lappir Posted January 3 Report Share Posted January 3 How many "Salt" your cutting board before using? Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Chalkie Posted January 3 Report Share Posted January 3 (edited) 2 hours ago, lappir said: How many "Salt" your cutting board before using? Rod Never heard of that but I suppose as long as you were very cautious of the amount of salt added later it would be alright. Edited January 3 by Chalkie Quote Link to comment Share on other sites More sharing options...
sandsys Posted January 3 Report Share Posted January 3 I never heard of it either. Does it make a difference what material your cutting board is made of? Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
2gypsies Posted January 3 Report Share Posted January 3 It's meant for deodorizing a wood board. You still should wash it. It's best to keep 2 boards - one for meats and one for anything else. https://www.thecleaningauthority.com/blog/how-to-clean/cutting-board-cleaning-hacks/ Quote Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
lappir Posted January 4 Author Report Share Posted January 4 So the reason I put salt on my Cutting surfaces, wood, plastic and one Glass one, is to keep the material from slipping around so much when I'm cutting or chopping. Not sure where I heard of doing it, but it works very well. It really doesn't take all that much unless your ingredient is very wet to start with. (Better to allow it to drain a bit if freshly washed). I have heard of Salting a "Butcher Block" for sanitation and I know people who are really bothered by my using a wooden cutting board at times. I do soak it and then put it in the microwave for a good steam and then a sun dry when I think about it. I have a Bamboo board that has 5 plastic inserts each with a label indicating what should be cut on it. Poultry, Meat, Bread Vegetables and fruit. They all nestle in a slot under the board and the board is cut out to keep the plastic from sliding around. I just pull out the one on top and cut what I need and then wash the plastic in addition to the holder. Sometimes I just throw them in the bottom of the sink rinsed and then wash several at once. Better use of water in my mind. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Chalkie Posted January 4 Report Share Posted January 4 2 hours ago, lappir said: So the reason I put salt on my Cutting surfaces, wood, plastic and one Glass one, is to keep the material from slipping around so much when I'm cutting or chopping. Not sure where I heard of doing it, but it works very well. It really doesn't take all that much unless your ingredient is very wet to start with. (Better to allow it to drain a bit if freshly washed). I have heard of Salting a "Butcher Block" for sanitation and I know people who are really bothered by my using a wooden cutting board at times. I do soak it and then put it in the microwave for a good steam and then a sun dry when I think about it. I have a Bamboo board that has 5 plastic inserts each with a label indicating what should be cut on it. Poultry, Meat, Bread Vegetables and fruit. They all nestle in a slot under the board and the board is cut out to keep the plastic from sliding around. I just pull out the one on top and cut what I need and then wash the plastic in addition to the holder. Sometimes I just throw them in the bottom of the sink rinsed and then wash several at once. Better use of water in my mind. Rod OK, so now I am going to have try this trick. I never would have thought of it. Interesting thing about wooden cutting boards, they are actually safe. I mean when you think about it wood has been used for cutting boards or butcher blocks for hundreds of years and there is no evidence of rampant botulism or salmonella ripping through the population. In actuality wood is naturally anti-microbial. From the National Institute of Health on a study the was done: Quote These results do not support the often-heard assertion that Plastic cutting boards are more sanitary than wood. Full study here if you care to read it. Quote Link to comment Share on other sites More sharing options...
MadeItToFT Posted January 4 Report Share Posted January 4 Grand parents, parents, myself and children same - always used and still do wooden cutting boards, regularly scrubbed and salted - have 3 scattered in SnB kitchen where a ton of prepping and cooking is done daily, and 2 in RV Kitchen (Large and small one). Just way we were taught when younger by ancestors and passed down the line. Very occasionally might pull out a small plastic one when cutting up a tomato or onion for speedier clean up snack times/sandwich making using it also as the plate so to speak LOL. Interesting thing about studies/research, I've always found over the years the results get changed from black to white often! Butter is bad for you, then it's better for you comes to mind immediately. If it ain't broke we ain't going to try and fix it. All been good for past zillion decades in our homes.🤞 Quote Link to comment Share on other sites More sharing options...
kb0zke Posted January 7 Report Share Posted January 7 Jo Ann has a set of plastic ones that we use. They are smooth on one side and rough on the other. Put the smooth side down and the rough side holds the item to be cut. Each color board is a specific use. I know a couple of the colors, and ask about anything else. If I need to get one for her she tells me what color to get. I pull out what I think is the correct color, show it to her, and she either says yes or no. I have a bit of color blindness, so sometimes two colors will look enough alike to me that I'm not sure which is which. Quote David Lininger, kb0zke 1993 Foretravel U300 40' (sold) 2022 Grand Design Reflection 315RLTS Link to comment Share on other sites More sharing options...
sandsys Posted January 8 Report Share Posted January 8 My biggest plastic cutting board has a gutter around the edge on one side but not the other. The gutter side is for cutting meat. Everything else uses the other side. I used one of the smaller ones yesterday to slice tomatoes; it does not have a gutter and I wish it did--tomatoes are juicy. Linda Sand Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Chalkie Posted January 8 Report Share Posted January 8 2 hours ago, sandsys said: My biggest plastic cutting board has a gutter around the edge on one side but not the other. The gutter side is for cutting meat. Everything else uses the other side. I used one of the smaller ones yesterday to slice tomatoes; it does not have a gutter and I wish it did--tomatoes are juicy. Linda Sand Or, you could just give it a wash and use whichever side you want. If you were really concerned you could use a food safe sanitizing wipe on it. Quote Link to comment Share on other sites More sharing options...
