GeorgiaHybrid Posted February 5, 2019 Report Share Posted February 5, 2019 This can get complicated in a hurry. The short answer is "it depends". More than likely, Henry has used A572-50 plate (possibly A36) or an AR plate (abrasive resistant) plate. Assuming A572-50 with a 50 ksi nominal yield. The steel jaws will be stronger, less brittle, but will be "softer" than cast iron. This will allow them to deform slightly under load but still be elastic enough to come back to their original state. The biggest advantage to steel vs cast iron is that steel will elongate and deform in a plastic state but not fail under overload where a #2 cast iron will become brittle and break under that same loading. Henry does a lot of good research before deciding on materials and with the addition of his new waterjet capacity, I think he is on the right track with his new jaw design. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Steve from SoCal Posted February 5, 2019 Report Share Posted February 5, 2019 Henry, Why are you welding the spacer? Just let it space the jaw, are you concerned about rock? Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 5, 2019 Author Report Share Posted February 5, 2019 7 hours ago, Steve from SoCal said: Henry, Why are you welding the spacer? Just let it space the jaw, are you concerned about rock? Steve If you look carefully on the cast jaws you can see that they are thicker in the areas where the pins go through and that thickness is only about 0.030-0.050" less than the opening in the head where they are mounted. The jaws operate almost 100% in shear (king pin tugging on these back and forth). The spacers are about 3/8 " thick or 3/4" between the two combined, that's a lot of unsupported distance in shear. That's why the spacers have to be welded to the jaws to form a homogeneous shaft hole with just a tiny gap on top and the bottom. In shear, gaps or unsupported distances are deadly and change the properties of the material over time which eventually results in stress cracks and failure. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 17, 2019 Author Report Share Posted February 17, 2019 Has the Old Goat gotten into loco weed, what the hell is he up to now (I think Jack knows) Link to comment Share on other sites More sharing options...
DesertMiner Posted February 17, 2019 Report Share Posted February 17, 2019 Let me make a guess.... would that be for one of those new fangled slider (moveable) HDT hitches? Link to comment Share on other sites More sharing options...
Jack Mayer Posted February 18, 2019 Report Share Posted February 18, 2019 1 hour ago, DesertMiner said: Let me make a guess.... would that be for one of those new fangled slider (moveable) HDT hitches? Nope. But it does have to do with hitches. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
rickeieio Posted February 18, 2019 Report Share Posted February 18, 2019 New way to mount an ET in a mini-van?😁 KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 18, 2019 Author Report Share Posted February 18, 2019 Close, at 425 pounds the plate is heavier than ET Jr., but lighter than ET Sr. Should be a good test for the effect on the minivan maneuvering. I'll probably hit the CAT scales to see what the load is with the "accessories" in front of the plate. Link to comment Share on other sites More sharing options...
Sculptor Posted February 18, 2019 Report Share Posted February 18, 2019 7 hours ago, phoenix2013 said: Close, at 425 pounds the plate is heavier than ET Jr., but lighter than ET Sr. Should be a good test for the effect on the minivan maneuvering. I'll probably hit the CAT scales to see what the load is with the "accessories" in front of the plate. How much can a Mocha Chino Frappe in the cupholder, and layer of fast food wrappers on the floor weigh? Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 22, 2019 Author Report Share Posted February 22, 2019 Just had to know it, it was worth $11.50. The only GVW spec I found on the Chrysler van (it must be a "secret") was this old one. We are tad over with 6360. Was concerned about the rear end at 3400, or actually the tires on the rear end. Wife just put 4 brand new Michelins on the car. Max weight rating on those is 1740 lbs per tire. WE ARE GOOD, got 40 pounds to spare on each tire. After all that's exactly what the RV industry does, they give you tires with 100 pounds to spare when you go towing. But we made it to Kansas and plate will be offloaded tomorrow. Interesting experience driving the van. Steering had to be done slowly and gently, sort of like leading a bride down the aisle to the altar. Link to comment Share on other sites More sharing options...
