Sculptor Posted December 23, 2020 Report Share Posted December 23, 2020 Hi folks, we have a wired camera system from RVS. Currently we have 2 cameras with room to add more. I have removed the camera from the high mounted position on the back of the cab. I want to mount in front of the hitch. Many of you have done this also. I am sure I will have to fab some kind of a frame or base. I might be able to mount directly to the ET hitch. I would be interested to see photos by those who have done this if you don’t mind taking the time to post them. Thanks in advance. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted December 23, 2020 Report Share Posted December 23, 2020 Antenna mag mount. Put it where you want, move it out of the way when you need. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Chad Heiser Posted December 23, 2020 Report Share Posted December 23, 2020 I put mine on a simple hing mounted to the bed in front of the hitch. Most of the time it is up and pointed at the hitch. If I am using the bed to haul something (when not towing), I can fold the camera down into the hitch tunnel and out of the way. I don’t have any pictures of it right now, but I can get a couple later if you are interested. I thought about going with the magnetic mount similar to what others use, but chose not to. That particular camera is dedicated to hitching on my truck. I have other cameras for other things, so I can dedicate this one to just hitching. For me it is important to keep that camera directly lined up with the center of the hitch. I have a stripe painted on the pin box of my trailer and there is a bolt centered on the hitch head of my hitch. When I hitch, I simply line these two things up and I never miss. If I had a magnetic mounted camera, the camera wouldn’t necessarily always be in the same place and it wouldn’t be as easy to line up my guide points for hitching. I’m sure I could mitigate this with some markings on the bed to make sure the magnet got put back in the same spot each time, but it would take more effort than my hinged solution that always puts the camera in the same position without any thought or effort on my part. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 23, 2020 Report Share Posted December 23, 2020 (edited) Hard to see but magnet mount (think I found at Harbor Freight), short pipe nipple from Home Depot. Like Daryl said, move where you want. Did not build “weather shield” but has never been an issue. Simple, effective. on edit this was original pic of my mounting plate that used two of the lift ring screws. I later traded to these magnetic antenna mount but retained everything else as is. Edited December 23, 2020 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Av8r3400 Posted December 23, 2020 Report Share Posted December 23, 2020 I drilled and tapped two holes in the front wall of my ET because I wanted it more secure than the “wide load” magnets I have. I used off the shelf bracket steel from the farm store to make the riser. I adjusted the height to clear the front of the trailer if 90 degree jackknifed. Quote Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted December 24, 2020 Report Share Posted December 24, 2020 Did the magnetic idea back in 2014. 6 years later the Harbor Freight magnetic is still working. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Big5er Posted December 24, 2020 Report Share Posted December 24, 2020 Mine is plain and simple Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Brad NSW Posted December 24, 2020 Report Share Posted December 24, 2020 (edited) I mounted mine directly on the deck and put a plastic electrical box around it, to keep it from being kicked or knocked off. Has worked well for us. Camera Box mount photo Edited December 24, 2020 by Brad NSW Quote 2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel. Occupants - Dena/Brad/Hershey BLOG LINK Link to comment Share on other sites More sharing options...
Sculptor Posted December 24, 2020 Author Report Share Posted December 24, 2020 Thanks everyone for your help. The underlying theme of the answers is keep it simple. I get that. 🙂 Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
