Blake Richards
phoenix2013
Blake Richards is an individual I purchased my truck from 10 years ago.
It was a surprise to hear from Blake this morning and reminisce about the "old days". These days he still sells semis, he still gets the occasional RVer to take care of and he is thinking about having a truck "ready with an ET" for that purpose. He talked about a possible "candidate" for that purpose. http://www.truckpaper.com/listings/trucks/for-sale/17366211/2013-volvo-vnl62t430 he has a bunch of these. I was totally unaware that Volvo produced these. Check the pictures of the rear axle on these, it's just a tube. Even though these are tandem they only have one axle that is driven, the front one. Guess what, singling these is almost a nonevent.
I know that vouching for anyone is risky, however, all I can say that my experience dealing with Blake was exemplary and he has a long history of supplying trucks to RVers. Incidentally, my "budget" back then was $32,000. He found me a reliable and good looking truck that I still drive ten years later, within that budget.
That depends on the state, but I can't see why not, if you meet the "four out seven" criteria.
I thought it was 5 of the 6? (Can't find the list right now...)
Separate Climate control - Maybe factory installed?
Shore Power - check, easy enough.
Food Storage - Fridge might be a challenge with the bunk right behind the seats.
Food Preparation - Mounting a microwave would be the same problem as the fridge
Porta Pottie - Probably not
Running water - Probably not
I have the Truck Fridge TF36 under my bunk in my 430, I believe I could have built and ice box instead in my province. I think you could fabricate a shelf above your feet in the sleeper for the microwave (mine is still in one of the boxes under the bed with the Webasto bunk heater and inverter. I think if you got creative you might even get a sink and faucet beside the micro on the shelf if you really needed it in your state. The 430 comes in single bunk only so unless you are newlyweds you are only sleeping one at a time if you actually use it as a motorhome. Definitely not as easy to do as the larger sleepers but should be possible most states. Best of all it is almost 3 feet shorter than a 780 for those concerned about overall length.
Nigel
My truck is registered as a motorhome in New Hampshire. The four:
1. Porta potty, bought in Walmart, cassette type. Parked in bottom compartment, never used in 10 years
2. Shore power, going into a breaker panel and powering outlets in the cab
3. Microwave, smallest one I could find sitting on the shelf.
4. Fridge, originally AC powered dorm type, then I found a truck one +12VDC powered
You are going to wind up with about a 170" wheelbase when you are done, if that is what you are after. Non powered axles on tandem setups are built by everybody now. In the old days a " tag" axle was strictly aftermarket, guys would dump the air on the dead axle and really get some traction on the drive axle. Of course they overloaded them with that stunt.
No oem manufacturer will build them that way for that reason. Various states have outlawed the practice, particularly Illinois because of uneven weights on the tandems. All air pressures on all 4 bags must be equal when the oem builds them.
They get stuck easily which is why they are not popular except with fleets willing to pay to get them unstuck. They are more fuel and weight efficient.
If you singled this truck would you single mid? How many feet of usable deck space do you think you would end up with a fifth wheel? I think this truck would be perfect for me. I want to put two motorcycles on the deck in a box of some kind and pull a fifth wheel. My wife likes a 40 footer and I would hope I could get this to 65 foot. Does anyone know? Thanks Ron
I think the point of those is to single short. You back the rear axle off the edge of the loading dock, roll the metal dumpster underneath, cut in front of each of the rear frame brackets, and kerplunk, she's done. It really is that easy (but don't do it exactly that way...). They'll cut a lot of labor out of the job. If you want a custom wheelbase, etc, they aren't going to save you a whole lot. You might as well have the job done on your perfect 6x4 truck at that point.
Their weight transfer between air bags for traction on them is done via the ABS. You spin, then wait a couple of secs for it to change the air around, then you go. They re-equalize themselves shortly later. The black valve you used to have to hold in on the dash quit being used OEM in the early 2000's. This, of course, is another thing you have to deal with when reconfiguring your ABS though.
This is similar to my older WIA42. NO problem getting stuff in...you just remove the bunk. Fridge, seats, little table, microwave, etc. Makes a nice little traveling space...you sleep in the camper!
I did basically What Phoenix did...tiny microwave and a portapotty. Neither was ever used.
