Little Posted February 14, 2018 Author Report Share Posted February 14, 2018 Thanks to all for the 'guessing'. Swapped in a throttle pedal assembly from a welding supply truck, and all was well. Put the assembly back in the 'donor' truck and ordered a new one from Vanguard. Supposed to be in tomorrow. That should take care of this problem. I should add that new batteries and clean connections caused the problem to be less frequent, but the pedal swap caused problems to disappear. Thanks to all. Mark 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
NoDirectionHome Posted February 15, 2018 Report Share Posted February 15, 2018 I know you wanted an original part but... https://www.amazon.com/Converter-Regulator-Adapter-Vehicle-DC9-20V/dp/B01EFUHGMU/ref=sr_1_1?ie=UTF8&qid=1518721129&sr=8-1&keywords=12vdc+to+24vdc+converter "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
Little Posted April 21, 2018 Author Report Share Posted April 21, 2018 Some more info about this. Had the SM code pop up leaving home. Took to Vangard (Volvo) they dicked with it for 4 hr. No clue. Was driveable and they weren't real interested. Took it to Northwest Equipment in Twin Falls and they were great. Turns out the brake switch under the plastic dash panels was loose. These guys have a give a sh!t factor. On the road again with everything working. Best experience with a truck shop in a long time. 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
lockmup68 Posted April 22, 2018 Report Share Posted April 22, 2018 Phil, when you had yours towed, did it just die and stuck in gear? I was cruising along fine, went to stop and truck stalled out. Trans did not clutch in at stop. No lights on shifter at all or display. So can’t start truck since it can’t see neutral. Can’t roll forward as it is in gear. I’m thinking it is the power module. Thoughts? 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Big5er Posted April 22, 2018 Report Share Posted April 22, 2018 In the end that is what mine did....took many cycles of the key before it "woke up" and let me limp back to the campground. I had it towed from there. Before that it would act up on occasion but wouldn't last long. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
lockmup68 Posted April 22, 2018 Report Share Posted April 22, 2018 Luckily, it died right in front of my trailer at the rally. We are thinking it is the power converter since no power to the cobra head and nothing is happening. I’ll be at the shop first thing in morn. Hope their computer verifies. Of course it happened before I backed in to the site, blocking my neighbors. Big thanks to Mr. David, Pat, and Ross who came over to help out and try to diagnose. And big thanks to Mr Tommy who got my ABS light to go off so it would auto shift after a year. I had forgotten what it was like to just drive. and thanks to Mr Phil, I have the $466 converter ready to order if that is what is dead. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
noteven Posted April 22, 2018 Report Share Posted April 22, 2018 Tennessee Towing runs a sweet Loovill ! I'll take my 250 points for spotting that, thank you. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
lockmup68 Posted April 22, 2018 Report Share Posted April 22, 2018 3 hours ago, noteven said: Tennessee Towing runs a sweet Loovill ! I'll take my 250 points for spotting that, thank you. My google-fu is failing me. What is a loovil? 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 22, 2018 Report Share Posted April 22, 2018 Ford Louisville truck. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted April 22, 2018 Report Share Posted April 22, 2018 Wish we could have gotten you moving but sometimes, the big flashing truck needs to be called. Let us know how it comes out. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
lockmup68 Posted April 22, 2018 Report Share Posted April 22, 2018 19 minutes ago, GeorgiaHybrid said: Wish we could have gotten you moving but sometimes, the big flashing truck needs to be called. Let us know how it comes out. Will do. I'll be there first thing in morn. Appreciate your help. Shannon 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Little Posted April 22, 2018 Author Report Share Posted April 22, 2018 Thats what happened to us in Jackpot NV. Wouldn't shift down and died in Cactus Pete's parking lot. Batteries were bad. They were new from Vangard. Turns out one battery was shorted internally. No codes no nothing. Took the batteries from RV and got it running by jumping starter posts. Drove to Twin Falls with the SM showing on the monitor. Over 100 codes in the computer. We are in Cranbrook B.C. now with no issues. One needs everything working in MT., especially over Lolo We came the 93 all the way from Las Vegas. Cruise hasn't worked since we got the 780, but works now. Total cost for batteries, starter,and diagnostics was under $1400. 8 hr in the shop, Like a different truck with everything working. 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
porky69 Posted April 23, 2018 Report Share Posted April 23, 2018 That tow truck is no regular Louisville..... that is a Ford LTL9000.... it is to Ford what a 379 is to Peterbilt, the big hood classic....... https://goo.gl/images/12QxHy Link to comment Share on other sites More sharing options...
