Wrknrvr Posted August 29, 2022 Report Share Posted August 29, 2022 First of all this is for a RV repair. So what could this part represent in a RV problem. It took me some thinking to come up with this idea. Can someone solve this question. In two days I will give another clue as to what this is for. Quote Link to comment Share on other sites More sharing options...
Chalkie Posted August 29, 2022 Report Share Posted August 29, 2022 I would guess it is a bushing and the slot is to allow lubricant to the full length. What specifically it might be for I have no idea. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 29, 2022 Report Share Posted August 29, 2022 Looks like a homemade shim of some sort, perhaps to correct a worn bushing or shaft. With nothing to indicate the relative size, it's difficult to come up with a specific application though. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 29, 2022 Report Share Posted August 29, 2022 Hmm , shim for a door hinge . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 29, 2022 Report Share Posted August 29, 2022 Replacement door hinge bushing, for a Jeep. Replaces the almost disposable plastic bushing. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rickeieio Posted August 29, 2022 Report Share Posted August 29, 2022 (edited) Or perhaps a plug. He split it nearly to the end, but a little dab of rtv will do ya. Edit: Two things. He's not shown us if the primer is still in place, or perhaps threaded. And while he said it's for RV repair, and a jeep isn't generally considered and RV, I believe it is sitting on the jeep hood. Edited August 29, 2022 by rickeieio Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
VC 23RSS Posted August 29, 2022 Report Share Posted August 29, 2022 Used to clean out plugged drain holes? Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 29, 2022 Author Report Share Posted August 29, 2022 Well it is sitting on a Jeep hood. But it is for a Rv. But again it could be used for a old farm tractor. Or for the Jeep it is sitting on. But this started as a serious project on a RV. Thinking out of the box for the fix it is for. Vern Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 29, 2022 Report Share Posted August 29, 2022 The problem is that you will never be able to reload that case again. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 29, 2022 Author Report Share Posted August 29, 2022 That depends Quote Link to comment Share on other sites More sharing options...
franco-bolli Posted August 29, 2022 Report Share Posted August 29, 2022 I'm thinking either it was too small indiameter as a sleeve on the outside of a shaft and had to be sliced to remove it OR its too big in diameter and the slice will reduce the diameter just a little when pressed into place. Dimensions of what is shown would tell another part of the story. Quote +++++++++++_____________________________________+++++++++++ 2021 Ram 3500 2017 Arctic Fox 25W(to be traded??) HAM guy (Ke7FIX), photography, woodworking (mostly sawdust), Electronics Technician, USAF DAV Going where everyone has gone before Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 29, 2022 Author Report Share Posted August 29, 2022 Well this piece of brass is a 45-70 cartridge case. Without the primer. But it is involved in a RV repair. Like i said, thinking out of the box. I have been known to do that a lot. Some may even think I am not all there. I will say the answers so far are very interesting. So now you know the dimensions, 2.1 “ long, .460” in diameter. Since it is a tapered cartridge. Now that throws a wrench into the thinking. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 30, 2022 Author Report Share Posted August 30, 2022 (edited) Edited August 30, 2022 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 30, 2022 Author Report Share Posted August 30, 2022 Now just what the heck could this be used for in a RV repair. And no,I am not tying to fool you. Just saying sometimes a person needs to think out of normal range of mechanical thinking. Quote Link to comment Share on other sites More sharing options...
durangodon Posted August 30, 2022 Report Share Posted August 30, 2022 I spent my whole career thinking outside the box to find solutions for unusual problems on the fly and in a matter of minutes. However, you're not giving us a problem to solve. You're giving us a solution to some problem that you had and asking us to figure out what the problem was. If you're going to play riddles, you could at least narrow it down to a category, like mechanical, appliance, structural, etc. 🙂 Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 30, 2022 Author Report Share Posted August 30, 2022 (edited) it contains antifreeze Edited August 30, 2022 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 31, 2022 Author Report Share Posted August 31, 2022 The problem is not solved yet. The RV will back in my area to fix this problem next week. That is if I can. This problem may need the use of a remote camera to accomplish this repair. The conventional way to fix this problem would require two days labor to fix it. Maybe a few hours extra. So I am figuring out how to fix it in two hours or less. That will include no swearing. I hope. Quote Link to comment Share on other sites More sharing options...
