Jack L Posted May 18, 2021 Report Share Posted May 18, 2021 I am thinking of removing the gas furnace that is under our rv gas range and replacing it with a regular 20 " residential gas range which will give my wife much more oven space. Since the Trailer is in a permanent spot in the Florida Keys we never use it any way. Does any one see any thing wrong with that. I guess one of my questions is will the difference between natural gas and propane cause any problem Jack L Quote Link to comment Share on other sites More sharing options...
folivier Posted May 18, 2021 Report Share Posted May 18, 2021 Propane is at a higher pressure than natural gas so it will cause problems, possibly a fire. Look for a propane residential range. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted May 18, 2021 Report Share Posted May 18, 2021 There are ways to convert a stove from natural gas to propane, or if you are buying a new one, specify that you want it to operate on propane. There are still folks in farm and ranch country that have kitchen stoves that are set up for propane. Quote Link to comment Share on other sites More sharing options...
Chalkie Posted May 18, 2021 Report Share Posted May 18, 2021 When we were RV shopping we found some that were using Insignia ranges that had a 4-burner cooktop and a 3.73 cu.ft. oven (which is pretty good sized). You might see if you can find one of those. Quote Link to comment Share on other sites More sharing options...
Larry Burkett Posted May 18, 2021 Report Share Posted May 18, 2021 We looked at an Insignia range, and had our preferred service center order one for us several months ago. Called them yesterday and was told the factory still has not shipped it and can't give them a date when it will ship. We were supposed to have it installed next week. Quote Link to comment Share on other sites More sharing options...
lappir Posted May 20, 2021 Report Share Posted May 20, 2021 I know it's not your question, but I would convert to a Induction cooktop, especially in Florida. You will have much less heat to deal with that is wasted and causes cooling issues with your A/C, especially if you cook very much. I put in a Residential LP cook top in my home on wheels but use the countertop induction plates so much I built a cover to put over the Residential cooktop and haven't used it in 3 years. I am looking for a Induction cooktop, but want to change my inverter and batteries before making the change so I can be sure to have the abilities to use it almost all the time either in an RV park or on the road. Rod Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted May 20, 2021 Report Share Posted May 20, 2021 56 minutes ago, lappir said: I know it's not your question, but I would convert to a Induction cooktop, especially in Florida. You will have much less heat to deal with that is wasted and causes cooling issues with your A/C, especially if you cook very much. I put in a Residential LP cook top in my home on wheels but use the countertop induction plates so much I built a cover to put over the Residential cooktop and haven't used it in 3 years. I am looking for a Induction cooktop, but want to change my inverter and batteries before making the change so I can be sure to have the abilities to use it almost all the time either in an RV park or on the road. Rod Their only interest is a larger oven. The 120VAC dual induction units have 1 1,300W and 1 1,800W element, this means you can only use one at a time on a 15A breaker. For that reason we have 2 1,800W single element countertop units(Nuwave) so we may put them on different circuits and use one outside when needed. Quote Link to comment Share on other sites More sharing options...
Jack L Posted May 20, 2021 Author Report Share Posted May 20, 2021 12 hours ago, lappir said: I know it's not your question, but I would convert to a Induction cooktop, especially in Florida. You will have much less heat to deal with that is wasted and causes cooling issues with your A/C, especially if you cook very much. I put in a Residential LP cook top in my home on wheels but use the countertop induction plates so much I built a cover to put over the Residential cooktop and haven't used it in 3 years. I am looking for a Induction cooktop, but want to change my inverter and batteries before making the change so I can be sure to have the abilities to use it almost all the time either in an RV park or on the road. Rod Not interested. We need a bigger oven Jack L Quote Link to comment Share on other sites More sharing options...
RV_ Posted May 20, 2021 Report Share Posted May 20, 2021 (edited) Let's remember the fridge and water heater, also use the gas lines in your rig. You can , if indeed you are going to keep it stationary just buy a natural gas range of the size you want and hire a plumber to run a line to your range only, then you can keep the propane lines and cylinders for them in case. Since you are stationary you might consider a residential refrigerator as well, and you could run an external 50 gallon Nat gas water heater with an insulation jacket. Lots of options and both residential fridges and water heaters are cheaper to replace than Propane/12volt/electric RV appliances. If only a range and you have NatGas lines to your parking place, just run a line to the range. Or convert the whole rig. More info here: https://www.propane101.com/lpgasapplianceconversions.htm Edited May 28, 2021 by RV_ Quote Link to comment Share on other sites More sharing options...
Star Dreamer Posted May 21, 2021 Report Share Posted May 21, 2021 We had a GE 24" apartment size range installed in our 5th wheel when we had it built. Much larger oven than the typical RV units. It was converted to LP gas by the trailer factory and has been working great. You will need to have any natural gas ones converted to LP if you plan to use your regular LP gas supply. One item, we did notice is the broiler is electric (Broiling is done in the oven and not in the drawer below) so we need to watch to make sure we are on shore power or generator when broiling, not sure how long our batteries would last if using our inverter. Quote Link to comment Share on other sites More sharing options...
Jack L Posted May 21, 2021 Author Report Share Posted May 21, 2021 I already have a big residential electric refrig. And I found out yesterday from my local Propane dealer that it is a simple procedure to convert a store bought natural gas range to burn LP gas. He said you can request the store to do it , have a plumber do it , or do it myself. (Just make sure I get the conversion kit) The only other thing I have in the trailer that has gas is the electric/propane water heater, and we keep it on electric continuously Thanks to all for your comments and answers Jack L Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted May 22, 2021 Report Share Posted May 22, 2021 FWIW a few natural gas appliance brands cannot be converted to LP, keep that in mine when shopping. Quote Link to comment Share on other sites More sharing options...
Jack L Posted May 22, 2021 Author Report Share Posted May 22, 2021 14 hours ago, Ray,IN said: FWIW a few natural gas appliance brands cannot be converted to LP, keep that in mine when shopping. Thanks, I didn't know that Jack L Quote Link to comment Share on other sites More sharing options...
Kirk W Posted May 22, 2021 Report Share Posted May 22, 2021 (edited) Having had a gas stove converted from natural gas to propane before, I strongly suggest that you read this link from petro.com before you begin. There us also a good article from the Ferrell Gas website. Quote Unlike, natural gas appliances that operate at pressures around 7 inches of water column (WC) or 14.9 millibars, 1743 Pa, or about 0.25 psi (pounds per square inch, a common operating pressure range for propane (liquid petroleum or LP gas) appliances is 10 – 11 inches WC or 27.4 millibars, 2491 – 2739 Pa or about 0.36 – 0.40 psi. Edited May 22, 2021 by Kirk W Add a little more information Quote Link to comment Share on other sites More sharing options...
