SuiteSuccess Posted April 29, 2018 Report Share Posted April 29, 2018 Winters over (hopefully) but need to buy a heated water hose for next year. I know Camco, Pirit make some. If you have used one your recommendation or did you make your own with heat tape? 25’ or 50’? Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 29, 2018 Report Share Posted April 29, 2018 Used to make my own, now we go South. 😉 Pre-made are spendy. Link to comment Share on other sites More sharing options...
SWharton Posted April 29, 2018 Report Share Posted April 29, 2018 Heat tape has got to be less and if it ceases to function you can easily get new heat tape. Link to comment Share on other sites More sharing options...
Nigel Posted April 29, 2018 Report Share Posted April 29, 2018 If you NEED a heated water hose you are too far north. Carl, when we were in Crossville this year we just put some water in the tank and disconnected the hose overnight when the big freeze hit. Do you go out over the winter? Thanks again for the wonderful rally and the all inclusive weather. Nigel Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 29, 2018 Author Report Share Posted April 29, 2018 6 minutes ago, Nigel said: If you NEED a heated water hose you are too far north. Carl, when we were in Crossville this year we just put some water in the tank and disconnected the hose overnight when the big freeze hit. Do you go out over the winter? Thanks again for the wonderful rally and the all inclusive weather. Nigel Nigel, Others here did the same as you but we are planning on being in some colder climates next year and would really like to have one available if longer period of freezing weather. Looked at the “nofreezehose” but it’s very expensive. The Camco Steve lent me worked well but the covering seemed cheap. Link to comment Share on other sites More sharing options...
rickeieio Posted April 29, 2018 Report Share Posted April 29, 2018 Going south can be "iffy". We ducked into a campground on I-10 just west of Lafayette, LA on about Jan.16 this winter. Next two mornings the temp was 17f. Fortunately, we'd filled the fresh tank the day before. I know, we didn't go far enough south. But they closed the interstate due to ice. Unfortunate timing. Link to comment Share on other sites More sharing options...
hone eagle Posted April 30, 2018 Report Share Posted April 30, 2018 Hardware up here sells a hose for the dads that make ice rinks for the kids ,leave it outside full of water dont hurt it. Link to comment Share on other sites More sharing options...
rdickinson Posted April 30, 2018 Report Share Posted April 30, 2018 . Link to comment Share on other sites More sharing options...
HERO Maker Posted April 30, 2018 Report Share Posted April 30, 2018 If you're talking just an overnight, or even a couple of days possible freeze temp, and you are on full hookups, just keep the water running real slow with your grey valve open, and your tank heat pads on. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 30, 2018 Report Share Posted April 30, 2018 If you decide to build your own, spring for self regulating heat tape. It can cross over itself, or run along side. It's more expensive, but lasts a lot longer. Edit to add: It's available in bulk length, so every install is a custom job. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted April 30, 2018 Report Share Posted April 30, 2018 I did my own heated hose. Heat tape and insulation. It worked until we got to North Dakota. With having 2 filters and a softener inline, we didn't chance it at 3 degrees, and 2 straight weeks below freezing. The No Freeze hose, https://nofreezewaterhose.com/blogs/news/why-having-a-no-freeze-rv-hose-is-so-essential while expensive works great if you are in freezing temps for a prolonged time. For a short overnite or maybe a 2-3 day event, the Camco or Pirit works fine. Link to comment Share on other sites More sharing options...
JPL Posted April 30, 2018 Report Share Posted April 30, 2018 Carl I keep a heat tape in the 5er and I wrapped the hose while in Crossville. Took 30 min. I don't think it really got cold enough to freeze but I think it was good enough had it really gotten a little colder. I agree that if it gets cold enough to freeze it's time to head south. My heat tape is 25' and that seems to work . Have used it several times. It has a light indicator on it so I at least know it is getting power. I try not to be where it's cold so the few times I get caught it has worked fine. But if I planned on being in cold weather for a long (3 days or more with a couple of CG's) time I would find something better. Thanks again for a great ECR! Pat The Old Sailor Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 30, 2018 Author Report Share Posted April 30, 2018 Thanks everyone for the discussion. Link to comment Share on other sites More sharing options...
