maverick_935 Posted May 14, 2018 Report Share Posted May 14, 2018 can find any topics on this. at this time I plan on using the commercial plate on the truck. is this a good idea? was thinking on putting on an air ride hitch on trailer to help with bounce. any thoughts on hitch. ok to keep or replace. thanks Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 14, 2018 Report Share Posted May 14, 2018 Having side to side articulation on a 5th wheel hitch is important for an RV. You can get away with a commercial 5th wheel hitch, but you need to be careful when turning into driveways with dips and other off level situations. It can put a lot of stress on the 5th wheel pin box and frame without that articulation.. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Av8r3400 Posted May 14, 2018 Report Share Posted May 14, 2018 This is a topic that has been debated to death on this board. Weather you use the commercial plate or not is your decision. Keep in mind the pitfalls of it's use: There is no lateral articulation - It will cause damaging flex of your camper's weak forward frame. The harshness of the truck's ride will rattle everything loose inside your trailer. An air inbox will help this to a point. A commercial plate is just that "commercial". It makes you look like a commercial truck. It may draw unwanted attention by DOT officials. Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 14, 2018 Report Share Posted May 14, 2018 I actually saw a rig on a site that wasn't that level, the tension of the pin from the lateral twist between the tractor and the trailer. would not allow the pin to pull out of the pocket. A commercial trailer frame may handle that twist torsion but an RV frame will crack. The is why using an air pin with a commercial hitch is not the same as a RV air hitch. Not a place to save money. Using an air pin with an RV hitch makes more sense but then the savings are not there. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
noteven Posted May 14, 2018 Report Share Posted May 14, 2018 Fully grown fifth wheels (aka “hitch” in rv land) have bolsters spaced approx 34” apart to match truck frames. This width plus the lack of occillation others have mentioned is what can place excessive twisting forces on the trailer king pin. A rv sized 5th wheel - hitch plate - Binckley head - is much narrower which makes it’s leverage on the trailer a lot less. Adding lateral movement adds more flexibility and stress relief to the trailer. This writer does not unnerstan why a side to side oscillating pin is not built into the trailer pin box. That combined with the hinge crossways of the 5th wheel - hitch - plate on the truck would form a nice universal joint giving flexibility in all directions. see most any belly dump gravel semi trailer.... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
rickndeb1125 Posted May 14, 2018 Report Share Posted May 14, 2018 I would be glad to help you out with a 30k hitch give me a call 608/575/5010 Rick L Olson Link to comment Share on other sites More sharing options...
Av8r3400 Posted May 14, 2018 Report Share Posted May 14, 2018 5 hours ago, noteven said: This writer does not unnerstand why a side to side oscillating pin is not built into the trailer pin box. That combined with the hinge cross-ways of the 5th wheel - hitch - plate on the truck would form a nice universal joint giving flexibility in all directions. The short answer: MONEY and LIABILITY. Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 14, 2018 Report Share Posted May 14, 2018 Shorter answer: Sales volume. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Scottiedot Posted May 14, 2018 Report Share Posted May 14, 2018 I’m towing with a 1992 FLD 120, factory singled with air ride rear suspension. It’s towed fifth wheel RV’s exclusively since 2000, three different trailers and well over 100,000 miles with zero issues. No visible damage, nothing flying out of cabinets. No issues. We upgraded the trailer 2 months ago and I did have an air ride pin box installed, because the dealer offered to it at cost. But the previous trailers had rigid pinbox’s. Link to comment Share on other sites More sharing options...
maverick_935 Posted July 14, 2018 Author Report Share Posted July 14, 2018 I understand the twist. do I put an air ride pin box and or a different hitch. looking at hitches now that I can bolt to the frame plate Link to comment Share on other sites More sharing options...
rpsinc Posted July 14, 2018 Report Share Posted July 14, 2018 Using the factory hitch would more likely show the truck as commercial, BUT with a 5th wheel hitch, it will clearly show it as an RV toter. Should more readily support its NON-commercial use, at least from my point of thinking. Marcel Link to comment Share on other sites More sharing options...
Morelli Posted July 14, 2018 Report Share Posted July 14, 2018 An average (please note the word average) commercial fifth wheel is designed for a 55,000 lbs pin weight and 150,000 lbs pull weight. A semi trailer is designed to flex and twist from side to side. Its all part of the design including the hump in the center. At average 78,500 lbs loaded truck weight, the truck flexes also and everything works together. A quality built RV hitch is designed for a 8,000 lbs pin weight and a max of 32,000 lbs pull weight and is also designed to pivot from side to side along with front to back because the usage models are completely different. Now take that same truck and attached it to an RV with much lighter loads, lighter trailer tires and different frame structure, you change everything. Now the weight of the commercial king pin is not there anymore so the tractor does not flex, the tires designed for 80K loads are stiff and so the RV has to absorb the flex. On a multi-pivot head, that takes the forces. Installing a multi-pivot commercial hitch does not work either, because the pivot springs are designed for high weights. An air ride pin box for an RV does not pivot side to side, so that force is still not dealt with, it just adsorbs the up and down jolts . Now depending on how the RV frame was made, where the steel came from (not all steel is the same), how it was welded together, how it was designed, how it was braced for torsional forces and much much more, some may work on a commercial hitch and many will not. It also depends on your driving, locations, roads and much much more if that RV is going to survive. Just because it has worked for one person does not mean is will work for another. At the end of the day, decision and responsibility is that of the owner. Yes I could slide my commercial fifth back far enough to hookup to my RV and head out, I will not because I understand that could happen and just not worth it. Same reason why I do not hookup a commercial flatbed to my RV hitch, I could, pin is the same size, but I understand the weight differences and forces at play and just not worth it. Hope that helps. Link to comment Share on other sites More sharing options...
