bags Posted August 24, 2016 Report Share Posted August 24, 2016 I have found myself in the unenviable position of have to replace my 7 year old (40 k mileage) rear duals. I have a couple of questions I need some help with. 1. should I balance my duals? 2. If so should I spend the 25 bucks a tire for the bags or go w/weights? 3. I use pressure pro and have a device (the name escapes me) that fills both tires from one common stem. The price for Kelly Springfield is about the same (1691.00 drive out) as my Firestone tires were 7 years ago after trade in on 3 tires. Any and all help appreciated. Thanks JB Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 24, 2016 Report Share Posted August 24, 2016 Most OTR truckers don't. Saying that I did but later took out the liquid balance and now have Centramatics all around. So you're gonna get different opinions. If you do balance AND use tire pressure monitors don't use liquid or powder balance. Also was cautioned by TST against bead balance because they eventually degrade to small particles that can mess with the sensors. If you do use beads get tire stems with screens to catch those particles (although lot of people don't use screened stems and beads and have apparently had no problems). So if they can use weights may be your best option. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 24, 2016 Report Share Posted August 24, 2016 We balanced ours and run the Centramatics. Smooth ride. Link to comment Share on other sites More sharing options...
Imurphy907 Posted August 24, 2016 Report Share Posted August 24, 2016 I balance all of my tires, even the trailer tires. Link to comment Share on other sites More sharing options...
brunsje Posted August 24, 2016 Report Share Posted August 24, 2016 No balancing. Rides great! Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 25, 2016 Report Share Posted August 25, 2016 I balance everything the spins and I'd recommend weights . The Centramatics seem to work great for us too. Link to comment Share on other sites More sharing options...
Broncohauler Posted August 25, 2016 Report Share Posted August 25, 2016 Your going to get opinions all over the map, just depends on how much money you want to spend, and how picky you are about your ride. None of my OTR trucks have ever had the rears balanced but maybe should have. As for the fronts, I would do everything and anything to make them perfect. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 25, 2016 Report Share Posted August 25, 2016 Brunsje, I am not an authority by any means but would think the amount of weight we carry on our trucks versus an OTR truck can influence the feel. With our less weight suspect we would feel an out of balance situation more readily. Opinions? Link to comment Share on other sites More sharing options...
Broncohauler Posted August 25, 2016 Report Share Posted August 25, 2016 Brunsje, I am not an authority by any means but would think the amount of weight we carry on our trucks versus an OTR truck can influence the feel. With our less weight suspect we would feel an out of balance situation more readily. Opinions? Must say I agree with you on that Carl. And as I'm driving my work truck last night and for the next couple hours I can feel they are out of balance. Now the extra vibration is no big deal on my 48 ft van trailer full of paint, but I really don't think I'd like it on my 5th wheel trailer. Link to comment Share on other sites More sharing options...
Jack Mayer Posted August 25, 2016 Report Share Posted August 25, 2016 IMO it is best to balance them - and with weights. Also check them for out of round....most decent tire places can do that. Link to comment Share on other sites More sharing options...
peety3 Posted August 25, 2016 Report Share Posted August 25, 2016 I still drive my 2001 Ford Excursion. Came with Firestones that were slicker than snot in the rain, so I tossed them after 40k (and only half worn) for Michelin. Had to go from load range D (aka 8-ply) to load range E (aka 10-ply, so theoretically stiffer), yet the ride got significantly better. Took the "bus" to a good tire shop who trued (shaved to make them round) and balanced the tires, then aligned everything. The improvement after true/balance/align was far more than the improvement in switching from Firestone to Michelin, and a lot cheaper too. Link to comment Share on other sites More sharing options...
bags Posted August 27, 2016 Author Report Share Posted August 27, 2016 I went with the plastic beads. I asked the tire guy and he said he had not noticed any dust and that was what they sold most. I took two different runs at 70 mph up 25 and they ran real smooth. I had forgot how enjoyable it is to run down the open road with all that power and no trailer. 50 miles of bliss and good rock and roll!!! I highly recommend it (the ride). Now if they don't stop up my sensors. Thanks for all the input. JB Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 27, 2016 Report Share Posted August 27, 2016 John, I mentioned the bead breakdown only to pass along what I was told. My opinion is that I suspect you won't have an issue with your sensors. Link to comment Share on other sites More sharing options...
bags Posted August 27, 2016 Author Report Share Posted August 27, 2016 John, I mentioned the bead breakdown only to pass along what I was told. My opinion is that I suspect you won't have an issue with your sensors. Thanks JB Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 27, 2016 Report Share Posted August 27, 2016 Just a thought - IMO any vehicle I drive I want to be as smooth as possible. Vibration in the steering wheel, pedal, seat, etc is ultimately a health hazard. Holding a steering wheel that vibrates for an extended period of time can cause numbness in hands, as well as causing other driver fatigue issues. When an object that rotates is out of balance, everything that it connects to vibrates / shakes leading to failure of materials. Our road infrastructure takes enough of a toll on our vehicles by itself without having self-induced parts failure. Link to comment Share on other sites More sharing options...
