wheel bearings
Hello, I have a 20 foot Jayco travel trailer.  How often should I get the wheel bearings repacked?  I only tow the trailer about 2000 miles a year on camping trips.  I'm told by the dealer that I need to do it every year but that gets expensive,  I will do it if it's necessary, but I would like to find out if it's really necessary on annual basis, thanks, John Anderson
We didn't do it on our first travel trailer. Limped into a small town on a Sunday evening when the garage owner just happened to be there. When he took everything apart, our wheel bearings looked like gun powder. That's one of those "don't do what we did" lessons.
From your opening message, it would seem you're not comfortable doing this yourself.  If that's correct, bite the bullet and have it done, or ask around to see if someone can help you through it.  It's not difficult, but if done incorrectly, it can get very inconvenient when a bearing fails.
It is very difficult to pin down what an action has prevented, and that is true for any preventive maintenance. With wheel bearing there are many variables that can either extend or shorten the useful life of the grease inside. Heat is the enemy of most lubricants but there are many other factors. The probability of needing to do so every year is more of a guess than a fact. This is one of the choices that is much like the age that tires need to be replaced or your transmission serviced. None of those recommended times mean that something bad will happen immediately after that time, but only that it is pretty safe to say that bad things will not happen if the recommendation is adhered to.
I think the key is to either do it yourself at least once or have it done by a trusted professional and let them tell you how often they think it should be done after they have preformed the task.
I found my brand new trailer with not enough oil in my oil bath bearings after my first trip. My mechanic said it shouldn't be an issue when he topped them off and that was 10 years ago. I did have to replace one inside seal since then, but don't remember if that was one of the lowest ones or not.
With the quality of many of the builds coming out in various examples, I think it's prudent to inspect even the wheel bearings very soon after getting a new vehicle, trailer or what ever you have on wheels.
Rod
2007 Honda GL 1800
The Dexter Axle recommendation to repack and inspect wheel bearing annually or at 12,000 miles is  a preventative measure to make sure slightly damaged bearings are caught before having an expensive failure that might also ruin the spindle, cause an accident or complete loss of a wheel.
I lost a wheel from a flat-bed trailer while hauling a tractor due to neglecting that recommendation.
the job is not difficult, just messy-bit that's why vinyl mechanics gloves are sold.
Another good idea is to carry a spare bearing assembly including races, already grease packed in a zip lock bag and then in a box. Even if you feel you can't do it yourself, it can bail you out with road service. Twenty years full timing, weekenders prior, it got me out of a pickle, two times, it was caused by an overheated brake. Just make sure you get the correct bearings.
Edited by bobsallyh
Two years ago at the HDT Rally we had to do some bearing work. Luckily there were folks prepared with new bearings, others with the proper tools and a Muffler Shop was found to press out and reinstall the races and to the surprise to most of us they packed the bearings at the same time. Not sure what the cost was, but I think we were happy to miss part of the mess.
Even then we all got a bit of grease on our hands and clothing. Marks of honor in my book.
Rod
2007 Honda GL 1800
  • 3 weeks later...
Just my thoughts. Yes check and repack the bearings just after purchase. As someone said you don't know how or if they did it correctly during manufacture. Yes generally they say once per year as a standard. But since you only put 2000 miles on the rig, if the bearings were done correctly with a quality grease, you could probably go a couple years between greasing and inspection.
However, grease setting in non rotating bearings can get hard and dry out reducing the lubrication of the bearings when they do start rotating. Then to if you travel in very hot parts of the country, the bearings and grease will get a work out.
As someone said you don't want to destroy a hub/spindle because of a seized or overheated bearing, then you will have to change the whole axle.
I do ours every year, inspect/repack the bearings and replace the grease seal, and don't forget to inspect the brakes shoes, magnets and drums. Or pads, calipers, spindles in the case of disc brakes.
We travel 5000-10,000 miles per year. I use Lucas Oil Red-N-Tacky grease and pack by hand, I don't use the EZ-lube hubs. I don't trust anyone else to do it. A too tight or too loose hub nut will destroy the bearings also. It's not hard to do, really no special tools, easy to learn how. It takes a little labor taking the tires off and pulling the drums/spindles but it's worth every minute.
Edited by Steven@146
Steve & Tami Cass, Fulltime Somewhere
2018 Ram 3500 DRW / 2019 Grand Design Solitude 3350RL S-Class. Texas Class A Drivers License
I usually do it every year but its been 3 years and 6,000 miles. I plan on packing them this weekend. We are headed on 3,000-mile 3-week trip soon.
If you use a good quality grease the bearings don't have to be pack every year and if you can I would learn to do them myself. If you use a extra tacky grease it stays in the bearing were it belongs. If you have someone else do it ask what kind of grease they use and if need be supply your own.
Denny & Jami SKP#90175
Absolutely correct.  The old time grease would separate into oil and clay, (clay based grease), and the oil goes away, leaving the hard clay.  Modern moly grease usually doesn't do that.  That said, use wheel bearing grease, NOT regular grease gun grease, as that will liquify when the bearings get warm.  Been there, had the bearing failure.
However trailer bearing should be inspected annually for defects. Well, unless you're the kind that waits for a bearing failure first. And todays wheel bearing grease will settle out over time. I've seen it with one of my farm wagons that sat in a shed for 3 years. I removed the dust caps to see if they had any grease showing and oil ran out of the dust cap. Regardless of advertising all #2 non synthetic grease must meet the same specs.
We have over 40000 miles on our trailer in almost 3 1/2 years. I check the bearings for play at most campsite stops and check temps. I repacked 1 wheel to check the grease a year and a half ago and it looked like new grease. It’s a triple axle and a little over 28000 lbs. I might repack them in the fall just to do it and the site will make it easy to do it. I definitely do not do it every year just because the service people say to. How often did you repack the bearings in the old rear wheel drive cars? Usually when the brake pads wore out.
I have a 2WD truck and the front bearings have to be serviced, Ford recommends every 30K miles but after starting to use extra tacky grease I'm doing it every 50K, I just did them at 30K and which I would have taken a picture of them because they definitely didn't need it. I don't pack our present trailer because they are Nev-R-Lube and the only grease they have is what's packed into the bearings cage at the factory, I check end play every year but that's all. I've run trailers my whole life both for work and play and always repacked them from new and 3 or 4 years after that depending on how much they are used. Get the bearing cage full and your good to go.
Denny