Chad Heiser Posted July 15, 2018 Report Share Posted July 15, 2018 6 hours ago, Pug said: An average (please note the word average) commercial fifth wheel is designed for a 55,000 lbs pin weight and 150,000 lbs pull weight. A semi trailer is designed to flex and twist from side to side. Its all part of the design including the hump in the center. At average 78,500 lbs loaded truck weight, the truck flexes also and everything works together. A quality built RV hitch is designed for a 8,000 lbs pin weight and a max of 32,000 lbs pull weight and is also designed to pivot from side to side along with front to back because the usage models are completely different. Now take that same truck and attached it to an RV with much lighter loads, lighter trailer tires and different frame structure, you change everything. Now the weight of the commercial king pin is not there anymore so the tractor does not flex, the tires designed for 80K loads are stiff and so the RV has to absorb the flex. On a multi-pivot head, that takes the forces. Installing a multi-pivot commercial hitch does not work either, because the pivot springs are designed for high weights. An air ride pin box for an RV does not pivot side to side, so that force is still not dealt with, it just adsorbs the up and down jolts . Now depending on how the RV frame was made, where the steel came from (not all steel is the same), how it was welded together, how it was designed, how it was braced for torsional forces and much much more, some may work on a commercial hitch and many will not. It also depends on your driving, locations, roads and much much more if that RV is going to survive. Just because it has worked for one person does not mean is will work for another. At the end of the day, decision and responsibility is that of the owner. Yes I could slide my commercial fifth back far enough to hookup to my RV and head out, I will not because I understand that could happen and just not worth it. Same reason why I do not hookup a commercial flatbed to my RV hitch, I could, pin is the same size, but I understand the weight differences and forces at play and just not worth it. Hope that helps. Excellent description. Very nice right up. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
jenandjon Posted July 15, 2018 Report Share Posted July 15, 2018 This is what I did. Slide the angle brackets that held the commercial 5th wheel back as far as you can. You will be able to use some of the factory holes but you will have to drill some. Them bolt a plate to that. Bolt your new hitch to the plate. I do ride 3 inches high in the nose but that has not been an issue so far. Actually when I pull in a park all I have to do is dump my air and I am level. Run the jacks down for stability and leave it hooked up. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Morelli Posted July 15, 2018 Report Share Posted July 15, 2018 10 hours ago, Chad Heiser said: Excellent description. Very nice right up. Thank you ! Link to comment Share on other sites More sharing options...
rpsinc Posted July 15, 2018 Report Share Posted July 15, 2018 I imagine that IF being nose high is an issue, that the plate you attached to the frame, could have also been attached to some 2"-3" channel bolted to the UNDER side of the frame and then the plate to the channel, or welded together, then the hitch bolted to the plate, which would leave the hitch lower as needed. I think I have seen this configuration often. Marcel Link to comment Share on other sites More sharing options...
rpsinc Posted July 15, 2018 Report Share Posted July 15, 2018 Or another option would be to attach it all to the lower flange of the frame and work from the bottom, up. Marcel Link to comment Share on other sites More sharing options...
jenandjon Posted July 15, 2018 Report Share Posted July 15, 2018 I couldn't lower it because it's right above the rear axle. I didn't want to extend the frame rails because I am already really long. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
maverick_935 Posted August 6, 2018 Author Report Share Posted August 6, 2018 plate on frame rails done. rails installed about to install a new 25k curt hitch. what height should the head be at for my fifth, my 1 ton seems high in number but I want the trailer level or a little nose up Link to comment Share on other sites More sharing options...
HERO Maker Posted August 6, 2018 Report Share Posted August 6, 2018 Get your trailer level and let it tell you! Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
noteven Posted August 7, 2018 Report Share Posted August 7, 2018 Level is the way. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Moresmoke Posted August 7, 2018 Report Share Posted August 7, 2018 On 5/14/2018 at 8:29 AM, noteven said: This writer does not unnerstand why a side to side oscillating pin is not built into the trailer pin box. That combined with the hinge cross-ways of the 5th wheel - hitch - plate on the truck would form a nice universal joint giving flexibility in all directions. If the trailer has a side to side oscillation in the pin box, when the truck turns at something close to a 90 degree angle, you get a wierd floppy sensation. The belly dump an a semi, you will feel it and say oh whatever... A 3/4 ton with a big 5er will have a totally different feeling. I've run a frameless dump on a truck with no pivot lock on the 5th wheel. I can tell you two pivot points in the same plane makes some interesting bumps in the night. Link to comment Share on other sites More sharing options...
noteven Posted August 7, 2018 Report Share Posted August 7, 2018 Ya it would bump once you got the two pins to line up... RV gadget opportunity alert! We could design a computer board controlled lockout with on screen display / event recorder in the cab... I am also working on a detachable neck “5th wheel” rv trailer as a theft prevention device... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
