Ronbo Posted May 3, 2016 Report Share Posted May 3, 2016 With 2 positive wires and 2 negative wires from the battery bank and the wire to the computer, it would take a lot of rewiring to run it through one switch. Easier to use the solar panels. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
maveric Posted May 3, 2016 Report Share Posted May 3, 2016 With 2 positive wires and 2 negative wires from the battery bank and the wire to the computer, it would take a lot of rewiring to run it through one switch. Easier to use the solar panels. I just disconnected the 2 negative cables from the frame, and hooked them into one side of the disco switch, then made a new ground cable. Hooked it to the other side of the disco, and back to the original frame ground. Been running it this way for 3 years, with only 1 problem (bad connection at the switch). I also hardwired a battery charger (2/10a) to the battery bank. It plugs into the outlet inside the truck when hooked to shore power. I usually plug the truck into shore power the day before I need it, plug in the charger, and top off the system. Chris & Tonya '99 Freightliner FLD120, '01 Wabash Toyhauler (32' garage, 20' LQ) Link to comment Share on other sites More sharing options...
