GeorgiaHybrid Posted July 26, 2016 Report Share Posted July 26, 2016 I have been thinking about getting the inside of our tool boxes and the inside of the drom box sprayed with Line-X instead of paint. It should dampen the noise from things sliding around and be an easy to fix coating if it ever gets messed up. We would still paint both sides of the doors in the truck body color. Anyone else ever done this? Can you think of any downsides? The Line-X will be cheaper than paint to get it sprayed and if it is like my pickup beds, it will take a lot of abuse and still look good. David Link to comment Share on other sites More sharing options...
Jim & Wilma Posted July 26, 2016 Report Share Posted July 26, 2016 Easy fix for us was putting down this floor mat material on the drom shelves and side boxes; it grips well and was easy to install. Link to comment Share on other sites More sharing options...
Nigel Posted July 26, 2016 Report Share Posted July 26, 2016 I have been thinking about getting the inside of our tool boxes and the inside of the drom box sprayed with Line-X instead of paint. It should dampen the noise from things sliding around and be an easy to fix coating if it ever gets messed up. We would still paint both sides of the doors in the truck body color. Anyone else ever done this? Can you think of any downsides? The Line-X will be cheaper than paint to get it sprayed and if it is like my pickup beds, it will take a lot of abuse and still look good. David I think it would work well. My suggestion is to wait until you have used your set up for a while, you may want to add or move shelves and dividers in your tool boxes. Nigel Link to comment Share on other sites More sharing options...
rpsinc Posted July 26, 2016 Report Share Posted July 26, 2016 While I didnt exactly do what you are proposing, I have used some elastomeric roof coating to coat the inside of a LoadNGo with it to reduce the sliding around of the tools and bins. I used some bedliner for the outside and the inside of the bed area of the LoadNGo. I has worked well and does reduce the sliding around. The bedliner was sprayed on and I find that with its peaks and valleys, the contact area of the product is less than the roof coating I put inside the boxes. Each coating has its advantages and disadvantages, but I would do it again. I did it all myself so I saved on the labor cost, although a few years back when I bought a truck and service bed, I had Line-X spray it for me. It didnt turn out as well as the one I did myself, likely because the motivation for a good job was different. As to coating the boxes and adding shelves and dividers, do it whenever. Any shelves and dividers can be added/moved with the coating in place as it doesnt make sense to coat those parts. Link to comment Share on other sites More sharing options...
Broncohauler Posted July 26, 2016 Report Share Posted July 26, 2016 I agree with Nigel. Make sure everything is how you want it. Trying to go back and weld after its coated sucks! I know Been there done that on some fleet welding jobs. Also it's a little harder to clean or wipe out than a smooth surface. You can have it sprayed some what smooth though. Other than that go for it you'll love it I did my whole inside of my early bronco, and can pressure wash it easily after a desert trip. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted July 26, 2016 Report Share Posted July 26, 2016 Is line-x a sealer? Without some form of primer / sealer you may get corrosion between the line-x and metal. Steve Link to comment Share on other sites More sharing options...
rickeieio Posted July 26, 2016 Report Share Posted July 26, 2016 Carpet scraps work well too. Link to comment Share on other sites More sharing options...
Jack Mayer Posted July 26, 2016 Report Share Posted July 26, 2016 I would think it would work OK, but you would still likely want to put down the rubber mats, as suggested above. The bigger issue will be finding someone with a small enough gun to shoot it properly inside the boxes. Not everyone can do that..... Link to comment Share on other sites More sharing options...
jkennell Posted July 26, 2016 Report Share Posted July 26, 2016 When I built my simple bed, I bought a "kit" from a local paint shop that included a throwaway spray gun. I painted the bed with regular primer, then hit it with the "line X" type stuff. I had just enough left over to cover the bottom inside and partway up the walls of my saddle boxes. Worked GREAT. Totally eliminates the clinking and rattles. Do throw a rubber mat in to protect the LIneX stuff from really heavy pointy stuff (old car floormats work good). The gun was no bigger than an ordinary paint gun....and it was the easiest paint job I ever did. Warning...have a friend ready to mix the "next" can of stuff, as you spray out the first one. It goes on fast, but has a short "mixed" life. Mine had 3 cans to mix the hardener into, and I emptied one nearly as fast as he could mix the next one! Link to comment Share on other sites More sharing options...
