Raquel Posted April 24, 2015 Report Share Posted April 24, 2015 I hopped into the truck today and started it up. There was a warning that the batteries were only putting out 11.7 amps. Whaaaa!? Okay. We've had the truck 37 months, so maybe that's not too bad life, but not real good. Where are the good deals happening guys? Trish & Raquel -------- "Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb "Wile E." -- 2013 Heartland Landmark San Antonio Link to comment Share on other sites More sharing options...
sclord2002 Posted April 24, 2015 Report Share Posted April 24, 2015 Raquel, I'm sure you meant volts and not amps. Anyway, I have found that the truck dealers often have the best prices on batteries. You may want to check with a Freightliner or Peterbilt or Volvo dealer to see who has the best battery deals. You do need to make sure your alternator output is good, also. Let us know what works out for you. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 24, 2015 Report Share Posted April 24, 2015 Amps, or volts? If amps, then all your loads combined are adding up to 11.2 amps. Not an unrealistic number. I don't know Volvo's enough to know if they have current monitoring hardware. If volts, that's the voltage of the entire system, from the alternator output stud, to the battery bank (with all it's connections), and up to whatever sensor or transducer is used to report to the driver info panel. How have the batteries been treated? On a maintainer, or solar charger? Disconnected from the parasitic loads, and left to sit? Driven regularly to maintain a charge? This is one place dealers can often have a good price, ready to go. It seems the Paccar dealers have batteries on special almost all the time. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
wtgeodog Posted April 25, 2015 Report Share Posted April 25, 2015 I found the best price for Group 31 batteries two weeks ago at the local Volvo dealer. Link to comment Share on other sites More sharing options...
CDR Posted April 25, 2015 Report Share Posted April 25, 2015 Trish & Raquel Is the belt still there? Water in them or are they sealed? A battery under 11.7 won't start your lawnmower. As soon as the truck started that alternator should be trying to put 14.2 to 14.7 volts and (whatever the rated amperage output of the alternator is), if not start diagnosis. 1) Alternator output (voltage & amperage) 2) Load test batteries results This should get you started. Curt 2001 Freightliner Century, 500hp Series 60, Gen 2 autoshift, 3.42 singled rear locker. 2004 Keystone Sprinter 299RLS (TT) 2 & 4 Wheelers! 2013 Polaris Ranger 800 midsize LE Our motto "4 wheels move the body, 2 wheels move the soul!" Link to comment Share on other sites More sharing options...
Dennis M Posted April 25, 2015 Report Share Posted April 25, 2015 If it was a monitor warning for "low voltage" it's not the batteries, it means the alternator is not putting out. Time for some diagnostics. 11.7 volts is about a 30% charge on a 12 volt battery. Probably will not start the truck again. Dennis & NancyTucson, AZ in winter, on the road in summer.1999 Volvo 610 "Bud" 425 HP Volvo, Super 10 spd.2005 Mountain Aire 35 BLKS2013 smart fortwo CityFlame riding on Bud(Replaced '05 smart first loaded in '06 and '11 smart that gave it's life to save me!)Our Travel Blog Link to comment Share on other sites More sharing options...
Raquel Posted April 25, 2015 Author Report Share Posted April 25, 2015 Oh, I don't know. It's probably volts. All I know for sure is that the driver's display showed a warning that had a battery on it with 11.7 (probably) volts beside it. I was thinking of trying Les Schwab, Costco, Walmart. I'll try some of the dealers in the general area. Trish & Raquel -------- "Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb "Wile E." -- 2013 Heartland Landmark San Antonio Link to comment Share on other sites More sharing options...
MrSeas Posted April 25, 2015 Report Share Posted April 25, 2015 Has the truck been sitting? If so put a good quality charger on the batteries before you go out and replace them. You may need to leave the charger on for a bit of time to get them to charge up. The volvo dealer usually has pallets of batteries and I have found them to be very competitive in pricing. I had a very similar problem on my truck and using just the "alternator" never got my batteries charged up. One I used an "external" charger to bring the batteries up in charge my alternate r was able to work properly. Also check to see if you have 3 or 4 batteries. Also verify the type of connection you have connecting the batteries to the truck. Just a thought.... Scott Link to comment Share on other sites More sharing options...
