Larry&Donna-AK Posted July 16, 2016 Report Share Posted July 16, 2016 Here is my dilemma. Unlocking the ET hitch using the installed release handle. The MorRyde plate covers the ET hitch release handle therefore I can't attach a 1/2" drive to the hitch handle. The only method I've been able is to use is a small flat bar crowbar wedged between the handle and head to release the king pin. I don't see any adjustments to eliminate the problem. Am I doing wrong? Is there an adjustment for the MorRyde or ET? I posed this question to ET, suggesting a longer release handle would help. The answer I received was "we tell people not to put the MorRyde on in that manner." I have know idea what that means. Planning Nanook version 2.0 Nanook "When we made ready to depart, after a few days, Nanook was beside himself with joy. Hudson Stuck Link to comment Share on other sites More sharing options...
MrSeas Posted July 16, 2016 Report Share Posted July 16, 2016 Larry, Any chance you could include a larger view so we can see how the ET release handle also interferes with the hitch pocket? Thanks Link to comment Share on other sites More sharing options...
rdickinson Posted July 16, 2016 Report Share Posted July 16, 2016 I just went out and looked at mine. Re yours, appears like the center hole is close to the rear edge of the 1.5" x 1/4" flat bar. The far hole at the other end could be filled and re drilled closer to the front edge or left side of the bar as we look at it. . This would bring the square hole end of the bar forward, out from under the plate a bit. The bar would pivot on the center hole which opens the jaws. If that isn't enough, try a pce of 2" flat bar and drill the holes in the locations I just mentioned. Center hole close to the rear of the truck and the non square hole close to the front of the truck. 3/4" would buy you enough to make it work. I have an xtra Trailersaver handle from the last hitch you could have but don't think it would work. Have a look at the Trailersaver release handle on their site. It has a dogleg in it which could be flipped the other way and still miss the locking pin. Instead of drilling or cutting a square hole, weld a socket on the bar 1/2" square hole up for flex bar. I'd make the handle or bar longer to increase mechanical advantage. Looks pretty short. It never ends. Link to comment Share on other sites More sharing options...
Larry&Donna-AK Posted July 16, 2016 Author Report Share Posted July 16, 2016 Larry, Any chance you could include a larger view so we can see how the ET release handle also interferes with the hitch pocket? Thanks Hitch Pocket? Not sure I understand this term. Tomorrow I'll post more photos. Planning Nanook version 2.0 Nanook "When we made ready to depart, after a few days, Nanook was beside himself with joy. Hudson Stuck Link to comment Share on other sites More sharing options...
MrSeas Posted July 16, 2016 Report Share Posted July 16, 2016 Hitch Pocket? Not sure I understand this term. Tomorrow I'll post more photos. The " well" or indentation that the hitch sits down in. Link to comment Share on other sites More sharing options...
Larry&Donna-AK Posted July 16, 2016 Author Report Share Posted July 16, 2016 I just went out and looked at mine. Re yours, appears like the center hole is close to the rear edge of the 1.5" x 1/4" flat bar. The far hole at the other end could be filled and re drilled closer to the front edge or left side of the bar as we look at it. . This would bring the square hole end of the bar forward, out from under the plate a bit. The bar would pivot on the center hole which opens the jaws. If that isn't enough, try a pce of 2" flat bar and drill the holes in the locations I just mentioned. Center hole close to the rear of the truck and the non square hole close to the front of the truck. 3/4" would buy you enough to make it work. I have an xtra Trailersaver handle from the last hitch you could have but don't think it would work. Have a look at the Trailersaver release handle on their site. It has a dogleg in it which could be flipped the other way and still miss the locking pin. Instead of drilling or cutting a square hole, weld a socket on the bar 1/2" square hole up for flex bar. I'd make the handle or bar longer to increase mechanical advantage. Looks pretty short. It never ends. I'm learning "it never ends"Yes the handle is to short, I wonder why. I could add approximately 3" to the handle create a bend (dog leg) to keep the handle perpendicular to the head. Great idea Planning Nanook version 2.0 Nanook "When we made ready to depart, after a few days, Nanook was beside himself with joy. Hudson Stuck Link to comment Share on other sites More sharing options...
