JimSurfs Posted July 26, 2020 Report Share Posted July 26, 2020 Does anyone recommend the Washer and Dryer options provide in Class C Coaches? Quote Link to comment Share on other sites More sharing options...
sandsys Posted July 26, 2020 Report Share Posted July 26, 2020 It depends a lot on your vehicle's carry capacity and the size of your tanks. And your tolerance for laundromats. Linda Sand Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Second Chance Posted July 26, 2020 Report Share Posted July 26, 2020 Use the search function on this and other forums (and on Google) and do a lot of reading. In my opinion, it boils down to available space versus functionality. Here are some of the trade-offs: Combo washer/dryer (single unit), nonvented: smallest drum (smallest loads), takes the longest to complete a cycle (especially nonvented), and you can't start the next load of wash while the previous one is drying. Separate washer/dryer: take the most space (which you may not have in a class C), but have the larger drum capacities. Can dry one load while another is washing. A separate, vented dryer dries clothing the fastest. Fresh water and gray tank capacity doesn't really matter if you're in a site with hookups. Personally, our tolerance for laundromats during the pandemic is zero. We used to use them all the time but installed a washer and dryer when the pandemic hit. Rob Quote 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
docj Posted July 26, 2020 Report Share Posted July 26, 2020 10 minutes ago, Second Chance said: Combo washer/dryer (single unit), nonvented: smallest drum (smallest loads), takes the longest to complete a cycle (especially nonvented), and you can't start the next load of wash while the previous one is drying. People continually act as if having separate washers and dryers makes for a big improvement in how long it takes to do a couple of loads of wash. In fact, having separate units results in a ~one hour reduction in the length of time it takes to do two loads of wash (out of a six hour wash/dry cycle.) If you have two loads to wash, having separate units means that the second wash can get started when the first wash is finished. For argument sake, let's assume washes take one hour and dry cycles take two hours. So at the end of the first hour the first load of clothes goes into the dryer and the second load of clothes goes into the washer. At the end of the second hour the second load of clothes has finished washing but the first load is still drying. At the end of the third hour the first load of wash will have finished drying and the second load can then be dried for two more hours. Total elapsed time 5 hours. With a combo the total elapsed time would be roughly 2 times the 3 hour wash/dry cycle = 6 hours. For us that one hour saving wouldn't balance out the loss of the huge storage pantry we have in the space above the combo. Yes, we could fit separate units in the space but we wouldn't want to lose the storage. Furthermore, we typically wash single loads when we have them and rarely have two loads of clothes to wash at one time. For us, the beauty of having our own washer/dryer is that we don't have to accumulate dirty clothes to wash. JMO Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Kirk W Posted July 26, 2020 Report Share Posted July 26, 2020 If you are looking at adding an washer/dryer to a class C that you already own, then this may be the only option, but if you are still shopping for an RV, they why not look at class A rigs as well? I have driven both and find the class A less difficult, once you get by the mental feeling of size and the cost is not significantly different. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
edatlanta Posted July 26, 2020 Report Share Posted July 26, 2020 I have a Splendide 2100XC and have been using it full time for 10 years. My rig has a hamper built in that I use for white items and I use the Splendide for colors. Since colors for me build up faster than whites when I have a load in the Splendide I run it. Then run the whites when I have a load. Easy. Quote Ed KM4STL2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch2010 Jayco Designer 35RLTS, RV Flex Armor Roof Link to comment Share on other sites More sharing options...
JimSurfs Posted July 26, 2020 Author Report Share Posted July 26, 2020 Appreciate reply. Does the washer and dryer combo require a high amp rating or is 30amps okay? Quote Link to comment Share on other sites More sharing options...
GlennWest Posted July 26, 2020 Report Share Posted July 26, 2020 If you can fit a stacked unit , I would use a waher/gas dryer combo. It will dry clothes faster and if you end up on solar, less power to operate. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Bill Joyce Posted July 26, 2020 Report Share Posted July 26, 2020 The Splendide 2100XC, a vented combo washer/dryer, uses about 12AMPs while drying and around 6AMPs while washing. Those were the numbers I measured with my meter. Quote 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
GlennWest Posted July 26, 2020 Report Share Posted July 26, 2020 1 minute ago, Bill Joyce said: The Splendide 2100XC, a vented combo washer/dryer, uses about 12AMPs while drying and around 6AMPs while washing. Those were the numbers I measured with my meter. and 12 amps is 1400 watts Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
remoandiris Posted July 26, 2020 Report Share Posted July 26, 2020 My wife would not be without our 2100XC. We have friends who sold their 2100XC. It completely boils down to personal preference. Quote Link to comment Share on other sites More sharing options...
