SuiteSuccess Posted November 24, 2023 Report Share Posted November 24, 2023 2006 Volvo VNL 780 with D12D motor. Air dryer part number is Wabco 4324210090. There are two parts to the air compressor discharge line that feeds to the air dryer itself. The first is metal which circles to the drivers side from the passenger side location of the compressor. The second piece is rubber (shrouded) hose from a compression fitting on the steel line and connects into the dryer. I need to find a part number for that hose if anyone has it. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 25, 2023 Report Share Posted November 25, 2023 Take it off, find a hose/hydraulic shop, wait at the counter for 1/2 cup of coffee, pay on your way out. No part number needed. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
ddm502001 Posted November 25, 2023 Report Share Posted November 25, 2023 Was going down same road Darryl. Even the Teflon Core High Temp from compressor head is available in those shops on a build as need. Quote Link to comment Share on other sites More sharing options...
rpsinc Posted November 25, 2023 Report Share Posted November 25, 2023 2 hours ago, Darryl&Rita said: Take it off, find a hose/hydraulic shop, wait at the counter for 1/2 cup of coffee, pay on your way out. No part number needed. A much better approach for any hydraulic lines. If you go the path of the RV manufacturer, they often will do the same thing and you will pay for the time they spent doing just that. Cut out the middle man, air lines and hydraulic lines can be fabricated at hose stores and then get the fittings you need while you are waiting on the hose. Quote Marcel Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 25, 2023 Author Report Share Posted November 25, 2023 That was Rickeieio’s suggestion also but he’s kind of shady and didn’t know if I could trust him. 😂😂 Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted November 25, 2023 Report Share Posted November 25, 2023 Thanks for the kind words ol' buddy. And you still don't know whether to trust me...... I was sitting back, waiting to see if my input was validated by someone with real experience. I'm going to add, if you measure your failing hose, and call a couple truck parts houses, I'll bet they have it in stock. When Steve Dixon need one, my local Mack dealer had them. In his case, we had to piece two shorter ones together, as his used hose for the entire run. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 26, 2023 Author Report Share Posted November 26, 2023 (edited) 2 hours ago, rickeieio said: Thanks for the kind words ol' buddy. And you still don't know whether to trust me...... I was sitting back, waiting to see if my input was validated by someone with real experience. I'm going to add, if you measure your failing hose, and call a couple truck parts houses, I'll bet they have it in stock. When Steve Dixon need one, my local Mack dealer had them. In his case, we had to piece two shorter ones together, as his used hose for the entire run. Made a call to dealer. They can get it but 3 weeks unless I pay overnight freight, hence why I wanted part # to check couple other places. Local dealer doesn’t like to give out part numbers. (BTW you’re still my bud. Just kidding wit ya). Edited November 26, 2023 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Cotreker Posted November 26, 2023 Report Share Posted November 26, 2023 Napa will do it. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Deezl Smoke Posted November 26, 2023 Report Share Posted November 26, 2023 No part numbers. But any hose you get, unless it's in a sealed bag, be sure to blow air through it before installation to remove any cutting and pressing debris. Depending upon what type of ends Volvo uses, do not use any sort of sealing paste or tape unless it is a pipe thread fitting. IMO. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 26, 2023 Author Report Share Posted November 26, 2023 20 minutes ago, Deezl Smoke said: No part numbers. But any hose you get, unless it's in a sealed bag, be sure to blow air through it before installation to remove any cutting and pressing debris. Depending upon what type of ends Volvo uses, do not use any sort of sealing paste or tape unless it is a pipe thread fitting. IMO. Good advice. Thanks. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted November 26, 2023 Report Share Posted November 26, 2023 Carl, if you go to a hydraulics shop. tell them it's air hose so they don't give you steel braided line rated for 4,500 psi. Braided sheath is fine, but you don't need to be wrestling an overly stiff hose at your age........... Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 26, 2023 Author Report Share Posted November 26, 2023 3 hours ago, rickeieio said: Carl, if you go to a hydraulics shop. tell them it's air hose so they don't give you steel braided line rated for 4,500 psi. Braided sheath is fine, but you don't need to be wrestling an overly stiff hose at your age........... 😳😳 Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted November 27, 2023 Report Share Posted November 27, 2023 3 hours ago, SuiteSuccess said: 😳😳 Gotcha. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
