Five Wood Posted May 8, 2017 Report Share Posted May 8, 2017 I buy Camco water hoses from Wallmart. In the past, after six months or so the male fitting would start to leak where the fitting is "pressed" together. This never bothered me, as I figured it was a good reminder to change out the hoses. But lately I'm finding that after one or two moves the male fitting starts to leak. It's not a massive leak, It's just a drip that can't be stopped. I would guess that it's just hard water that deposits calcium in that fitting. The bottom line here is. . . does anyone have a recommendation on a water hose that will last six months without leaking? I think it's a good idea to change out your water hose at least yearly. But I would like to get 60 or 90 days out of one. Jim JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
Kirk W Posted May 8, 2017 Report Share Posted May 8, 2017 I just replace the hose ends with a replacement part from Lowe's that uses a hose clamp. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
SWharton Posted May 8, 2017 Report Share Posted May 8, 2017 We buy our hoses from RV Water Filter Store, he has quality hoses and we have had ours for many years, never a leak. He will also make hoses to any length you want. Might be more $$$ but we feel well worth it. He also has water filter components, pressure regulators etc. Give him a call he knows his stuff. https://www.rvwaterfilterstore.com/ Link to comment Share on other sites More sharing options...
mptjelgin Posted May 9, 2017 Report Share Posted May 9, 2017 An enthusiastic second on the RV Water Filter Store. You get 200 psi hose, machined brass or stainless steel fittings, and any length you want. We've been full-timing for over 7 years with our first set of hoses from them, and they show no signs of needing to be replaced. Just curious: Why do you think it a good idea to replace hoses yearly? Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
Five Wood Posted May 9, 2017 Author Report Share Posted May 9, 2017 12 hours ago, Kirk Wood said: I just replace the hose ends with a replacement part from Lowe's that uses a hose clamp. Kirk, I've done that before. I guess I'll just start doing that again. It just seems to me they should be able to make a hose that doesn't leak. 10 hours ago, mptjelgin said: An enthusiastic second on the RV Water Filter Store. You get 200 psi hose, machined brass or stainless steel fittings, and any length you want. We've been full-timing for over 7 years with our first set of hoses from them, and they show no signs of needing to be replaced. Just curious: Why do you think it a good idea to replace hoses yearly? I like to change mine out before they start to get brittle. An old Camco water hose will get stiff and brittle. When you bend it you can hear it crack. It's my theory that the inside of the hose may be cracking, which may allow pieces of plastic to be introduced into your system. That theory may or may not be correct, but a new hose is an inexpensive way to eliminate that problem. Jim JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
Kirk W Posted May 9, 2017 Report Share Posted May 9, 2017 Has anyone tried making up their own potable water hose from something like the "food grade" hoses carried by Lowe's or other home & lumber stores? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 9, 2017 Report Share Posted May 9, 2017 36 minutes ago, Five Wood said: I like to change mine out before they start to get brittle. Jim Well my RV Water Filter Store hoses for the trailer are 11 years old with no indication of any deterioration. If you do the math, cheap hoses are too expensive. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
SWharton Posted May 9, 2017 Report Share Posted May 9, 2017 x2 Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 9, 2017 Report Share Posted May 9, 2017 If the hose is good , I use this type replacement end . They last forever , so when the hose craps out for good , they can be used for the next repair . But , I haven't had to make a repair to our potable hose , which I found strung out along the shore of a lake we hosted a camp on more than 6 years ago . Talk about cost effective . Goes around , comes around . Link to comment Share on other sites More sharing options...
jblo Posted May 16, 2017 Report Share Posted May 16, 2017 If I had to replace a hose yearly because it was deteriorating, believe I would stop buying them. But, have had a white water hose with blue stripe that I believe is a Camco, and no problem with it for over 10 years. Maybe quality has gone down. Joe Link to comment Share on other sites More sharing options...
Pappy Yokum Posted May 16, 2017 Report Share Posted May 16, 2017 On 5/8/2017 at 4:21 PM, SWharton said: We buy our hoses from RV Water Filter Store, he has quality hoses and we have had ours for many years, never a leak. He will also make hoses to any length you want. Might be more $$$ but we feel well worth it. He also has water filter components, pressure regulators etc. Give him a call he knows his stuff. https://www.rvwaterfilterstore.com/ Ditto the above. They supply hoses in whatever length you want with your choice of brass or stainless couplings. Have used them for years, *NEVER* had a coupling fail or leak. Well worth the extra cost - which (IMO) is minimal for the quality of the product. BTW - apparently the original owners retired a couple of years ago, hopefully the business continues in good hands! . Link to comment Share on other sites More sharing options...
Big Greg Posted May 16, 2017 Report Share Posted May 16, 2017 Another recommendation for hoses from the RV Water Filter Store, ours are 8+ years old and never a problem. It's white outside with a clear inner hose, you will pay more but they last a loooong time. Greg Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
Ray,IN Posted May 18, 2017 Report Share Posted May 18, 2017 Oddly enough I was thinking about this today. Looked at one of those "as seen on TV" metal encased hoses at Menards; began reading the information and spied "WARNING" this hose contains chemicals known to be carcinogenic by the state of California. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
budwizer Posted May 20, 2017 Report Share Posted May 20, 2017 I bought some of these from Walmart. They are made by Orbit. Easy to use, cheap, and so far they haven't leaked. 1995 Holiday Rambler Imperial DP2003 Suzuki Grand Vitara Link to comment Share on other sites More sharing options...
The Quiet Assassin Posted May 22, 2017 Report Share Posted May 22, 2017 My hoses which are blue and white striped were bought from Walmart 10 years ago and are still leak free. I suspect the reason for their longevity is their lack of UV exposure. I use them to fill the tanks then put them away. FT since September 2007 Safari Trek + M/C http://johncarolandcharro.blogspot.com/ Link to comment Share on other sites More sharing options...
chevy3500 Posted May 22, 2017 Report Share Posted May 22, 2017 On 5/17/2017 at 10:24 PM, Ray,IN said: Oddly enough I was thinking about this today. Looked at one of those "as seen on TV" metal encased hoses at Menards; began reading the information and spied "WARNING" this hose contains chemicals known to be carcinogenic by the state of California. Everything is known to cause cancer in California Link to comment Share on other sites More sharing options...
Barbaraok Posted May 22, 2017 Report Share Posted May 22, 2017 3 minutes ago, chevy3500 said: Everything is known to cause cancer in California The dose makes the poison. California just protects its people better than other states. Look at incidence of Cancer in Louisiana - wouldn't want to live there. Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
bobsallyh Posted May 22, 2017 Report Share Posted May 22, 2017 budwizer, glad to know they are working for you. I saw them but with the "multiple size fit" I was concerned about them sealing. The fitting is like a fitting for electrical Liquid Tight. I'll have to try some. Link to comment Share on other sites More sharing options...
