Little Posted February 7, 2018 Report Share Posted February 7, 2018 I think this may have been discussed before, maybe even by me but couldn't find it with search. '04 780 with d12 and freedomline. We drove the Volvo to MT to pick up some horses to take to AZ for the winter. First 80 miles with no trailer we had no issues. Got to the farm and hooked up, loaded and headed for the highway. Error code sm and trans is in 6th gear. Stop at highway and turn rt. all good. Down the hill into town, same thing, sm, so I coast to a stop and trans stays in 12th till we get stopped, then it shifts back to 4th. Still says sm on the dash screen. So I try to shift it up/ dome using the paddle and all seems ok. Called ahead to Casper but they were too busy to look at it so we drove straight thru to Wickenburg. Got here about 4 pm unloaded and unhooked. Took it bobtail down the Vulture Mine road, same thing, sometimes it worked ok, then 'sm' code and only shift manual. Any ideas before I take it to PHX for them to tell me its a loose wire that could have been detected myself. Only a bit over hr. in but a crappy drive. Thanks in advance, Mark 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
jeffw Posted February 7, 2018 Report Share Posted February 7, 2018 You should try to pull the codes: https://www.zf.com/usa_canada/media/zfmig_united_states/zfmig_corporate_replacement_parts_1/zfmig_service_portfolio/zfmig_class8/TP01110.pdf 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
hone eagle Posted February 7, 2018 Report Share Posted February 7, 2018 when I got the SM (service module)and stuck in 6th, it was a bad/ intermittent connection from the battery bank to the 'doubler' that is what the volvo tech said ,redid the connector no trouble since it has been 6 years. 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
Quickthrotl Posted February 7, 2018 Report Share Posted February 7, 2018 I had same problems, cleaned all connections from battery to the to the transmission, check for corroded connections and replace them. use dielectric grease on your repaired connections if you need to replace them, which I would do anyway. 2004 Volvo VNL 780 2017 Momentum 376TH 2007 Harley Davidson FLHTC 2009 Smart4two Link to comment Share on other sites More sharing options...
Little Posted February 7, 2018 Author Report Share Posted February 7, 2018 Should I see a plug of some sort on the trans?? Parked in the dirt last night so will need to get it up to the hard ground. I also need to check the batteries and connections. I cleaned them early fall and i battery was slightly lower volts than others when cables were removed. Batteries are 5 yr old but have had pretty good maintenance. Thanks guys for the tips. 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
hone eagle Posted February 7, 2018 Report Share Posted February 7, 2018 there should be a connector coming from the batteries ,just about lays on top I think there is a fuse inside? do that before climbing under it. 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
Wrknrvr Posted February 7, 2018 Report Share Posted February 7, 2018 If you stop by the north ranch I would donate a beer. Now I have seen that issue when the trans computer is not registering the modulating valve at the rear axle. Ended up being the wiring harness between the two. Has the truck been singled? Now I had a tough day so it is beeeeer time,. Vern Link to comment Share on other sites More sharing options...
Little Posted February 7, 2018 Author Report Share Posted February 7, 2018 Yes singled. Removed the front drive axle only and plugged the speed sensor into the vacant spot on the hub. Vern where is your place?? 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
Wrknrvr Posted February 7, 2018 Report Share Posted February 7, 2018 We stay the escapes north ranch campground. Just south of Congress Az. Safe travels,. Vern Link to comment Share on other sites More sharing options...
Little Posted February 7, 2018 Author Report Share Posted February 7, 2018 OK we've been by there many times, never been in the gate. Going to visit some friends in Cottonwood. Will try to stop by. Thanks, Mark 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
ctsedlak Posted February 8, 2018 Report Share Posted February 8, 2018 I had similar problem. 2004 VNL630 d12 w/Freedomline. Seemed to only do it once the speed leveled off. Also noticed the shift timing was way off. Like going through a small town at 30mph in 16th gear. I finally replaced the throttle position sensor, which Volvo no longer carried just the $20 sensor, so it's about $150 for the accelerator pedal w/sensor. Took all of 10 minutes to replace and it drives like a new truck. The computer just couldn't communicate with the throttle pedal anymore to know where it was, so it went into SM until you let off the pedal to slow down and then it would correct itself. From my research, it sounds like a common problem even in cars. But with a truck that has had the throttle at the same spot for hundreds of thousands of miles, it just gets dead spots in the sensor. Link to comment Share on other sites More sharing options...
Wrknrvr Posted February 8, 2018 Report Share Posted February 8, 2018 If you are going to stop by call before as I am out working a fair amount. Yes still working. I maybe just down the street or in Stanton. Will be in Wickenburg Friday afternoon and on Saturday . My number is 406-250-8861 Safe Travels,. Vern Link to comment Share on other sites More sharing options...