rpsinc Posted July 26, 2016 Report Share Posted July 26, 2016 The bedliner works best outside but the elastomeric roof coating I used inside was applied with throw away brushes and weenie rollers. My boxes have shelves mounted to clips and unistrut, so moving/adjusting them is not a big deal, no welding required. I used Xtreeme Liner and they supplied a drywall texture gun to spray it. They also have an undercoat gun that is smaller but uses a suction tube so position will be important as the tube needs to stay in the product. The ticket for the inside was the weenie applied elastomeric. And I can freshen it up when I need to. I put several coats on. Link to comment Share on other sites More sharing options...
Broncohauler Posted July 26, 2016 Report Share Posted July 26, 2016 If you decide to also use a mat? I've had great luck with the rubber truck mud flaps cut to size in the boxes on my Mobile welding truck. I have a friend that uses stall mats inside his boxes on a step deck trailer for chains and binders. It's a lot thicker but really helps cushion the blow when throwing in chains. He also uses the Mats as mudflaps, it helps a lot with road spray off the tires. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted July 26, 2016 Author Report Share Posted July 26, 2016 I think one plus would be that Line-X is almost indestructible and can be repaired easily and still look nice. It is a little slick though so I might need to use mats. Larry claims his vendor can spray it inside the boxes so I am going to take him at his word there. I am going to go over the spacing on the drom box shelves to make sure that the spacing will work out OK with what I want to store on them. I can see where changing my mind later would be a pain in the tail to fix. I think they spray it over blast cleaned metal so as long as the coating is not cut to the metal, it shouldn't ever rust (I hope). I can see the advantage of waiting to see if any shelves need to move but if I do that, I will just spray the insides chassis black and not worry about it. A spray can of that is a cheap fix to scratched paint and a little rust can be easily knocked off before a re-paint. It is going to be a tossup but I think I am leaning towards the Line-X just because of the durability aspect of the coating. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 26, 2016 Report Share Posted July 26, 2016 Do the Line-X. If the vendor has a light color that they can spray inside the boxes get it. Dark colors suck up available light making it hard to see into corners or bad lighting. Having a lighter color is easier to see into, but shows dirt faster. If I can ever get this old bed pulled off, the next on will be Line-X in a light grey . Make it easier to see underneath. MythBuster did several episodes about the stuff. In the right application, the stuff is just about bomb proof, dog proof, fire proof, etc. Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted July 27, 2016 Report Share Posted July 27, 2016 Probably would not matter to you but you should be aware that the Line-x warranty is only for pick up truck beds (at least that's how it was 4 years ago). I had it done on the back of the HDT twice (wasn't applied thick enough the first time) because I did not know this. For any other application any warranty comes from the applier and get it in writing. This little fact is apparently in the VERY FINE Print somewhere. I took it all the way to corporate and that was what I was told. Just an FYI. Brad Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted July 27, 2016 Report Share Posted July 27, 2016 My question is will LineX help seal the seams? If in one had any water leaks into their boxes? Roger Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 27, 2016 Report Share Posted July 27, 2016 My question is will LineX help seal the seams? If in one had any water leaks into their boxes? Roger Here's your "Maybe" answer....Supposedly..... We LineX'ed several race boat motor wells back in the '90's. As a test, we sprayed several raw pieces of 2x8 pine boards. Those boards were then submerged for several weeks. 1 board was cut in half to see if there was any water penetration and there wasn't. The other 2 boards are in a sauna still being used as seats. So if properly applied in adequate thickness, yes it will seal cracks and prevent water intrusion. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 4, 2016 Author Report Share Posted August 4, 2016 OK, After reading everything here and talking to Larry about the guys doing the spraying, I don't think they can spray everywhere inside the drom and tool boxes (reaching in to paint the inside wall) with their equipment. I decided to paint the boxes with a silver paint and will mask off everything once I get it back home and spray a light gray Line-X on the top side of the shelves and the bottom of the boxes. After that is done, I will wire up the lights in the boxes. Link to comment Share on other sites More sharing options...