Imurphy907 Posted May 1, 2018 Report Share Posted May 1, 2018 I have always made my own. Potable water hose the length I need it, And a 2 wire heat tape just a bit longer than that. I put 1 wrap on the faucet and use electrical tape to hold the heat tape to the hose. Making sure the thermostat is just outside of the wet bay but having a bit of heat tape going inside. Then use the split foam pipe insulation to wrap it all. Got me thru an Alaskan winter. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 1, 2018 Author Report Share Posted May 1, 2018 3 hours ago, Imurphy907 said: I have always made my own. Potable water hose the length I need it, And a 2 wire heat tape just a bit longer than that. I put 1 wrap on the faucet and use electrical tape to hold the heat tape to the hose. Making sure the thermostat is just outside of the wet bay but having a bit of heat tape going inside. Then use the split foam pipe insulation to wrap it all. Got me thru an Alaskan winter. Thanks that’s what I was thinking. Link to comment Share on other sites More sharing options...
tyates007 Posted May 2, 2018 Report Share Posted May 2, 2018 I always made mine the same as above. Looks nice and very protected. We stayed through 2 VERY cold Idaho winters and had no issues Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 2, 2018 Report Share Posted May 2, 2018 16 hours ago, Imurphy907 said: I have always made my own. Potable water hose the length I need it, And a 2 wire heat tape just a bit longer than that. I put 1 wrap on the faucet and use electrical tape to hold the heat tape to the hose. Making sure the thermostat is just outside of the wet bay but having a bit of heat tape going inside. Then use the split foam pipe insulation to wrap it all. Got me thru an Alaskan winter. I can't believe I forgot the biggest benefit of self-regulating tape. No need for thermostats. On top of that, they're available in a wide range of wattages, from 5w/ft to 15w/ft are fairly common locally, with higher or lower available on order. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 2, 2018 Author Report Share Posted May 2, 2018 10 hours ago, Darryl&Rita said: I can't believe I forgot the biggest benefit of self-regulating tape. No need for thermostats. On top of that, they're available in a wide range of wattages, from 5w/ft to 15w/ft are fairly common locally, with higher or lower available on order. Darryl, What wattage did you use? I see it can be bought from 3watts/foot up to 12 watts/foot. Also do you just wire into a junction box on the end or a controller? My camping might get down to low 20’s to teens but don’t think I will be in a climate down to zero. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 2, 2018 Report Share Posted May 2, 2018 Temp dependent, along with the insulation on top. A typical line used in northern Alberta, where -40 isn't unusual, is 8-10 watts. This is wrapped with a layer of Reflectix. The tape is wrapped in a spiral, as close as 6" between wraps. If it freezes, the insulation can be peeled back, and another heat tape line added. A huge value of self-regulating tape is it's robustness. If regular tape is overlapped, it'll burn out where they touch. Self-regulating will automatically limit it's heat at that location, & avoid burning out. Connection kits are available, they add a connection box where a piece of extension cord can connect. The Red neck way involves a male cord end installed directly to the heat tape. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 2, 2018 Author Report Share Posted May 2, 2018 1 hour ago, Darryl&Rita said: Temp dependent, along with the insulation on top. A typical line used in northern Alberta, where -40 isn't unusual, is 8-10 watts. This is wrapped with a layer of Reflectix. The tape is wrapped in a spiral, as close as 6" between wraps. If it freezes, the insulation can be peeled back, and another heat tape line added. A huge value of self-regulating tape is it's robustness. If regular tape is overlapped, it'll burn out where they touch. Self-regulating will automatically limit it's heat at that location, & avoid burning out. Connection kits are available, they add a connection box where a piece of extension cord can connect. The Red neck way involves a male cord end installed directly to the heat tape. Thanks Darryl. Link to comment Share on other sites More sharing options...