TXiceman Posted July 26, 2020 Report Share Posted July 26, 2020 16 hours ago, docj said: People continually act as if having separate washers and dryers makes for a big improvement in how long it takes to do a couple of loads of wash. In fact, having separate units results in a ~one hour reduction in the length of time it takes to do two loads of wash (out of a six hour wash/dry cycle.) . JMO What is the magic of taking less time to wash and dry. We are retired and have all the time we need to waste. But with the combo unit, we can put in a load of dry and dirty laundry and take off ...come back later and the load is dry and clean. No one has to be around to swap from the washer to the drier. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Twotoes Posted July 26, 2020 Report Share Posted July 26, 2020 docj, my washer takes between 15 min to 1 1/2 hours to wash depending on what I set it at. I usually use 55 min. My dryer takes about 1 hour. When the wash is done I put it in the dryer. An hour later it is dry. Sometimes I start a second wash. When the second wash is done the first load in the dryer is done and I put the second load of wash in the dryer. A hour later the second load is dry. So it takes me only 3 hours total to do two loads. Not 5 or 6 hours. I highly recommend the stackable units over the combo unit. The only advantage of the combo unit is if you start a load and leave for the day it will be dry when you get back. No one has to be there to transfer the wash to the dryer. But that only works for one load. I usually start a load at dinner time. By the time I am done eating I can start a second load. Before I go to bed I put the second load in the dryer and fold the first load that is now dry. When I wake up in the morning the second load is dry and gets folded. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
Lou Schneider Posted July 27, 2020 Report Share Posted July 27, 2020 (edited) 10 hours ago, GlennWest said: If you can fit a stacked unit , I would use a waher/gas dryer combo. It will dry clothes faster and if you end up on solar, less power to operate. I'm surprised there aren't more gas dryers in RVs. Not only for boondocking but because a gas dryer has 10-15 times more heat than a 120 volt electric dryer so it dries clothes much faster. A gas dryer uses about 22,000 btu or 1/4 gallon of propane per hour of drying time and dries full loads in 30 - 45 minutes. About the same amount of propane as running an RV furnace for the same amount of time. Meanwhile, it's only using enough electricity to spin the drum and blow the hot air through the clothes. Maybe 100 watts. Edited July 27, 2020 by Lou Schneider Quote Link to comment Share on other sites More sharing options...
docj Posted July 27, 2020 Report Share Posted July 27, 2020 (edited) 5 hours ago, Twotoes said: docj, my washer takes between 15 min to 1 1/2 hours to wash depending on what I set it at. I usually use 55 min. My dryer takes about 1 hour. When the wash is done I put it in the dryer. An hour later it is dry. You can barely dry a load of clothes in an hour with a 240V residential dryer, let alone one in an RV running on 120V. Is your dryer propane fired? Or do you have it wired for 240V? Edited July 27, 2020 by docj Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
GlennWest Posted July 27, 2020 Report Share Posted July 27, 2020 (edited) 28 minutes ago, docj said: You can barely dry a load of clothes in an hour with a 240V residential dryer, let alone one in an RV running on 120V. Is your dryer propane fired? Or do you have it wired for 240V? A residential dryer holds a lot more clothes also. So drying time would be similar. Since we got the front loader washer with the high speed spin out, our drying times are way down. Clothes are not as wet. Edited July 27, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Twotoes Posted July 28, 2020 Report Share Posted July 28, 2020 docj, I have an all electric Class A. No propane at all. My dryer is done in about an hour. It is a small load so that may be why it is so quick. I set my washer to 50 min and the drying of the first load is done just after the washer and the wet clothes (second wash load) goes right into the dryer. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
WileyOhio Posted August 15, 2020 Report Share Posted August 15, 2020 I just had an experience with our Splendide 2100XC. Despite the Surge Guard, an electrical storm whacked it. The Splendide techs walked me through troubleshooting,even sending an email illustration. Found the problem and they sent the part the next day. I am pleased with that result, and DW is happy, too! Quote Link to comment Share on other sites More sharing options...
