jenandjon Posted October 25, 2020 Report Share Posted October 25, 2020 My truck was singled when I got it. The previous owner simply pulled the front rear and extended the drive shaft. My camper at the time was very light but I did get a little vibration when it pulled harder running across the Rockies. I dont think anything of it. Its an old truck with 1.3 million miles on it. Forward ahead a couple years I got a newer much larger trailer. I take off from the dealer and as I'm rowing the gears I got a vibration. I recognize it immediately as the same vibration I got in the mountains. I get up to speed, set the cruise its fine. Come to a hill and it pulls harder the vibration starts up again. So I'm thinking transmission. I call a mechanic friend of mine to see if hes got anything used laying around. I go through the whole spiel. Everything I just said above. He asks if they changed the angle of the rear end when it was singled. Because the rear rear sits at a different angle than the front rear. You need a 12 degree pitch. He thinks when I'm pulling harder its flexing the rear end changing the drive line angle causing vibration. I said OK I have to check that out. I didn't drain my low points in time and they froze I have to pull the camper in the shop anyway. We just happen to have one of the farm trucks in there right now so I pull up side by side and get the creeper out. Sure as I'm sitting there they are different. So I call the guy I bought it from and asked if he changed anything. No he didn't think to change anything. So he walks over to his truck and says yea they are different angles but it never even crossed his mind that it would make a difference. I need to get a hold of Freightliner and find out exactly what the drive line angle is suppose to be then Figure out what mine is. I dont know exactly how to do that. I will be posting pictures below off my phone. They are not very good but if you know what you are looking at you will see there is a difference. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
jenandjon Posted October 25, 2020 Author Report Share Posted October 25, 2020 I cant post pics because I got a new phone and apparently they are too big. I value my life enough not to wake Jen at this hour on a weekend to fix it. Pics will have to wait. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Chalkie Posted October 25, 2020 Report Share Posted October 25, 2020 27 minutes ago, jenandjon said: I cant post pics because I got a new phone and apparently they are too big. I value my life enough not to wake Jen at this hour on a weekend to fix it. Pics will have to wait. Put your pics on an external site, like Dropbox or Google Photos and then embed them here and it will not matter what size the pics are. In fact, Google Photos by default optimizes them for space saving. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 25, 2020 Report Share Posted October 25, 2020 We don't really need pics, but they will help the newcomers. Get in touch with a driveline shop, have your u-joint size ready, and they will be able to tell you what angles that joint wants. The angles are measured off the face of the yoke. The reason I'm saying to get ahold of a driveline shop, instead of Freightliner, is because you don't have a stock driveshaft anymore. When the axle was removed, the shaft had to be modified by replacing the rear yoke. The yokes are different on the front axle and rear. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
NeverEasy Posted October 25, 2020 Report Share Posted October 25, 2020 2 hours ago, jenandjon said: I cant post pics because I got a new phone and apparently they are too big. I value my life enough not to wake Jen at this hour on a weekend to fix it. Pics will have to wait. Follow Jack's instructions. Works great. Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
NeverEasy Posted October 25, 2020 Report Share Posted October 25, 2020 There is alignment and u-joint phasing. Might be out-of-phase if the lengthened drive shaft got welded out-of-phase. Do a search on "driveline u joint alignment". Lots of info. There is a driveline operating angle calculator here. https://spicerparts.com/calculators/driveline-operating-angle-calculator Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
jkoenig24 Posted October 25, 2020 Report Share Posted October 25, 2020 " I value my life enough not to wake Jen at this hour on a weekend to fix it." You are indeed a WISE man.......... Quote Link to comment Share on other sites More sharing options...
jenandjon Posted October 25, 2020 Author Report Share Posted October 25, 2020 3 hours ago, NeverEasy said: Follow Jack's instructions. Works great. Thats what I use. It says the file size is too big. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
NeverEasy Posted October 26, 2020 Report Share Posted October 26, 2020 19 hours ago, jenandjon said: Thats what I use. It says the file size is too big. In Windows, open PAINT, click on resize. Don't know about MAC. Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
Scrap Posted October 27, 2020 Report Share Posted October 27, 2020 Call Freightliner, buy the axle seats and u-bolts that match the angle the fwd axle used to have (2,3,4 ~ish deg). I don't know Freightliner, but maybe the original fwd axle seats will work on a rear axle. The axle slant needs to get to near the engine slant or it won't work out. Set the axle, then you can do all the math (or hold/measure/adjust with a crane) and lower the centerbearing to get the perfect angles. Or maybe with the axle set right it'll be close enough.... Shaft angles need to target a compound 3 deg, shouldn't be much over 5deg if overdrive trans. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted October 27, 2020 Author Report Share Posted October 27, 2020 6 hours ago, Scrap said: Call Freightliner, buy the axle seats and u-bolts that match the angle the fwd axle used to have (2,3,4 ~ish deg). I don't know Freightliner, but maybe the original fwd axle seats will work on a rear axle. The axle slant needs to get to near the engine slant or it won't work out. Set the axle, then you can do all the math (or hold/measure/adjust with a crane) and lower the centerbearing to get the perfect angles. Or maybe with the axle set right it'll be close enough.... Shaft angles need to target a compound 3 deg, shouldn't be much over 5deg if overdrive trans. Ok Thanks. I will do some investigating. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
lappir Posted October 27, 2020 Report Share Posted October 27, 2020 I'm going to have to replace my leveling valve lever again. Last time I did it I didn't realize how specific it was and got some vibrations. Luckily I found a shop that noticed it and adjusted it correctly. This one is going to cost me more though. If you have ever driven many miles with it just hanging you know what I mean. Embarrassed to say I never thought it was why the road was so rough when it looked so new. Hopefully a lesson learned. If something doesn't feel right it isn't. I missed my GOAL opportunity until I was at my destination. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Ray,IN Posted October 27, 2020 Report Share Posted October 27, 2020 (edited) On 10/25/2020 at 8:39 AM, jenandjon said: I cant post pics because I got a new phone and apparently they are too big. I value my life enough not to wake Jen at this hour on a weekend to fix it. Pics will have to wait. I use http://photoposting.is-great.net/?i=2 or https://postimages.org/ Another possibility is the driveshaft is out of time = unbalanced as a result of being taken apart, upon re-assembly the timing marks were not matched. Edited October 27, 2020 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
jenandjon Posted October 27, 2020 Author Report Share Posted October 27, 2020 (edited) this is the HDT. Remember I am using the rear rear. It is still in its factory position. This is the work truck. Edited October 27, 2020 by jenandjon Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
jenandjon Posted October 27, 2020 Author Report Share Posted October 27, 2020 Try again. This is the work truck front rear end. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
jenandjon Posted October 27, 2020 Author Report Share Posted October 27, 2020 From what I can tell with what I learned from google and my cheap harbor freight protractor the operating angle of my rear u joint is at 15 degrees. What I earned for Driveline angles 101, 15 degrees is not even on the chart. Very interesting video on there. https://shiftsst.com/blog/post/driveline-angles.html Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
beemergary Posted October 31, 2020 Report Share Posted October 31, 2020 There is no set degree but less is better. You want the trans yoke to be parallel to the rear end pinion yoke. The thing is torque under load will force the rear end up so atleast 1 degree down can be important. Get a degree angle finder. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted November 2, 2020 Author Report Share Posted November 2, 2020 (edited) We are back doing field work now so it be a while before I get to work on this again. Edited November 2, 2020 by jenandjon Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
