bigredhdt Posted August 15, 2020 Report Share Posted August 15, 2020 The hood on my vnl cracked around the hinge point. Can this be repaired or do I need to replace it? Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 16, 2020 Report Share Posted August 16, 2020 Someone good with fiberglass repair should be able to fix it. Even a boat shop or regular body shop should be able to fix it. Hope this helps, Vern Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 16, 2020 Report Share Posted August 16, 2020 If you go to the HHRV site here http://www.hhrvresource.com/search/node/hood hinge repair You should be able to see how others have done this repair. Quote Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Jaydrvr Posted August 16, 2020 Report Share Posted August 16, 2020 (edited) Where are you located? If you're east of the Mississippi, these guys are really good. Jay http://www.mickeybody.com/locations/ Edited August 17, 2020 by Jaydrvr Quote Link to comment Share on other sites More sharing options...
solo318 Posted August 17, 2020 Report Share Posted August 17, 2020 replace it. it WILL crack again. Mine has been fixed on both hinges and cracked again on both sides. the replacement hoods are 1 piece instead of 3. they hold up better. Quote Click For Full-Size Image. Link to comment Share on other sites More sharing options...
bigredhdt Posted August 18, 2020 Author Report Share Posted August 18, 2020 Are you talking about an aftermarket hood? If so, what kind? Quote Link to comment Share on other sites More sharing options...
JPL Posted August 21, 2020 Report Share Posted August 21, 2020 Big That can be repaired with plenty of glass mat over some 16 gage steel or alum. Use West system Epoxy. I've fixed a couple on working trucks and they do take a beating but they are still ticking. The secret is a lot of glass and wrap it tight and use plenty of metal to give it strength. Pat The Old Sailor Quote Link to comment Share on other sites More sharing options...
hone eagle Posted August 21, 2020 Report Share Posted August 21, 2020 once it is fixed -stop letting it slam to close/lock- lower it slowly and walk around and click it shut right to left. fibreglas is infinitely repairable but why do it constantly Quote 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
GlennWest Posted August 21, 2020 Report Share Posted August 21, 2020 Interesting, don't believe it is possible to slam my Freightshaker hood. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Nigel Posted August 21, 2020 Report Share Posted August 21, 2020 35 minutes ago, GlennWest said: Interesting, don't believe it is possible to slam my Freightshaker hood. Same with the Volvo if the hood struts are good. Quote 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
hone eagle Posted August 21, 2020 Report Share Posted August 21, 2020 my struts are new and if you push it and let gravity take over it will slam shut and lock,I lower mine never letting go and slowly lower it to contact -it will not lock however . I then walk from side to side and with the palm of my hand push and click/latch it .the small cracks at the hinges have never increased in size in the 8 years of ownership. Quote 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
