 20, 2023 Report Share Posted February 20, 2023 4 hours ago, Second Chance said: I took the path of least resistance (no pun intended) and left the hubs as they are - grease. I have done as you have but part of the reason is also that I'm pretty cheap! 😉 Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted February 22, 2023 Report Share Posted February 22, 2023 Standard greaseable bearing hubs have a rather large cavity between the bearings. Oil bath hubs don't normally have that large cavity, otherwise you'd never completely change the oil, it would just run to the lowest point in the cavity and never get changed. Trailer oil bath hubs usually take about 3-4oz. oil each as a result. reference for 7,000# trailer axles: https://www.etrailer.com/Lubricants-Sealants-Adhesives/Kodiak/XLPROLUBE.html Which is better? Owners choice iMO. Grease is a heavy oil in a thickener base to keep it from running to the low side of bearings during long term storage. Its downside is more heat retention vs hub oil. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted February 22, 2023 Report Share Posted February 22, 2023 My fiver can with Dexter 7000# Never-Lube bearings. Part of the upgrade to disc brakes included switching to Dexter #8000 axles with oil bath. I can't tell whether they are any better than other hubs, but I haven't had any problems in five years. Wayne Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 22, 2023 Report Share Posted February 22, 2023 On 2/18/2023 at 9:16 AM, rbertalotto said: Rule of thumb in engineering school was...If it slides=grease / if it rolls=oil.... Your engineering Rule of Thumb is flawed, too. Engine main bearings definitely slide, yet they're oil lubed. Crawler tractor bearings run on grease. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rbertalotto Posted February 22, 2023 Author Report Share Posted February 22, 2023 Quote Your engineering Rule of Thumb is flawed, too. Engine main bearings definitely slide, yet they're oil lubed. Crawler tractor bearings run on grease. Not MY rule of thumb......Been a rule for ages.... And, engine bearings "slide"???......As far as tractor bearings (and wheel bearings) some engineering designs have it all wrong......OR....There are exceptions to every rule.....😁 Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
jenandjon Posted February 24, 2023 Report Share Posted February 24, 2023 I would rather have oil bath because changing a little oil is easier than repacking bearings all the time. I have a friend that converted his oil bath to grease on his camper because that is what he wanted. Most semi-trailer have oil hubs. Except for my brand-new semi-trailer came with grease hubs. I guess because of the disc brakes. I know I'm comparing apples to oranges here, but I suppose it boils down to personal preference. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
rickeieio Posted February 24, 2023 Report Share Posted February 24, 2023 Not directly an answer to the original question, but.... it's crazy how little lube is needed for roller bearings. Look at the drive axle(s) on a truck. There's perhaps a tablespoon or two of oil in the well at each bearing, and that oil only get occasionally sloshed to and fro with the differential oil. Greaseable bearings also need very little lube. That big cavity in the middle is for air expansion as the bearing warms, not to act as a reservoir. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rbertalotto Posted February 24, 2023 Author Report Share Posted February 24, 2023 It seems everyone I talk to that puts reasonable miles on their trailer have had a "Wheel Bearing" issue. I pull a 20' toy hauler and never haul toys with it. I'm way under rated weight wise for my hubs. Yet I've had two wheel bearing failures and the trailer has about 50K miles on it. I repack the bearing religiously every two years or 10,000 miles on a repack......Yet I still experienced failures...As have so many more long distance haulers......(and some that don't tow long distances at all) BUT!!!....How come in over 50 years of driving cars and trucks, and I've never owned a car that didn't go over 180,000 miles, (I was an on the road consultant, trainer) I've NEVER serviced a vehicles front wheel bearings (or rear bearings for that matter)....I've had a number of cars go over 250K miles!...And asking around, I've not met anyone that had either. Interesting...... Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 24, 2023 Report Share Posted February 24, 2023 The reason car/truck wheel bearings go so much further than trailer wheel bearings comes down to one thing: Unit bearings. They're faster to install on the production line, never need adjustment or lube, and aren't subject to the vagaries of a mechanics touch. If you've had that many failures with that service routine, you're the problem. Either adjusted too tight, or too loose. Something in your procedure is flawed. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
mike5511 Posted February 25, 2023 Report Share Posted February 25, 2023 I've got 9000 lbs Dexter axles with oil bath hubs that were grease filled from the factory. I called Dexter about switching to the oil bath. Their advice was that if my trailer sat a lot, like most RV trailers, the grease was better. Why? The oil will drain down over time and the bearing will dry out and possibly even rust. That won't happen with grease. Makes sense, and Dexter should know. Thus, when I put new Timken bearings in, I went back with Mobil 1 grease. My hubs don't leak, so I know the grease is still in there. (plus I did pull a cap and looked) Haven't messed with them since I did that 3 years ago. Quote Link to comment Share on other sites More sharing options...
lappir Posted February 25, 2023 Report Share Posted February 25, 2023 9 hours ago, mike5511 said: I've got 9000 lbs Dexter axles with oil bath hubs that were grease filled from the factory. I called Dexter about switching to the oil bath. Their advice was that if my trailer sat a lot, like most RV trailers, the grease was better. Why? The oil will drain down over time and the bearing will dry out and possibly even rust. That won't happen with grease. Makes sense, and Dexter should know. Thus, when I put new Timken bearings in, I went back with Mobil 1 grease. My hubs don't leak, so I know the grease is still in there. (plus I did pull a cap and looked) Haven't messed with them since I did that 3 years ago. That's a good thought. When do you expect to repack them? Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
rbertalotto Posted February 25, 2023 Author Report Share Posted February 25, 2023 “Their advice was that if my trailer sat a lot, likemost RV trailers, the grease was better. Why? The oil willdrain down over time and the bearing will dry out and possiblyeven rust. ” Not a real issue. Modern oils have a great ability to cling. If not, all engines that dont get used much would have everything above the oil pan rusting. Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
rickeieio Posted February 25, 2023 Report Share Posted February 25, 2023 In the 8 years and roughly 40k miles we've had our 21k# toyhauler, I've adjusted one bearing, and repacked none. All were done a couple months ago, and the mechanic said all bearings were in great shape with the grease a little dirty in just one. BTW, three 8k Dexter using grease. Agree with Darryl above. If you service the bearings and get one a little too tight, it matters not whether you have oil or grease, it's going to fail. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rbertalotto Posted February 25, 2023 Author Report Share Posted February 25, 2023 8 hours ago, rickeieio said: In the 8 years and roughly 40k miles we've had our 21k# toyhauler, I've adjusted one bearing, and repacked none. All were done a couple months ago, and the mechanic said all bearings were in great shape with the grease a little dirty in just one. BTW, three 8k Dexter using grease. Agree with Darryl above. If you service the bearings and get one a little too tight, it matters not whether you have oil or grease, it's going to fail. Quick….go buy a lottery ticket! You have amazing luck!😁 Quote RoyB South of Boston 2021 Dodge 2500 - 6.4L Forest River 19RR Toy Hauler Roofnest Falcon Rooftop Tent www.rvbprecision.com Link to comment Share on other sites More sharing options...
lappir Posted February 25, 2023 Report Share Posted February 25, 2023 My oil bath trailer axles have been sitting for about 5 months. I raised the tires off the ground today and gave all the wheels a spin to put a little oil on them before heading out next week. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