JC and Angie Posted July 16, 2016 Report Share Posted July 16, 2016 Henry dose have a longer Handel that he has in the past sold, updated, gave Away or ?? I'm still waiting on mine. Maybe this fall is the magic time for getting mine. Hitch needs attention anyway If Henry will share the file I'll cut a few, but that's up to Henry. 2009 Volvo 780. D-16 500hp 1850 torque with a Herrin hauler bed. 2015 Continental Coach 2008 650cc Suzuki Bergman 2013 Mustang GT 500 convertible 2014 Smartcar convertible WWW.Hollyfab.com. (Metal Fabrication Company) Jamesc@hollyfab.com (preferred contact method) Link to comment Share on other sites More sharing options...
Ronbo Posted July 16, 2016 Report Share Posted July 16, 2016 I use the squashed pipe from my trailer saver hitch. It works perfect. I have a wire handle for an awning I use to pull the release with and then us the pipe. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
rdickinson Posted July 16, 2016 Report Share Posted July 16, 2016 Looks like the square hole is center on the 1.5" flat bar. The far hole looks off center maybe 3/4" from the rear. That hole needs to be closer to the front of the truck. You may be thinking of the dogleg in a different plane than I mean. It may not be required, my TS would still clear the locking pin without the jog. Check out the release bar on the Trailersaver site. I saw an exploded view somewhere but there are lots of pics scattered thru their User Manual. In my case the wire puller and the pipe with the flattened end wouldn't work as the hitch release lever and locking pin are below the main truck deck. You'd have to reach over and down and my wrists won't do that. Where you have the square hole, I put a large nut but the 6 and 12 point sockets had too much slop so I'm welding a socket on the bar making sure it's facing the right way then use a 3/4" flex bar plus an extension. Take the existing one off and make a mockup out of cardboard or Coreplast or 1/8" Masonite. Link to comment Share on other sites More sharing options...
rickeieio Posted July 16, 2016 Report Share Posted July 16, 2016 I don't have an ET, yet, so I can't be sure, but it looks to me like you could use a 1/2" breaker bar in that square hole. Flip the breaker bar so that the male pin enters the latch from the bottom? KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 16, 2016 Report Share Posted July 16, 2016 Don't have an ET either, but you could have an extension welded on the flatbar with a hole drilled or punched that is past the end of the MorRyde plate. Have a socket welded on, or have the bar angled to where you could use the Trailersaver squished pipe. Try Ronbo's idea though. The socket may fit from the bottom side. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
rdickinson Posted July 16, 2016 Report Share Posted July 16, 2016 Larry, the RV Park here has a woodshop which no-one uses so I've loaded most of my woodworking tools up there. Get me the length of the bar measurement in from the end to center of the 2 pivot holes. Measure in from the far end or non square hole end. lateral measurement of the holes to center from the left side of the bar. Front of truck side. I will make a couple of mockups out of 1/4" mdf, full size with measurements, take some pics and send them to you. Will also put socket and breaker bar in mockup. 1 idea is to tack a 1x1 pce of flat bar to the back edge of the bar at the center hole and re-drill the bar. Re-drilling the hole 3/4 " to the rear of the existing one moves the handle fwd. I'll try different pivot point locations.. Also how far below the rest of the truck deck is the top of the flat bar? In other words is it dropped down in a recess b/w the frame rails? This is an easy fix. Send e-mail so I can send pics. I can have this done by noonish. You can post the pics and let the engineers critique it if you want. Also send Visa # for design fees. Link to comment Share on other sites More sharing options...
Big5er Posted July 16, 2016 Report Share Posted July 16, 2016 I created a handle that slips over the ET's release. It acts like an extension. Like Ronbo I use an awning rod (welded a real handle to it also) to pull the release and my homemade extension to move the flat ET release. Both of my "homemade" tools are about 24 inches long. I never actually get within arms reach of my ET to unhitch. I didn't weld an extension directly onto the ET because when it airs down all the way a longer handle could hit on the bed. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 16, 2016 Report Share Posted July 16, 2016 I have the MorRyde and ET but with the older longer handle. Will try to get you some pics of my tools to unhitch. One is simply a curved "hook" to grab the spring pin, the second is some rectangular tubing welded to a piece of bar that slides over the handle. Makes things easy. I think Rogers idea of smashing the end of a piece of round tubing so it would slide over the handle or Rick's breaker bar engaged from the underside would both work. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rdickinson Posted July 16, 2016 Report Share Posted July 16, 2016 I have the MorRyde and ET but with the older longer handle. Will try to get you some pics of my tools to unhitch. One is simply a curved "hook" to grab the spring pin, the second is some rectangular tubing welded to a piece of bar that slides over the handle. Makes things easy. I think Rogers idea of smashing the end of a piece of round tubing so it would slide over the handle or Rick's breaker bar engaged from the underside would both work. Roger doesn't smash, uses fineness and skill instead. You got me mixed up with the wrong dude. Big Fiver, could the handle be shortened so as not to hit the deck when hitch is deflated. We had to do that with mine. Link to comment Share on other sites More sharing options...
