GlennWest Posted June 28, 2016 Report Share Posted June 28, 2016 I run the air up to max, 110. Couldn't tell any diff in ride but drove better. What you all running? 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 28, 2016 Report Share Posted June 28, 2016 100 steers, 95 drives. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 28, 2016 Report Share Posted June 28, 2016 105-110 psi in steers and 95 in the drives. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
billr Posted June 28, 2016 Report Share Posted June 28, 2016 105 in steers. And 85 in drives. Single axle Bill and Joan and 3 Collie pups 2001 Volvo VNL 770 "The Doghouse" Singled short, "ET" hItch VED12 465HP Gen 1 Autoshift 3.58 ratio 2005 Mobile Suite 38RL3 2011 Smart Passion loaded piggybacK Weigh-It Portable RV Scales http://www.weighitrv.com/ Link to comment Share on other sites More sharing options...
CrazyCooter Posted June 28, 2016 Report Share Posted June 28, 2016 85psi steers, 65psi drives per manufacturer's recommendation on their load inflation table recommendation. 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
Dennis M Posted June 28, 2016 Report Share Posted June 28, 2016 100 steers, 90 drives per weight charts Dennis & NancyTucson, AZ in winter, on the road in summer.1999 Volvo 610 "Bud" 425 HP Volvo, Super 10 spd.2005 Mountain Aire 35 BLKS2013 smart fortwo CityFlame riding on Bud(Replaced '05 smart first loaded in '06 and '11 smart that gave it's life to save me!)Our Travel Blog Link to comment Share on other sites More sharing options...
GlennWest Posted June 28, 2016 Author Report Share Posted June 28, 2016 85psi steers, 65psi drives per manufacturer's recommendation on their load inflation table recommendation. anything under 100 front mine sag rather well 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
CrazyCooter Posted June 28, 2016 Report Share Posted June 28, 2016 anything under 100 front mine sag rather well I only run 9,500 max on the steer and 8,200 loaded. I also have 24.5's. 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
GlennWest Posted June 28, 2016 Author Report Share Posted June 28, 2016 That explains why. Imagine my 14L detroit heavy 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 28, 2016 Report Share Posted June 28, 2016 100 steers, 90 on the rear Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Chad Heiser Posted June 29, 2016 Report Share Posted June 29, 2016 100 on steers, 100 on drives, 100 on trailer tires. I like to keep it simple. I have more air than I need in the drives according to the tire charts for my weight, but the others are where they need to be and the ride difference was not noticeable going up to 100 on the drives. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
HERO Maker Posted June 29, 2016 Report Share Posted June 29, 2016 100 in the steers, 80 in the rear tandems. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Jim & Wilma Posted June 30, 2016 Report Share Posted June 30, 2016 105 in steers. And 85 in drives. Single axle ditto . . . after Bill weighed us at ECR. As you'd expect, steers load is highest with Smart loaded and unhitched and is within a few hundred lbs of axle rating. Drives are highest when hitched and has much more margin, though expect we'll erode that a bit. We hope to weigh again at Hutch with Trey and Susan and probably need to bump the drives to 90 after we finish loading up and getting set for full timing. Would like to get Crossfires for the drives but holding off just for this reason. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Gabbie Posted June 30, 2016 Report Share Posted June 30, 2016 I was told by a tire installer to keep the steers above the 100psi mark or risk breraking the bead in slow turns. So I keep mine around 115 psi steers and around 90-95 psi for the drives. Kevin Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 30, 2016 Report Share Posted June 30, 2016 I was told by a tire installer to keep the steers above the 100psi mark or risk breraking the bead in slow turns. So I keep mine around 115 psi steers and around 90-95 psi for the drives. Kevin Is that 115 psi Canadian? 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
RickW Posted June 30, 2016 Report Share Posted June 30, 2016 115 sounds way to high to me. Personally steers @ 100psi, drives @ 85psi and trailer @90psi. PSI for each axle position is based on actual weight and tire charts on my tires. 2017 Entegra Anthem 44A SOLD - 2004 Volvo 780. 465hp and 10sp Auto Shift (from 2010~2017) SOLD - 2009 Montana 3400RL Link to comment Share on other sites More sharing options...