Shallow Draft Posted April 25, 2015 Report Share Posted April 25, 2015 I have mine on a battery tender whenever it is parked. Way to much parasitic draw and I don't drive it often enough to keep the batteries fully topped up. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
HERO Maker Posted April 25, 2015 Report Share Posted April 25, 2015 A battery minder would be a better set up. And you must have hit the strike through before you started typing. Rachael, were the bats new when you purchased your truck? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Phil D Posted April 25, 2015 Report Share Posted April 25, 2015 Why do I have a line thru my post? You inadvertently hit the "Strikethrough" button (the capital "S" with the line through it, between the "Underline" and "Subscript" buttons) somewhere along the line. Fixed! Phil 2002 Teton Royal Aspen 2003 Kenworth T2000 - Cat C12 380/430 1450/1650, FreedomLine, 3.36 - TOTO . . . he's not in Kansas anymore. ET Air Hitch Link to comment Share on other sites More sharing options...
Shallow Draft Posted April 25, 2015 Report Share Posted April 25, 2015 Sorry to HyJack the thread with my lack of computer skills! LOL 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
Raquel Posted April 25, 2015 Author Report Share Posted April 25, 2015 Scott, The truck has 4 batteries. They are connected by a buss bar (I think that's what it's called) across the positive posts and across the negative posts. Right now the truck sits for 4 to 6 weeks at a time without being started but, it goes onto the battery minder whenever it's sitting. The 4 batteries are no maintenance wet cell. There are no caps accessible for us to fill the cells. The negative post of one battery is having some issues of showing some acid on the post. Perhaps what I need to do is to remove the connections, clean the posts and treat with electrical grease before re-assembling? Trish & Raquel -------- "Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb "Wile E." -- 2013 Heartland Landmark San Antonio Link to comment Share on other sites More sharing options...
kkesp Posted April 25, 2015 Report Share Posted April 25, 2015 It's probably your alternator, not the batteries. The number that your truck is displaying is the output from the alternator, and it should be around 14.0-14.5. If the batteries are down a little you might see as high as 14.8 for a period then it will come down. I would have the alternator checked, before I bought new batteries. Then make sure you get a good charge on the batteries from a charger, it's not really good to let a new alternator charge low batteries. Full batteries should be around 12.6 volts then have them load tested to see how close they are to the rated CCA. If the batteries are rated at 700 CCA you should see at least that on a load test. Link to comment Share on other sites More sharing options...
Raquel Posted April 25, 2015 Author Report Share Posted April 25, 2015 A battery minder would be a better set up. And you must have hit the strike through before you started typing. Rachael, were the bats new when you purchased your truck? If I remember correctly, the batteries were replaced about 2 months before we bought the truck. We picked the truck up 3 years ago April 1. Trish & Raquel -------- "Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb "Wile E." -- 2013 Heartland Landmark San Antonio Link to comment Share on other sites More sharing options...
MrSeas Posted April 25, 2015 Report Share Posted April 25, 2015 deleted Link to comment Share on other sites More sharing options...
lappir Posted April 25, 2015 Report Share Posted April 25, 2015 I replaced my 4 batteries with two and have been happy with the choice so far. I also added a battery minder that is plugged in whenever the truck is parked for more than a day. My truck can sit for months at a time and there is something that is always using the battery power while it is sitting. Having the charger connected resolves that issue. When removed two of the 4 batteries checked "bad" and two "good". If you are just starting the truck two batteries is really all you need. If you plan to park along the road with the lights on overnight then you will need more battery capacity. Just my opinion. It may change, but not today. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
phoenix2013 Posted April 25, 2015 Report Share Posted April 25, 2015 My Volvo will not start with Voltage that low, the computer will not allow the starter to "try". Sight unseen diagnostic tells me that the batteries are probably OK. Not that old 37 months, on the battery minder when sitting and most important they did start the truck. Once the truck is running the alternator should have no problem to go into a boost mode of around 14.4V and after running for a while drop to around 13.8V (maintaining voltage) once the batteries get up to full charge. Immediately after shut down fully charged batteries should show around 12.6V by themselves. Before you spend money on the batteries I would have the alternator or anything with it (belt, connections, etc.) checked. Link to comment Share on other sites More sharing options...