Larry&Donna-AK Posted July 16, 2016 Author Report Share Posted July 16, 2016 I don't have an ET, yet, so I can't be sure, but it looks to me like you could use a 1/2" breaker bar in that square hole. Flip the breaker bar so that the male pin enters the latch from the bottom? You're correct, that's exactly the intent of the square hole. the MorRyde plate extends over the handle, not enough space to attach a breaker bar. Also can't attach a breaker bar from the bottom because of the locking pin. Planning Nanook version 2.0 Nanook "When we made ready to depart, after a few days, Nanook was beside himself with joy. Hudson Stuck Link to comment Share on other sites More sharing options...
GlennWest Posted July 16, 2016 Report Share Posted July 16, 2016 I have a standard pin box with ET on truck. I have some difficulty hooking my pull handle to it. Barely enough. The hitch I got for my LDT used a brinkly head. Had longer handle. I liked that handle better. But a piece of pipe to slide over should work great and easy to make. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 16, 2016 Report Share Posted July 16, 2016 Larry, Pics of my tools. Note bend in rod to get to handle when aired down. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rdickinson Posted July 16, 2016 Report Share Posted July 16, 2016 If his hitch is below deck level the handle will hit the inside of the recess for the hitch. He would have to shorten the handle like I did. Also if the hitch is below deck level, you'd want the release bar with the square drive above not below the handle. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 16, 2016 Report Share Posted July 16, 2016 More pics. Roger, my "bend" takes care of the below deck issue. So far no issues in six years getting unhitched and I have the same MorRyde pin box. Just one of many possible solutions. Cost of tools about $15 for materials. Note my handle on the old style ET is slightly longer but still don't think that should be an issue. Might need bend in bar slightly further back along rod to compensate. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 16, 2016 Report Share Posted July 16, 2016 Larry, In looking at your picture more closely, IF you choose to make a tool like mine, make sure the rectangular tubing has several inches passed the rod welding so the rod doesn't hit the pin box. In fact might do the weld "end on" the tubing rather than on top. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rdickinson Posted July 16, 2016 Report Share Posted July 16, 2016 I like your lever device. Even if his release handle was longer to get the square out from under the trailer plate, that would work. If there was room. That's why I'd prefer to use a socket with extension and flex bar. I'm coming off in the horizontal....but whatever works. Link to comment Share on other sites More sharing options...
noteven Posted July 16, 2016 Report Share Posted July 16, 2016 Deleted "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Big5er Posted July 16, 2016 Report Share Posted July 16, 2016 Big Fiver, could the handle be shortened so as not to hit the deck when hitch is deflated. We had to do that with mine. I went and took pictures of my ET and tools The red arrow is pointing at the release handle. The hitch is totally deflated and that is why I didn't just extend the handle. I also added a washer onto the spring release handle. No slipping off of that. And by the way: MY ET handle doesn't have a square hole in it. See?? Both tools. The one on the left is an old awning rod. I shortened it a bit and added a real handle made of square tubing. I cut, notched and bent the other tool from a straight piece of whatever that was, welding each bend/notch in place. When the hitch is aired up, the handle of that tool is a few inches above the deck and a bit more level with the deck. Right now, the hitch is tilted a bit on the springs. With the bends in the tool I can release the hitch without the tool (or my knuckles) hitting the deck mounted tool box. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
GlennWest Posted July 16, 2016 Report Share Posted July 16, 2016 That is unistrut tray. Use it a lot for instrumentation and electrical 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
