How to remove over spray
alan0043
 Share
Hi Everyone,
I know this is an off topic but there a good pool of brain power here. How can someone remove over spray off the painted surfaces on the wheels with out removing the original paint from the wheels ? I know acetone can remove paint but I think it is to strong for the original paint to stand up. I have no idea how long the over spray has been on the paint.
Any ideas,
Al
If wheels are painted then Im guessing they are steel.  Might consider cleaning well, sanding and then using something like Plastidip to restore them.  Can do it with a rattle can and looks pretty good when done.  Can also change colors now or later as it is a removable coating.
The aluminum wheels I've had are powder coated which if it is a good quality coating the Acetone will not affect.
Try some Acetone on a rag and rub along an edge of the painted surface.
A stronger thinner like Lacquer Thinner or Gun Wash may remove the over spray faster.
Thin Nitrile Gloves do not stand up to Acetone/Lacquer thinners but the orange/black (Marigold) rubber gloves do.
What I have not read is what the overspray is.  If it is an oil base enamel like Rustoleum and is not over 30 days old regular mineral spirits should remove it.  If it is acrylic enamel like Krylon you are going to need acetone.  If it is urethane you probably won't get it off without ruining the wheel finish.  Please let us know what the overspray is and how old it is.  I do understand the wheels are powder coated.
Hi Everyone,
I believe the over spray is automotive clear coat. I think it is older then 30 days.
Al
4 hours ago, alan0043 said:
Hi Everyone,
Al
3
Modern automotive clear coats are a catalyzed polyurethane.  Unlike clears of yesteryear that were acrylic enamels or acrylic lacquer, these clears are extremely resistant to solvents.  Like noted above sanding is probably your only option.  Not knowing exactly what you are dealing with, how much area is affected, or how thick the overspray is general directions would be to start wet sanding with #400 paper and finish with #2000 then a machine polish using a medium or fine cut compound.  It would probably be a good idea to take your wheels to a reputable paint and body shop, find someone in the shop that knows their paint/chemicals and slip them a Hamilton or Jackson to get a professional opinion.
Unfortunately, WD-40 is not a very strong solvent when it comes to removing paint.  It might help to remove paint on rubber seals by being absorbed by the rubber and causing the paint to release.  Good luck!
3 hours ago, Brad & Jacolyn said:
Will WD40 remove the paint from rubber seals?
Brad
Not likely . I've never had it remove cured and clear coated paints . But , it does take any over spray from recent paintings off .
Why not just spray a bit on a rag and try it ? You'll see if anything more than you want is starting to come along . If it does , stop .
And , what is paint doing on rubber seals anyway ?
Edited by Pat & Pete
Hi Everyone,
I am not going to fool with the wheels no more. I think it is time for the professionals to set in. The reason why I am saying that is because I tried acetone on the polished aluminum part of the rim with no effect. Man has to no his limitations.
Thank you everyone for your help,
Al
21 minutes ago, alan0043 said:
Hi Everyone,
Al
How do you know your limitations ? You haven't tested them . LOL
 Share
RV Cable Grip
RV Cable Grip
Country Thunder Iowa
Nomad Internet
RV Air.