Deezl Smoke Posted November 27, 2023 Report Share Posted November 27, 2023 20 hours ago, rickeieio said: Carl, if you go to a hydraulics shop. tell them it's air hose so they don't give you steel braided line rated for 4,500 psi. Braided sheath is fine, but you don't need to be wrestling an overly stiff hose at your age........... 🤣 Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 28, 2023 Report Share Posted November 28, 2023 On 11/26/2023 at 1:21 PM, rickeieio said: Carl, if you go to a hydraulics shop. tell them it's air hose so they don't give you steel braided line rated for 4,500 psi. Braided sheath is fine, but you don't need to be wrestling an overly stiff hose at your age........... At his age, he just gets Donna to fix it. Kinda like another old timer I know... Quote 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 28, 2023 Author Report Share Posted November 28, 2023 3 hours ago, GeorgiaHybrid said: At his age, he just gets Donna to fix it. Kinda like another old timer I know... Now I’m feeling ganged up on. Feel like it’s “pick on the old guy” week, lol. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 29, 2023 Author Report Share Posted November 29, 2023 On 11/25/2023 at 10:34 AM, Darryl&Rita said: Take it off, find a hose/hydraulic shop, wait at the counter for 1/2 cup of coffee, pay on your way out. No part number needed. Easier said than done. RandyA in a previous thread described trying to remove the hose and ended up having to cut and destroy it in the process. Would like to one in hand prior to having to go to that extreme. I have another dealer source that may be willing to give me the number. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted November 29, 2023 Report Share Posted November 29, 2023 Length really isn't an issue, providing it's long enough. Cut it in two, get it removed any way you can, and get the new one a couple inches longer. I'd bet dollars to do-nuts, that how most shops do it. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
hatrack Posted November 30, 2023 Report Share Posted November 30, 2023 (edited) On 11/24/2023 at 2:18 PM, SuiteSuccess said: 2006 Volvo VNL 780 with D12D motor. Air dryer part number is Wabco 4324210090. There are two parts to the air compressor discharge line that feeds to the air dryer itself. The first is metal which circles to the drivers side from the passenger side location of the compressor. The second piece is rubber (shrouded) hose from a compression fitting on the steel line and connects into the dryer. I need to find a part number for that hose if anyone has it. Carl, This is a gif of the compressor and hose for my 2020 D13. If the hose looks the same he numbers are: 3 990424 1 hose assembly M12x1.5*6*225 4 977639 2 nipple M12X1,5 6MM L I can add vin's to my customer portal and probably get the #'s for your exact truck. https://class8truckparts.com/volvo-hose-assembly-990424.html or https://www.truckpartcenter.com/p-volvo-990424-hose-assembly-990424 Ken.... Edited November 30, 2023 by hatrack added links Quote 2024 DRV Fullhouse JX450 2017 DRV Fullhouse JX450 2020 Volvo VNR 42-640, D13, 455hp, Ishift, 189"wb, factory single, ET Junior Hitch @ 195", Jacklopee, Directlink 2016 GMC 3500 Denali DRW, CC, LB, Curt 25k, Sold Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 30, 2023 Author Report Share Posted November 30, 2023 12 hours ago, hatrack said: Carl, This is a gif of the compressor and hose for my 2020 D13. If the hose looks the same he numbers are: 3 990424 1 hose assembly M12x1.5*6*225 4 977639 2 nipple M12X1,5 6MM L I can add vin's to my customer portal and probably get the #'s for your exact truck. https://class8truckparts.com/volvo-hose-assembly-990424.html or https://www.truckpartcenter.com/p-volvo-990424-hose-assembly-990424 Ken.... Thanks so much. I will personal message my vin# to you. What you show looks correct. Going to try and get some pictures today and will send also. Was going to do it yesterday but was cold and windy. These old bones don’t like the cold. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
spindrift Posted November 30, 2023 Report Share Posted November 30, 2023 On 11/25/2023 at 6:42 PM, SuiteSuccess said: Made a call to dealer. They can get it but 3 weeks unless I pay overnight freight, hence why I wanted part # to check couple other places. Local dealer doesn’t like to give out part numbers. (BTW you’re still my bud. Just kidding wit ya). I can validate your concern. That guy needs to be watched like a hawk on a diet. Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
hatrack Posted December 2, 2023 Report Share Posted December 2, 2023 Carl, I got the vin in the system, have to wait for Volvo to approve it. I'll get the info as soon as they do. Ken.... Quote 2024 DRV Fullhouse JX450 2017 DRV Fullhouse JX450 2020 Volvo VNR 42-640, D13, 455hp, Ishift, 189"wb, factory single, ET Junior Hitch @ 195", Jacklopee, Directlink 2016 GMC 3500 Denali DRW, CC, LB, Curt 25k, Sold Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 4, 2023 Author Report Share Posted December 4, 2023 Just want to ask about another option to cover my bases. Both top and bottom connections are seized. Going to try heat and PB Blaster. If all else fails removing the hose, could I simply cut the rusted connection end off and have a new end fabricated and splice into the remaining hose with a barbed connection? If so would want something better than regular hose clamps. Max pressure in that feed line to dryer is 185 psi and mine “chuffs” at 135 psi. BTW I’m replacing the air dryer also so getting the rusted connection off will not be necessary. Will get new connections. Understand this solution would be last resort only. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted December 4, 2023 Report Share Posted December 4, 2023 Carl, Do you have a set of flare nut crowfoot wrenches? Put them on a pair of 24" ratchets, put some heat on the larger connection nut and they should break loose. Quote 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 4, 2023 Author Report Share Posted December 4, 2023 11 minutes ago, GeorgiaHybrid said: Carl, Do you have a set of flare nut crowfoot wrenches? Put them on a pair of 24" ratchets, put some heat on the larger connection nut and they should break loose. Have some crowfoot. Not sure if they are large enough. Will check. May be time for more tools. 😊 Just can’t see paying shop $185 an hour when I could spend on tools. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