beyerjf Posted April 25, 2015 Report Share Posted April 25, 2015 As has been said check alternator and clean connections first. 3 years old for flooded cell batteries is pushing it. The type of service that these hdt's go through is tough on them, even with a trickle charger. The chemistry is well known, time plus discharge cycles adds up to a finite life some time. There are batteries and there are batteries. Look for at least 950 CCA. Dealers are ok, they are going to usually sell the "private label" manufactured by one of the majors, Johnson Controls, Exide, Deka. Some of them use batteries as a loss leader and price them accordingly. Check heavy duty truck parts suppliers in the area, Truck Pro as an example. Stay away from consumer outlets such as Costco. Jeff Beyer temporarily retired from Trailer Transit 2000 Freightliner Argosy Cabover 2008 Work and Play 34FK Homebase NW Indiana, no longer full time Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted April 25, 2015 Report Share Posted April 25, 2015 We just replaced our batteries (3) as well. We bought ours from a Napa as they were the best deal that week $110 each. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted April 25, 2015 Report Share Posted April 25, 2015 I replaced my battery's after the bed build, got them at local Volvo dealer for 85.00 each. I would clean the buss bars, and check the battery's first, If one is bad replace them all. Roger Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted April 25, 2015 Report Share Posted April 25, 2015 Raquel, When I needed to replace my batteries a year ago the Volvo dealer had the best price. Surprised the heck out of me. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
HERO Maker Posted April 25, 2015 Report Share Posted April 25, 2015 Just the other day, I went to start the truck to actually take it to Volvo for another issue, and there was no nothing what-so-ever! Turned the key off, thinking I had just tried turning it on too quickly, and then tried it again. Nothing. I then remembered that you guys had said to check battery connections first when these things happen. So I got a few tools that fit and loosened every connection and then tightened them down again. Turned right over and started up! My guess is that there is enough vibration (and like we are told to do with everything electric on our rigs and even homes) that these connections can loosen up. Glad to have this forum to keep us all edumacated . Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Dennis M Posted April 25, 2015 Report Share Posted April 25, 2015 My Volvo will not start with Voltage that low, the computer will not allow the starter to "try". Sight unseen diagnostic tells me that the batteries are probably OK. Not that old 37 months, on the battery minder when sitting and most important they did start the truck. Once the truck is running the alternator should have no problem to go into a boost mode of around 14.4V and after running for a while drop to around 13.8V (maintaining voltage) once the batteries get up to full charge. Immediately after shut down fully charged batteries should show around 12.6V by themselves. Before you spend money on the batteries I would have the alternator or anything with it (belt, connections, etc.) checked. X2 As I said before, you are looking at alternator output (in volts), not battery charge. Mine shows 14.2 right after start up and then levels out between 13.8 and 14 when running. Check your belts and alternator before you start messing with the batteries! My first set of batteries lasted 8 years, mostly vacation use and on the Battery Tender when parked. Dennis & NancyTucson, AZ in winter, on the road in summer.1999 Volvo 610 "Bud" 425 HP Volvo, Super 10 spd.2005 Mountain Aire 35 BLKS2013 smart fortwo CityFlame riding on Bud(Replaced '05 smart first loaded in '06 and '11 smart that gave it's life to save me!)Our Travel Blog Link to comment Share on other sites More sharing options...
Raquel Posted April 25, 2015 Author Report Share Posted April 25, 2015 . Look for at least 950 CCA. Dealers are ok, they are going to usually sell the "private label" manufactured by one of the majors, Johnson Controls, Exide, Deka. Some of them use batteries as a loss leader and price them accordingly. Check heavy duty truck parts suppliers in the area, Truck Pro as an example. Stay away from consumer outlets such as Costco. These are 1100 cca batteries. Monday I'll be able to get out and check for prices and tighten connections, etc. Trish & Raquel -------- "Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb "Wile E." -- 2013 Heartland Landmark San Antonio Link to comment Share on other sites More sharing options...