ms60ocb Posted August 31, 2022 Report Share Posted August 31, 2022 (edited) I was thinking a faucet repair until I saw solder. The water system don't have copper. After you last hint even your A/C system and Propane could be ruled out Makes me think you an electrical terminal problem. But anti-freeze? The misery is what would take 2 days versus 2 hours? Clay Edited August 31, 2022 by ms60ocb Quote Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
gjhunter01 Posted August 31, 2022 Report Share Posted August 31, 2022 Show us what the problem is first, then we can help identify solutions. There is alot of expertise here that may help you solve this repair, if help is what you are looking for? Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 31, 2022 Author Report Share Posted August 31, 2022 Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 31, 2022 Author Report Share Posted August 31, 2022 The picture above is the subject unit I need to work on. It is a Aquahot 100-02S heating unit. If you look on the top, center of this unit there is a radiator cap. Just like on a old tractor, truck or Jeep. The problem is the radiator filler neck has a vertical crack in it. What most likely caused the crack was someone had to shorten the hose that goes from the filler neck to the overflow tank. The end of that hose can deteriorate, leak fluid and eventually shut the unit off. That person apparently did not like the spring clamp that was there from new. So that person put a screw type conventional hose clamp on it. But the screw area on the hose clamp was up high enough that when installing the radiator cap it apparently forced the cap to one side. Enough that it formed a vertical crack in the neck of the filler neck. Through the years of working on Aquahot unit that have caps I mostly see the filler neck bent from that screw type clamp installation. They can leak fluid from the bent area not sealing to the cap. Being careful the bent area can be straightened out. One time the cap hit the clamp on hose as in this unit and busted the drain hose nipple off the filler neck. Fun job to reach in there and solder the nipple back on the neck. But it did work. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 31, 2022 Author Report Share Posted August 31, 2022 If the filler neck needs replaced the whole unit need to be removed. That normal requires the exhaust pipe be disconnected. Electrical wires to each fan at the heat exchangers, 110 vac wire, all hydronic heat and return lines need to be disconnected. Also water pump, water filters and exterior door, gas struts and strut mounting brackets removed. And misc. stuff needs removed. Remove antifreeze from unit. Pull unit out, remove stainless steel covering. Then replace that cracked neck. Then reverse that process. After you have unit installed, then pump the antifreeze back in. Once you drain the fluid out of the unit. The heating loops may need primed with antifreeze. Might as well ad that into your time. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 31, 2022 Author Report Share Posted August 31, 2022 So my thought was to just solder it. Now if this was on in old tractor, truck or Jeep. Just solder a new one in place. But as I described above that would involve a lot of time. I have removed these units before. So if one does this, take lots of pictures and notes. I was thinking if I had two thin pieces of brass that I could clean for soldering. Clamp them next to each other. Then try soldering in a vertical position. Heck just hacksaw a slot in a cartridge case. And I have one. So now I have the brass clamped down. Just like the radiator cap will be tight. Now in real life situation on this job there is maybe 8” of clearance above the cap. And the unit is in the middle on the bay. There is access to the side of the unit. I do have a remote camera I am planning on having it laying on top of the Aquahot unit, showing the far side. Positioned back out of the way. But that I can see the other side. Also no torch to be used in bay area. Too much uncontrollable heat. And flame. In the picture of my solder job. You can see I fluxed, then tined the brass. I will need to clean the crack itself. Either physically or with acid cleaner. Then sand the interior and exterior of the neck. Flux and tin the crack area. I did notice my practice soldering did not get on the other side of the brass. The thicker base was hard to solder with the soldering iron I was using. Until the thin area was being soldered. Then it went good. I plan on using silver solder for this job. So now I will have the vertical crack soldered. Now to solder the top flange. Probably need to use a smaller heat range of soldering iron for that. I hope to get pictures of the job before and after work is done. So in my practice piece you can see the bottom of the cartridge case did not solder easy. Bottom of cartridge case is thicker than the upper portion of the case. But that gives me confidence as the filler neck should soldered to the tank. It would take a lot of heat to affect that part of the joint. At least I hope. This job may take place on Monday am, as the customer is traveling back this way and will be in a rv park until I get the situation solved. I will try my best to repair it this way. Epoxies have been considered. Any comments for helping me on this job would be appreciated. Vern Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 31, 2022 Report Share Posted August 31, 2022 I shuddered at the pic of the AquaHot. Been there, done that. They do pay good money for the yearly service, though. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Trainer Posted August 31, 2022 Report Share Posted August 31, 2022 Sent you a message. Trainer Quote Link to comment Share on other sites More sharing options...