Jack Mayer Posted August 27, 2016 Report Share Posted August 27, 2016 John, I mentioned the bead breakdown only to pass along what I was told. My opinion is that I suspect you won't have an issue with your sensors. I ran beads in my Jeep for many years.They helped immensely with the large offroad tires. I also ran tire monitors on the valve stems and had no issues. For what it is worth. Link to comment Share on other sites More sharing options...
lappir Posted August 27, 2016 Report Share Posted August 27, 2016 I ran beads in my Jeep for many years.They helped immensely with the large offroad tires. I also ran tire monitors on the valve stems and had no issues. For what it is worth. Jack, Were they the Dynabeads? I have used them in my motorcycle for years until my latest Yamaha. Put a tire on the back 15000 miles ago and didn't balance it. Very smooth still. I had "Equal" tossed into my drive tires when I replaced them a few years ago and it seems to work well. Had the 4 tires spin balanced, the outer bead broke and put beads in bags in the tires of my VX a few years ago and thought I made a HUGE mistake. Took forever it seemed for the bag to break and finally allow the beads to distribute. Haven't taken the tire off the rim since so don't know what the beads look like now. One day I will show photos. My Brother owns a small tire shop in S.E. Iowa. Does a LOT of tire work for the local truck drivers. Hardly any of them use any type of balancing on anything other than steer tires. He also has customers with the Super Singles and they are very happy with them. I'm a couple years from trading in my Steers and then a couple more for the drives. Want to just do about 5 years on them and then let someone wear them out. Hopefully we will both be happy with the prices. Rod Link to comment Share on other sites More sharing options...
alan0043 Posted August 27, 2016 Report Share Posted August 27, 2016 I balance everything the spins and I'd recommend weights . The Centramatics seem to work great for us too. I believe that anything that moves in a circle should be balanced if it can be done. Just my opinion. 2X on the Centramatics. Al Link to comment Share on other sites More sharing options...
Jack Mayer Posted August 28, 2016 Report Share Posted August 28, 2016 Jack, Were they the Dynabeads? Rod Yes. They did not seem to impact the Pressurepro at all. Link to comment Share on other sites More sharing options...
GlennWest Posted August 28, 2016 Report Share Posted August 28, 2016 I have no vibration that I can tell. My truck does have new virgin rubber. There is no weights on them. Have had one rear wheel off and patch put in. No beads. Link to comment Share on other sites More sharing options...
lappir Posted August 28, 2016 Report Share Posted August 28, 2016 Yes. They did not seem to impact the Pressurepro at all. I liked the Dynabeads the best for my motorcycles, but Little Brother used "Equal" in my truck tires. Sort of hard to find someone with the Dynabeads and I try not order them online. Had a guy in South Florida, but I don't get down there much anymore. Rod Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 28, 2016 Report Share Posted August 28, 2016 I liked the Dynabeads the best for my motorcycles, but Little Brother used "Equal" in my truck tires. Sort of hard to find someone with the Dynabeads and I try not order them online. Had a guy in South Florida, but I don't get down there much anymore. Rod I've used regular BBs . That requires breaking the tire bead , but , once and done . Just to show what those BBs looked like after 20K miles : Left side = out of the box Right side = 20K polished Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 28, 2016 Report Share Posted August 28, 2016 I used dynabeads in my Dodge's steer tires and they broke down into a really fine dust. Don't know if that would mess with TPMS, but it did make the valve cores leak after some time. They have been fine in the motorcycle though. I have also used Magnum beads. I have since given up on any type of bead or internal balance in the Dodge because I have just had too many strange incurable intermittent vibration issues and since I just vent back to weights, the problems are gone. On the Pete, IDK if the Centramatics work or if the tires are just smooth without any weights. They were on the truck when I bought it so I run them...... Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 28, 2016 Report Share Posted August 28, 2016 From liquid balance to Centramatics, big improvement. Link to comment Share on other sites More sharing options...