Little Posted February 9, 2018 Author Report Share Posted February 9, 2018 On 2/7/2018 at 6:27 PM, ctsedlak said: I had similar problem. 2004 VNL630 d12 w/Freedomline. Seemed to only do it once the speed leveled off. Also noticed the shift timing was way off. Like going through a small town at 30mph in 16th gear. I finally replaced the throttle position sensor, which Volvo no longer carried just the $20 sensor, so it's about $150 for the accelerator pedal w/sensor. Took all of 10 minutes to replace and it drives like a new truck. The computer just couldn't communicate with the throttle pedal anymore to know where it was, so it went into SM until you let off the pedal to slow down and then it would correct itself. From my research, it sounds like a common problem even in cars. But with a truck that has had the throttle at the same spot for hundreds of thousands of miles, it just gets dead spots in the sensor. This may be our trouble. Disconnected the batteries and load tested. 2 were weak. Changed all 4 kept 2 for spares. Cleaned all the connections, 2 smaller + had a wee bit of green. Loaded 4 horses for Maricopa and took off. Worked perfectly for few miles then SM. Let off the throttle a bit and all good. Kept this routine up for the 90 mile trip. Annoying but not a big deal. I will get a TPS tomorrow if possible, maybe Mon. Thanks for the tip.Mark 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
Big5er Posted February 10, 2018 Report Share Posted February 10, 2018 Little, The Freedomline is a 24v transmission. It has a voltage doubler mounted on top. It is about the size of a car stereo amp. If I remember correct it has 4 (maybe 3) plugs going into it. I am not a mechanic but if your 12v is low, could that affect the doubler?? My voltage doubler went out on me a few years ago. It started out not shifting as you accelerated. The SM error would come on and it would stay in the gear it was in...same when I stopped. Give it a few minutes and it would straighten itself out. It seemed to get better as it warmed up...until the day it say "uh..no". Had it towed to the Volvo dealer in Kansas who diagnosed it and said "The doubler is $1200 and we can have one tomorrow". I found it online for $500 including overnight shipping and the dealer installed it, "but we won't warranty it". They hooked their computer up after the install and pronounced my problem solved. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Little Posted February 10, 2018 Author Report Share Posted February 10, 2018 Ok some of this could be explained by my nfg batteries. However we put new ones in and trans shifting was better. Took awhile but eventually coded sm. Touched the throttle up/down lightly and back to good. Acted up twice on a 20 mile test. Here's hoping its the $100 tps rather than doubler but that will be the next thing to try. Volvo in PHX didn't have a tps in stock but ordered 1 in. Thanks for the help 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
DesertMiner Posted February 10, 2018 Report Share Posted February 10, 2018 Big5er.... can you share with us your source of the voltage doubler? Thx Link to comment Share on other sites More sharing options...
Big5er Posted February 10, 2018 Report Share Posted February 10, 2018 2 hours ago, DesertMiner said: Big5er.... can you share with us your source of the voltage doubler? http://www.ase-supply.com/Sure_Power_41222_DC_to_DC_Converter_p/sp-41222.htm MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
DesertMiner Posted February 10, 2018 Report Share Posted February 10, 2018 Thanks Link to comment Share on other sites More sharing options...
Big5er Posted February 10, 2018 Report Share Posted February 10, 2018 When I pulled the floor access panel the doubler had a label with the part number ZF 41222. How I actually found this one I do not recall. The original thread about it has disappeared from the forum. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted February 12, 2018 Report Share Posted February 12, 2018 Phil when we pulled the access panel didn't the doubler sit right on top of the transmission? It was a while ago and I don't remember. Did we pull the passenger seat and slide it to the back and then peel up the carpet to get to the access panel. Damn I miss my mind. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Grassy Posted February 12, 2018 Report Share Posted February 12, 2018 As mentioned on the other board, you would save yourself a lot of grief if you went into an authorized Eaton service center and have them plug their computer into your trans.. we can guess all day here ... . Arctic Fox 29-5T . Beagle co-pilots - Faffy and Lulu Link to comment Share on other sites More sharing options...
Big5er Posted February 12, 2018 Report Share Posted February 12, 2018 3 hours ago, Brad & Jacolyn said: Phil when we pulled the access panel didn't the doubler sit right on top of the transmission? It was a while ago and I don't remember. Did we pull the passenger seat and slide it to the back and then peel up the carpet to get to the access panel. Damn I miss my mind. Brad Your mind isn't that far gone Brad. You are 100% correct. We moved the seat, just so we could pull the mat back and get to the access panel. Of course I was told later that any "good" mechanic can change out the doubler from the bottom. Guess we aren't "good"..or mechanics for that for that matter. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted February 12, 2018 Report Share Posted February 12, 2018 I thought we were doing good when we found the access panel. Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted February 12, 2018 Report Share Posted February 12, 2018 Dang! For a 12V to 24V 10 Amp converter, that thing is expensive! "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
Big5er Posted February 14, 2018 Report Share Posted February 14, 2018 On 2/12/2018 at 12:44 PM, NoDirectionHome said: Dang! For a 12V to 24V 10 Amp converter, that thing is expensive! I called 3 different Volvo dealers. None had it in stock but they wanted $1100-1300 for it. For what that one cost, even with overnight shipping, I was real happy. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
