trimster Posted August 16, 2020 Report Share Posted August 16, 2020 I need thoughts/ideas/tips on the cabling the dash monitor for a camera system. Where do I best run/drill thru the dash? Best way to get the cable runs out of the cab? Thanks Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 16, 2020 Report Share Posted August 16, 2020 Follow the rest of the wiring through the firewall. Punch a hole near the bulkhead connector, use the factory wiring bundle to ty-wrap to. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Star Dreamer Posted August 16, 2020 Report Share Posted August 16, 2020 Each brand of truck will probably be different. On our Freightliner, I came up through the passenger side floor board with a hole and large grommet right below the dash cover on that side and ran it up into the dash from there. It was convenient as I could also access the fuse panel which is on the passenger side dash for the power supply for the monitor. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
trimster Posted August 16, 2020 Author Report Share Posted August 16, 2020 On the volvo vnl, the dash piece that covers the fuse box, on the top of the dash...it just snaps out? Lift up an edge and hope for the best? Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
hatrack Posted August 16, 2020 Report Share Posted August 16, 2020 Bob, I think there are two screws by the cup holder that pops out. Not positive on this, still trying to figure out how to open it on my Volvo VNR 640. Quote 2017 DRV Fullhouse JX450 2020 Volvo VNR 42-640, D13, 455hp, Ishift, 189"wb, factory single, ET Junior Hitch @ 195", Jacklopee, Directlink 2016 GMC 3500 Denali DRW, CC, LB, Curt 25k, Sold Link to comment Share on other sites More sharing options...
HERO Maker Posted August 16, 2020 Report Share Posted August 16, 2020 20 minutes ago, trimster said: On the volvo vnl, the dash piece that covers the fuse box, on the top of the dash...it just snaps out? Lift up an edge and hope for the best? Bob On my 2001 the whole top comes off after you remove the screws. not sure about your 2015 Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
DesertMiner Posted August 17, 2020 Report Share Posted August 17, 2020 Slide out the “center top” cup holder. You will see 2 screws that need to be removed to un-snap the edge of the top panel. It hinges up towards the windshield. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 17, 2020 Report Share Posted August 17, 2020 I brought my cable through the cab and under the floor trim piece on the drivers side floor. There is a channel where other wires run. I then mounted the monitor in the dash itself and didn’t have to drill any holes. Looks like a factory install. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted August 17, 2020 Report Share Posted August 17, 2020 I agree with Suite. I did mine the same way. Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
trimster Posted August 17, 2020 Author Report Share Posted August 17, 2020 That's really clean. My monitor has a flush surface mount option like that as well. Thanks all. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 17, 2020 Report Share Posted August 17, 2020 6 hours ago, trimster said: That's really clean. My monitor has a flush surface mount option like that as well. Thanks all. Bob Bob, My truck doesn’t have a lot of dash mounted switches but you may have to move them over and consolidate. Easy to do as those switches can go multiple places. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Sculptor Posted August 17, 2020 Report Share Posted August 17, 2020 7 hours ago, SuiteSuccess said: I brought my cable through the cab and under the floor trim piece on the drivers side floor. There is a channel where other wires run. I then mounted the monitor in the dash itself and didn’t have to drill any holes. Looks like a factory install. X3, thats how I did mine too. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
trimster Posted August 17, 2020 Author Report Share Posted August 17, 2020 I looked at my dash. There I have axle controls , which can be moved, and two axle temp gages. Not sure where I can move those too. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted August 17, 2020 Author Report Share Posted August 17, 2020 ...and I got a 9" monitor. So, it's to big for that spot. Bigger might not be better. Doh. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
