Smitty77_7
Last day for Mobley and Car Connect $20 plan
ATT has them back in stock, and the software will still let you order the ZTE-Mobley with eh $20 Car Connect Plan. (Or at least, if did 3 hours ago when I ordered a second Mobley.)
Still one of the better deals available, if ATT will support you where you travel.
Smitty
Share this post
Link to post
I ordered a second one the other day.  I did it mainly as a back up to my primary one.  I also recently got a text from ATT notifying me I was getting close to my 20 gig unlimited limit and once I passed that point I would be subject to de-prioritization (not throttling).  I figure with a second Mobley waiting in back up, I can swap over to it if need be to avoid the de-prioritization if it becomes an issue.
Share this post
Link to post
So does anyone know what the new plan cost will be and if you are not on contract, but bought your device outright, will you be grandfathered in at the $20.
Share this post
Link to post
Smitty
Where did you see or find out that this was the last day?  Many people at car connect told me that it was not a promotional rate at that an end was not coming soon. That was 2 months ago.
Share this post
Link to post
2 months is a lifetime for some folks . ;)
Share this post
Link to post
As of right now, (July 18) the ATT website is still offering the Mobley with the $20 per month plan. Either ATT changed their mind about this being a limited time promotion or someone is asleep at the switch.
Edited by Lou Schneider
Share this post
Link to post
I bought two Mobleys as a back up.  So if they change to be programmed to a specific vin or they just stop making them.
Share this post
Link to post
Very true, but sometimes you call and they do not even know the plan exists.  I guess it is all about who you speak to.
Share this post
Link to post
Yep. When going to check my Order Status, I went thru the process again to see if it was still offered. Saw that it was, about 9:30AM Mountain Time.
Many sources back when Mobley hit the latest and greatest ATT Data Parade - had 7/17 noted as the end of this promotion. (Howard's Forum, IRV2, RVMOBILEINTERNET, etc.). So I got my "7/17" last date off of the Internet - and it is never wrong...:)!
(My 2nd order still reflects In Proress...).
Best,
Smitty
Share this post
Link to post
The Mobley only uses the 12-volt and ground pins from the OBD2 port. The CAN and ISO bus pins are not connected, so it's not capable of reading the VIN.
Share this post
Link to post
Ordered one today 7/19 at ATT store with the $20 unlimited stand alone plan (no ATT plan previously required).
Maybe I just squeaked in under the wire but there was no mention of a final day.
Share this post
Link to post
Could somebody tell me the range of the Mobley and is it antenna capable for better signal ? ...under the dash doesnt sound like the greatest spot to recieve a signal.
Share this post
Link to post
It doesn't need to be under the dash. Simply power it from a 12v source and place it at a better location. It doesn't have an antenna port without opening the car and creating your own attachment.
Share this post
Link to post
Whats needed to adapt it. My rv has lots of 12V in it cig lighter lights.. cig lighter would be great if it would work
Share this post
Link to post
Check your fuses! Then see if the wire is connected!
Share this post
Link to post
Search Amazon or ebay for mobley adapter. There are adapters that plug into AC/USB/Cigarette lighter.
The Mobley Device is basically is a small cellular router (think mifi/hotspot) with an OBDII connection for power. The above adapters provide the needed power to the Mobley device so that it does not have to be used in a car/vehicle.
Correction: (WRONG - No Antenna port) Apparently there is/are MS156 antenna port(s) to connect an external antenna) one possible adapter
You could use a cell booster ($$-$$$$).
It does broadcast wifi so can be found by a wifi router with wifi capture (e.g. WifiRanger/PepwaveSOHO/Cradlepoint/etc) and then broadcast the signal to local network.
I did have to go into an ATT store and kindly and persistently convince the store representative (As many others have had to do) that they indeed do have this device/account. He finally relented from his position and made the attempt and learned that they did have the (apparently hidden/unknown) service (His position was that this could only be an add-on service to an existing ATT account - of course, most of y'all not that position is incorrect). Online ordering did not work for me. Probably because I made a mistake with the initial attempt and put it a different shipping address. Any online attempt after that resulted in "not being able to verify my identity".
Edited by TreyandSusan
Share this post
Link to post
Hmm I think I have the adaptor I need that I used on my trucker antenna for a verizon Jetpack...My Mobley is supposed to arrive tomorrow. :)
Share this post
Link to post
Judging from the interest, these little Mobleys must work pretty good. That and price.  How much cheaper are these than getting a regular mifi device?
Share this post
Link to post
I think the plan is based for the Mobley only.  As you call "Connected Car" to get the $20 plan.  It is the only one that I know of that connects to a vehicles OBD2 port.
Share this post
Link to post
But how much does comparable mifi service cost?  I've never used either so my lack of experience makes it difficult to compare.
Share this post
Link to post
AT&T has a prepaid mifi/hotspot plan with 8GB of data for $75/month, and their contract "Unlimited Mobile Essentials" 3G speeds limited plan starts at $70/month, and starts at $100/month for their "Premium Unlimited" 4G/LTE plan.
Share this post
Link to post
My Jetpack that I had with Verizon was $50 plus
Share this post
Link to post
Ours , too . BUT , it cost us $90 a month for 12 gigs .
It doesn't take to long to see which is the better deal : a $100 device and $20 / month for unlimited data or $50 device and $90 / month for 12 gigs of data .
Of course , anyone should always compare coverage . Will any or no device service you where you will be wanting to use it .
Share this post
Link to post
I was trying to forget about cost of Gig BUT in my situation I can if needed use the hotspot on my verizon ph if Mobley cant work
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Rvonthego.com