lockmup68 Posted April 23, 2018 Report Share Posted April 23, 2018 I found the diagnostic manual online and printed it out. Handed it to the service manager and I even marked the electrical diagnostic pages so they didn't have to flip through 100 pages to get there. If I would have found this before the tow truck came, I think we could have diagnosed. Mr. Al's truck got in ahead of mine. Hopefully they get mine in and diagnosed today so we can get stuff ordered if needed. Shannon 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted April 23, 2018 Report Share Posted April 23, 2018 Should have known you were holding out. All of you Nashville types are alike, picking and grinning when you should be flipping and reading. Hope they get you in and the problem figured out soon. David 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Big5er Posted April 23, 2018 Report Share Posted April 23, 2018 Hope they get it figured out quickly.....and inexpensively. Doesn't it just suck watching your baby getting towed?? MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
lockmup68 Posted April 24, 2018 Report Share Posted April 24, 2018 BTW, here is the link to the full maintenance and diagnostic manual for the freedomline trans. It is 292 pages, so if you print it out, do double-sided. https://www.zf.com/usa_canada/media/zfmig_united_states/zfmig_corporate_replacement_parts_1/zfmig_service_portfolio/zfmig_class8/mm0150.pdf 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
lockmup68 Posted April 24, 2018 Report Share Posted April 24, 2018 just back from the shop. He was grateful that I provided the diagnostic manual to him as he has never seen a freedomline trans before. I even had the troubleshooting section for the doubler marked so he didn't have to page through 100 pages to find it. The 30 amp fuse to the trans that is supposedly on the battery bank (according to manual), in my case, is in the engine bay, right by the steering shaft. The fuse was blown. Replaced and it immediately blew again. Unplugged the voltage doubler, replaced the fuse, and all was well (at lease shift tower lit up). Plugged in voltage doubler and it immediately blew again. Doubler also smells burnt. So ordered a new one via Phil's link. (Thanks Phil.) Will be here tomorrow. Good news is since I had a windshield leak, I cut out the entire center section of the carpet as it was moldy and have not put in a new carpet kit yet, so it was easy to get to the tunnel cover. He was grateful he didn't have to take the entire front cab apart to get to the tunnel cover. Probably saved me two hours of shop time too. Now I need to find a rubber carpet kit for the front cab section. I don't want carpet. Probably a dealer only item? Any pointers greatly appreciated on where to source. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
rpsinc Posted April 24, 2018 Report Share Posted April 24, 2018 Carpet may be dealer item or a competent upholstery shop. Marcel Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 24, 2018 Report Share Posted April 24, 2018 Mmmm, hardwood: I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
lockmup68 Posted April 24, 2018 Report Share Posted April 24, 2018 I like the hardwood a lot. Assume you do not have a tunnel access panel? I just want full rubber mat and insulation. The rear will get wood I think. New AC first. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Big5er Posted April 24, 2018 Report Share Posted April 24, 2018 When I replaced the factory Volvo mat it was a dealer only item. And the bottom side is gold plated I think, judging from the price. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted April 24, 2018 Report Share Posted April 24, 2018 Shannon, Glad to see it will be a quick fix, not as cheap as a fuse but still, it could have been a lot worse. David 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
DesertMiner Posted April 24, 2018 Report Share Posted April 24, 2018 6 minutes ago, Big5er said: When I replaced the factory Volvo mat it was a dealer only item. And the bottom side is gold plated I think, judging from the price. Can you share the Volvo part number? Thanks in advance. Link to comment Share on other sites More sharing options...
lockmup68 Posted April 24, 2018 Report Share Posted April 24, 2018 30 minutes ago, GeorgiaHybrid said: Shannon, Glad to see it will be a quick fix, not as cheap as a fuse but still, it could have been a lot worse. David Keeping fingers crossed. All conjecture right now until we plug it in and test! Bonus, they are doing full oil and all filter change cheaper than Speedco while it is sitting there today. Just got shipping confirmation, less than two hours after ordering. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
