cornwellkidd Posted June 30, 2019 Report Share Posted June 30, 2019 I read about Happy Camper to clean out your Black tank and now can't find it. I think it was in a Escapees Mag. Anyone know where it is. Thanks Quote Link to comment Share on other sites More sharing options...
SWharton Posted June 30, 2019 Report Share Posted June 30, 2019 I think Walmart sells it. Quote Link to comment Share on other sites More sharing options...
rynosback Posted June 30, 2019 Report Share Posted June 30, 2019 12 minutes ago, SWharton said: I think Walmart sells it. What doesn’t Walmart sell? : ) Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
RV inspector Posted June 30, 2019 Report Share Posted June 30, 2019 It's also on Amazon, but in the 130 treatment size. Quote Duane & Cheri NRVIA Certified RV Inspector https://www.rvinspectionandcare.com Link to comment Share on other sites More sharing options...
Kirk W Posted June 30, 2019 Report Share Posted June 30, 2019 I have used Trisodium Phosphate from Amazon for many years. I began using it to clean my waste tanks after learnig of it in a clinic put on by a Thetford RV products representitive. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
kb0zke Posted July 1, 2019 Report Share Posted July 1, 2019 Kirk, are you still using it? We did a bit of research just now and it seems that it has been removed from most things that used to have it. Quote David Lininger, kb0zke 1993 Foretravel U300 40' (sold) 2022 Grand Design Reflection 315RLTS Link to comment Share on other sites More sharing options...
2gypsies Posted July 1, 2019 Report Share Posted July 1, 2019 It's a phosphate and they are bad for septic tanks which some parks have. Quote Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
Chalkie Posted July 1, 2019 Report Share Posted July 1, 2019 6 hours ago, 2gypsies said: It's a phosphate and they are bad for septic tanks which some parks have. Do you have a reference for this? We had a septic system for many years and were told by the guy that maintained the system that TSP was no worse for the septic than bleach or other household chemicals as long as it was used in proper dilution. TSP is also a food additive and is deemed safe by both the EU and FDA. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted July 1, 2019 Report Share Posted July 1, 2019 1 minute ago, Chalkie said: Do you have a reference for this? We had a septic system for many years and were told by the guy that maintained the system that TSP was no worse for the septic than bleach or other household chemicals as long as it was used in proper dilution. TSP is also a food additive and is deemed safe by both the EU and FDA. The same is true for us. In fact if you read the fine print on the package we use it lists it as "food grade." You should use it properly and follow the instructions, as is true for any product. Quote TSP is most commonly used to reduce the acidic nature of foods, especially breakfast cereals, as it modifies cereal color and aids in the cereal's flow through the extruder. Other uses are: Added to meat to retain moisture during storage and cooking. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Darryl&Rita Posted July 1, 2019 Report Share Posted July 1, 2019 Phosphate is a fertilizer, and contributes to water quality problems. Septic systems don't care about phosphate levels, but the chemical enters the water cycle, eventually ending up in ponds and lakes. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
cornwellkidd Posted July 1, 2019 Author Report Share Posted July 1, 2019 Thanks to all for the reply. Quote Link to comment Share on other sites More sharing options...