Seniramsu Posted February 23, 2019 Report Share Posted February 23, 2019 Guessing it might be part of newer type of suspension hitches that can handle some of the newer 40K trailers with pin weights around the 10K range?? 2013 Volvo 780 "Grunt" D13 I-Shift w/ ET Hitch 2016 Cyclone 4200 Link to comment Share on other sites More sharing options...
noteven Posted February 23, 2019 Report Share Posted February 23, 2019 Horizontal guillotine in a frontal collision? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 23, 2019 Author Report Share Posted February 23, 2019 Ouch🤣, I don't like that vision at all, the plate has been offloaded and delivered to the place to be "dealt with". More on that later Link to comment Share on other sites More sharing options...
Hot Rod Posted February 24, 2019 Report Share Posted February 24, 2019 On 2/23/2019 at 8:28 AM, noteven said: Horizontal guillotine in a frontal collision? That's no joke, and something to take seriously with cargo like that. Up here in the northern Ohio snow belt we tend to throw weight in the backs of the pickup trucks (and car trunks) in the winter for traction weight. Most folks us sandbags from the hardware store, but me being young, foolish, cheap and working for the propane company I grabbed a 24x36x2 concrete slab we used for tanks and tossed it in the back by the tailgate for traction. Then proceeded to get in that front end collision. The thing flew up just missed the top of the bed and hit the cab about 2" below the window and pushed the sheetmetal in 4". 2" higher it would have gone through the window and killed everybody. Lesson learned. So secure that heavy cargo even if it is inside and not going to fall out. Link to comment Share on other sites More sharing options...
noteven Posted February 25, 2019 Report Share Posted February 25, 2019 Strapping heavy stuff to seat mounts and the pallet itself will help absorb some energy as the cargo has to tear out the mounts to get airborne. I remember a 4 door 1500 GMC pickup being towed in after a front end kaboom. Young mom had no kids in the back. 1 inch plate hubby borrowed from his fab shop for traction came to rest against the backs of the front seats. Anyway done being the safety monitor back to the thread topic. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 27, 2019 Author Report Share Posted February 27, 2019 OK, where the hell is the Old Goat now? You can see the guy who is welding these in the far distance. He is holding two crane controllers at the same time to flip the whole structure 180 degrees over. Link to comment Share on other sites More sharing options...
sclord2002 Posted February 27, 2019 Report Share Posted February 27, 2019 Dang, Henry....are you building a bridge ???? Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
phoenix2013 Posted February 27, 2019 Author Report Share Posted February 27, 2019 They do that and more Tanks and parts are welded with a programmable welder that runs around in a circle to weld these. 144,000 square foot facility http://www.youngsweldinginc.com/. I've seen laser cutters, but this one will cut up to an inch and check the size of the table, 40 feet. They have a smaller one also and a plasma cutter that is even bigger and will do 3 inch plate. Also a three stage powder coat line, sand blast, phosphate wash and bake with a 90 foot bake oven at the end. Those big "bridge parts" go in to be powder coated. Link to comment Share on other sites More sharing options...
dblr Posted February 27, 2019 Report Share Posted February 27, 2019 You must feel like a kid in a toy store!!! 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
noteven Posted February 27, 2019 Report Share Posted February 27, 2019 The big question is: does anyone pound on steel with a hammer? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
sclord2002 Posted March 3, 2019 Report Share Posted March 3, 2019 Now, that is an impressive facility !! Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
phoenix2013 Posted March 3, 2019 Author Report Share Posted March 3, 2019 Yes Charlie, I showed you the laser cutter (they also have couple of smaller ones for small and thin stuff) and a plasma cutter which is something something to see running. I've seen jobs where the whole table was covered with a steel plate and with plasma head just running around, they don't watch these once set up.. Between these two the ET Hitch parts are just happening. Just spotted couple of other things they are working on. However, this morning, this ain't right, this is a Florida car, it's not supposed to see the white crap and then it showed me this, which is just WRONG! Link to comment Share on other sites More sharing options...
Parrformance Posted March 3, 2019 Report Share Posted March 3, 2019 Come home soon Henry, 85° today in Lakeland😎 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
phoenix2013 Posted March 6, 2019 Author Report Share Posted March 6, 2019 Powdercoated hitch parts as far as an eye can see Baked and ready to go to assembly Link to comment Share on other sites More sharing options...
1930harley Posted March 6, 2019 Report Share Posted March 6, 2019 Cool, I hope one of those hitches is mine! Anxiously awaiting its arrival Link to comment Share on other sites More sharing options...
