woman_who_sees Posted November 1, 2020 Report Share Posted November 1, 2020 Our propane leak detector keeps going off in the middle of the night! Bill gets up, checks everything, opens the kitchen vent and turns on the fan. Funny thing, it only happens at night. This is driving us crazy and I sure hope someone can give us an answer as to why this happens..... Quote Bill (DH), Jan (DW), Sunshine (DBird), and Gila and Tacobelle (DCats) 2004 Winnebago Sightseer "Folks are about as happy as they make up their minds to be" (after a cup of coffee) Link to comment Share on other sites More sharing options...
SWharton Posted November 1, 2020 Report Share Posted November 1, 2020 Time for a new one??? How old is yours? Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted November 1, 2020 Report Share Posted November 1, 2020 Keep in mind this is actually a combustible gas detector, it detects any gas that is explosive/flammable. It is not limited to propane. Off-gassing batteries can trigger the alarm, flatulent dogs are two of the most common false alarms. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted November 1, 2020 Report Share Posted November 1, 2020 Propane alarms are one of the most difficult things to deal with because it is a safety issue and propane is heavier than air so it will pool and trigger a real alarm with minimal amounts of propane well before it is dangerous, but should not be ignored. If you have one that is 5 years or more old, start by replacing it as the manufacturers suggest 5 to 7 years of reliable life. As has been pointed out, there are other things that can trigger an alarm like flatulence and off-gassing. But do be careful as you don't want to take a chance. One thing that we found would cause ours was the oven had a pilot light that had to be lighted to use it and if it got turned on but not lit, there could be enough propane supplied to cause an occasional alarm but yet we were never able to detect it by smell. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wrknrvr Posted November 1, 2020 Report Share Posted November 1, 2020 The other answers are really good. But I have seen a pet cause that problem. Hair spray, perfume and glue can do that. One time I had a service call for a lp detector keep going off in a class c. They had left the southeast of the US headed to Alaska. They want to make the trip efficiently so said husband redid the shelving so to hold more food for the trip. My handheld lp detector will pickup molecules of combustible products. Well he made the shelves with particle board. Yep the glue from the freshly cut wood was letting the smell of the glue trip the lp detector. Could be anything that gives off a gas. Vern in a T-shirt Quote Link to comment Share on other sites More sharing options...
Bill Joyce Posted November 1, 2020 Report Share Posted November 1, 2020 Another thing is does this only happen at one camping spot or multiple places? If only one camping spot the problem might be outside. Quote 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 1, 2020 Report Share Posted November 1, 2020 It goes off in the middle of the night because that's when the RV is closed up. Try cracking a vent to increase air flow. Not a perfect answer, but it'll let you get some sleep. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
StraitRVing Posted November 1, 2020 Report Share Posted November 1, 2020 Many great answers here. Many things cause them to go off. We had the same problem with it going off in the middle of the night, especially on cold nights when the outside temp was at or below 35. Turns out it was a low voltage in the campground at night for some reason. I confirmed it with my meter at the pedestal. I was told by another camper that colder air on those cold nights (below 35 outside) in the RV can set it off if we keep the temp inside too low. During the colder nights, we usually keep the thermostat set at 64 at night when we are sleeping. The camper said it dealt with water/ice crystals in the air. I do not know if that is valid or not. Spoke with the RV service center and they said it could also be caused by an issue with the inverter. They said to check the inverter for loose wires, signs of arching, etc. I also had it happen when the house batteries were getting low on fluid. Low fluid caused low voltage. I check the battery fluid levels every week now. Quote Richard "Doc" Strait, USN Retired 2017 Coachmen Leprechaun 319MB Point of Contact for the Military, Veterans, and Gold Star Families BOF Link to comment Share on other sites More sharing options...
Kirk W Posted November 1, 2020 Report Share Posted November 1, 2020 Most of the RV propane detectors only chirp if voltage is low and low shore power voltage would have to fall low enough to discharge the RV battery below 10.5V, since they are powered by the RV's 12V system and designed to operate between 10.5 and 14V. Infrared sensors or IR detectors work via a system of transmitters and receivers to detect combustible gases, specifically hydrocarbon vapors. Typically, the transmitters are light sources and receivers are light detectors. If a gas is present in the optical path, it will interfere with the power of the light transmission between the transmitter and receiver. The altered state of light determines if and what type of gas is present. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
JimK Posted November 7, 2020 Report Share Posted November 7, 2020 If it truly keeps going off in the middle of the night, then testing should be simple. Shut off the propane tanks and turn on the stove to burn off any propane in the lines. If it goes off again you will know for sure it is a false alarm. I have had 2 detectors fail over the years and the symptoms were the same. In both cases I got false alarms in the middle of the night. Why in the middle of the night I could not tell you except if it went off in the day likely I was not around to notice. Quote Link to comment Share on other sites More sharing options...
Philipclopez Posted January 12, 2021 Report Share Posted January 12, 2021 Agree with Kirk. If you have had a propane alarm for more than 5 years then you should replace it. Quote Link to comment Share on other sites More sharing options...
johnpeters Posted September 23, 2021 Report Share Posted September 23, 2021 The service life of a propane detector is determined on how it was manufactured. Some older gas leak detectors have an average service life of five years, and the countdown begins on the date of manufacture. Many brands of detectors have a service life of six to eight years, and the clock begins the moment you turn it on. Quote Link to comment Share on other sites More sharing options...
travelinbob Posted October 24, 2021 Report Share Posted October 24, 2021 (edited) Ronaldos, you should have both detectors, one mounts near the floor and the other mounts about chest high. Edited October 24, 2021 by travelinbob added info Quote 2006 Elite Suite 36TK32001 F-550 Starhaulerwww.mytripjournal.com/elitesuitestravelsIN GOD WE TRUST Link to comment Share on other sites More sharing options...
Kirk W Posted October 24, 2021 Report Share Posted October 24, 2021 11 minutes ago, travelinbob said: you should have both detectors For some reason the RV industry has moved mostly to the combination CO/Propane detectors and my present RV is one of them. I do not like those because it is so difficult to know which is alarming and I agree that they should be in different locations to be ideal. For that reason I replaced mine with a propane sensor in the location of the OEM combo unit that is down about 3" above the floor and then installed a CO detector that is located near the bed and at about the height of our heads when sleeping. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
