GlennWest Posted April 29, 2016 Report Share Posted April 29, 2016 Truck been setting weeks now. Going to put charge on it. Is the jump start lug under hood good spot. Or do I need to go to batteries 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Star Dreamer Posted April 30, 2016 Report Share Posted April 30, 2016 For charging our batteries on our Freightliner I have just gone to the batteries. I have not looked for a jump start lug so can't tell you where it is at. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
GlennWest Posted April 30, 2016 Author Report Share Posted April 30, 2016 On mine on driver side, raise hood and it is close to latch. I have to remove fairing to get to batteries. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lazysusan Posted April 30, 2016 Report Share Posted April 30, 2016 Positive and negative on starter works for charging and boosting Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted April 30, 2016 Report Share Posted April 30, 2016 The jump start lugs will work just fine. That is what they are for. 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
Phil D Posted April 30, 2016 Report Share Posted April 30, 2016 Truck been setting weeks now. Going to put charge on it. Is the jump start lug under hood good spot. Or do I need to go to batteries As GeorgiaHybrid said, Glenn, I've had good success with using the jump start lugs on my truck for charging/maintaining the batteries. Phil 2002 Teton Royal Aspen 2003 Kenworth T2000 - Cat C12 380/430 1450/1650, FreedomLine, 3.36 - TOTO . . . he's not in Kansas anymore. ET Air Hitch Link to comment Share on other sites More sharing options...
GlennWest Posted April 30, 2016 Author Report Share Posted April 30, 2016 That's what I'm using. After I posted I traced it down. Runs straight to battery and starter. Thanks everyone. Pulling out Monday for south Texas. Be first tow with hdt 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
peety3 Posted May 1, 2016 Report Share Posted May 1, 2016 Jump start lugs are probably positioned so they meet two "requirements": safe separation from each other (to prevent arcs) and relatively close to starter (to avoid losses in long copper runs). Batteries get positioned where they're out of the way, out of the spray, and easier to replace. Putting your charger on the jump start lugs probably results in a little bit of resistive loss in the cabling, but if your charger is strong enough, 90% of strong enough is probably still strong enough. Link to comment Share on other sites More sharing options...
pugsly Posted May 1, 2016 Report Share Posted May 1, 2016 I leave my truck on a maintainer most of the time when it is just sitting. I figure it is better to keep the batteries topped up. Link to comment Share on other sites More sharing options...
GlennWest Posted May 1, 2016 Author Report Share Posted May 1, 2016 I leave my truck on a maintainer most of the time when it is just sitting. I figure it is better to keep the batteries topped up. Solar or 110v? 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
pugsly Posted May 1, 2016 Report Share Posted May 1, 2016 Solar or 110v? When I have shore power it is 110v. When on solar, my Blue Sky charge controller has an aux charge mode that switches over to charging/maintaining the start battery after the house batteries are topped off. It's a pretty slick system. Not a big deal when we are on the road, but my rig sits for several months at a time because we are not fulltime yet. Link to comment Share on other sites More sharing options...
GlennWest Posted May 1, 2016 Author Report Share Posted May 1, 2016 Lots of parks I'm in truck can't be on site with me. Like here it is at park but not on my site. I had to run 200 feet of cord to charge. I will be getting solar for it. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Star Dreamer Posted May 1, 2016 Report Share Posted May 1, 2016 Glenn, do you have a way to take a picture of your jump lugs and post them? I checked our truck and I only see the posts on the starter, no other lugs on the drivers side under the hood that I could see. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
pugsly Posted May 1, 2016 Report Share Posted May 1, 2016 Lots of parks I'm in truck can't be on site with me. Like here it is at park but not on my site. I had to run 200 feet of cord to charge. I will be getting solar for it. Sounds like a good idea. Solar maintainers are inexpensive - you don't need a huge amount to keep the batteries topped off. Link to comment Share on other sites More sharing options...
rpsinc Posted May 1, 2016 Report Share Posted May 1, 2016 Solar panels work great as battery maintainers. Since batteries at rest, disconnected will see a discharge of around 10%, it doesnt take much to compensate. I've used some from Harbor Freight that seem to have done the job good enough. And the price is reasonable. Just dont treat them too rough, they arent very robustly built. Marcel Link to comment Share on other sites More sharing options...
Ronbo Posted May 1, 2016 Report Share Posted May 1, 2016 I haven't used a charger on my truck for over 2 years. I have the harbor freight panels set up to keep batteries charged. The truck sat for 4 months this winter and restarted with no problems. It will probably sit another 4 months while,I do chemo this summer. Expect it to restart with no problems. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
GlennWest Posted May 1, 2016 Author Report Share Posted May 1, 2016 The 15 watt unit? 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
pugsly Posted May 1, 2016 Report Share Posted May 1, 2016 This is the one I use, it is hooked up to a motorcycle battery and some 12 volt computer case fans that I use to keep air circulating - http://www.amazon.com/Instapark®-Mono-crystalline-Solar-charge-controller/dp/B004FOGG1E Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 1, 2016 Report Share Posted May 1, 2016 Glenn, do you have a way to take a picture of your jump lugs and post them? I checked our truck and I only see the posts on the starter, no other lugs on the drivers side under the hood that I could see. Dave Similar to this. About the size around of a roll of dimes, or pennies. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
GlennWest Posted May 1, 2016 Author Report Share Posted May 1, 2016 Been raining all day. when i raise hood it is right at the latch, drivers side. Mine has a plastic cover over lug. It is a single lug. I ground at motor 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted May 2, 2016 Report Share Posted May 2, 2016 I put a 33 watt panel that I had on my truck with an inexpensive controller. It is usually fully charged and switched to float by noon at the latest. We are normally in the western or southwestern US where the sun is abundant but it has never failed to keep the batteries charged. I don't disconnect the batteries from the truck either. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Ronbo Posted May 2, 2016 Report Share Posted May 2, 2016 I used the 45 watt system but one of my panels is broken so now 30 watts Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
GlennWest Posted May 2, 2016 Author Report Share Posted May 2, 2016 ok, local Harbor Freight here only has 15 amp or less. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Ronbo Posted May 2, 2016 Report Share Posted May 2, 2016 Here you go http://t.harborfreight.com/45-watt-solar-panel-kit-10-pc-kit-68751.html Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
noteven Posted May 2, 2016 Report Share Posted May 2, 2016 in the winter we will park trucks for months with the batteries disconnected by switches. Turn the switch and the vehicle comes to life. ... battery cut off switches are a parked HDT's best friend vs yet another "system" to chase and maintain... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