sandsys Posted January 9 Report Share Posted January 9 20 hours ago, Chalkie said: Or, you could just give it a wash and use whichever side you want. Actually, I do that. I just didn't want to use the huge cutting board to slice grape tomatoes for a salad. Then I wished I did. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
lappir Posted January 17 Author Report Share Posted January 17 Another not Recipe. I used to peel off the skin of Potato's, but haven't in many years. I would also peel carrots and usually Cucumbers, but consider just washing them now. How many wash. Wash and peel or just Peel? I'm also thinking of discarding my "Plastic" cutting boards after reading the latest on the amount of plastic released by cutting carrots on a plastic cutting board. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Chalkie Posted January 18 Report Share Posted January 18 2 hours ago, lappir said: Another not Recipe. I used to peel off the skin of Potato's, but haven't in many years. I would also peel carrots and usually Cucumbers, but consider just washing them now. How many wash. Wash and peel or just Peel? I'm also thinking of discarding my "Plastic" cutting boards after reading the latest on the amount of plastic released by cutting carrots on a plastic cutting board. Rod I peel potatoes if I am going to mash them otherwise skins are fine. I have gotten lazy on carrots and just buy the "baby" carrots. I peel cucumbers because I personally find the peels to have bitter taste. Quote Link to comment Share on other sites More sharing options...
lappir Posted January 18 Author Report Share Posted January 18 4 hours ago, Chalkie said: I peel potatoes if I am going to mash them otherwise skins are fine. I have gotten lazy on carrots and just buy the "baby" carrots. I peel cucumbers because I personally find the peels to have bitter taste. I refrain from buying the "peeled cut carrots", way too much mark up in those things and I find they often taste terrible, but maybe I'm unlucky in picking the right bag. Depending on what I'm doing with the Cucumbers on how much I peel. I don't notice much of a difference in the taste, but I don't buy them often. I haven't made "Mashed" potato's for a long time. I don't actually mind them mashed with the skins and maybe even being a bit "Lumpy". Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
sandsys Posted January 19 Report Share Posted January 19 I don't peel baked potatoes but I rarely eat the skin. I do not like skins in mashed potatoes. True baby carrots taste differently from those that are tumbled to look like baby carrots. I don't peel cucumbers. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
MadeItToFT Posted January 19 Report Share Posted January 19 Don't peel baby boiled potatoes or baby potatoes roasted. Love baked potatoes and hubby eats skin but I don't. Don't care for flavour of mini peeled carrots but love peeled regular carrots cut long and thin tossed in butter and parsley. Another favourite mashed rutabaga aka swede with roast dinners. To each their own. Quote Link to comment Share on other sites More sharing options...
Chalkie Posted January 19 Report Share Posted January 19 11 hours ago, FULLTIMEWANABE said: Another favourite mashed rutabaga aka swede with roast dinners. To each their own. Indeed. I think the taste of a rutabaga is bitter no matter what you do with them, which is odd because I like cabbage and I like turnips (especially as Tatties and Neeps). Maybe it is genetic, just like to some people cilantro tastes like soap which they know is caused by a particular gene. Quote Link to comment Share on other sites More sharing options...
DanZemke Posted January 19 Report Share Posted January 19 (edited) I've never heard of "Tatties and Neeps"! I had to look them up to understand. But I don't like cabbage, so they're probably not for me. I do like cilantro, especially in salsa. No soapy taste for me! However, my pee smells bad, after eating asparagus. And the ability to smell that is genetic. Must be correlated with intellect https://www.medicinenet.com/do_all_peoples_pee_smell_after_eating_asparagus/article.htm Edited January 19 by DanZemke clarity Quote Volvo 770, New Horizons Majestic and an upcoming Smart car Link to comment Share on other sites More sharing options...
folivier Posted January 20 Report Share Posted January 20 Yep I'm the guy who cilantro tastes like soap, and artificial sweeteners taste bitter, and my pee smells after asparagus. Quote Back on the road again in a 2011 Roadtrek 210P 2011 Tahoe 4x4, 2006 Lexus GX470, 2018 Ranger XP1000, 2013 RZR 570LEhttp://finallynewellin.blogspot.com/ Link to comment Share on other sites More sharing options...
DanZemke Posted January 20 Report Share Posted January 20 A good life includes balanced karma. Perhaps your good looks and superior skills provide that balance. :-) Quote Volvo 770, New Horizons Majestic and an upcoming Smart car Link to comment Share on other sites More sharing options...
Chalkie Posted June 26 Report Share Posted June 26 On 1/19/2024 at 4:09 PM, DanZemke said: I've never heard of "Tatties and Neeps"! I had to look them up to understand. Thanks to thread resurrection I saw this. In Scotland, where we lived for a few years, turnips are a versatile root vegetable. They use them for human feed and they also grow them for cattle feed. The ones used for livestock are huge, like 10-14" in diameter. A farmer friend had a machine that was pulled behind a tractor in the field. It had a hopper and a slicer that would slice the turnips into slices about 1/2" thick a hurl them to the side like a big frisbee. They also carved the big ones at halloween instead of pumpkins. I understand pumpkins have become more common as they are far easier to carve. Quote Link to comment Share on other sites More sharing options...
LindaH Posted June 27 Report Share Posted June 27 My husband is on a low-salt diet because of heart failure, so salting a cutting board would be a big NO for us. Just 1/4 tsp of regular table salt has 590 mg of sodium! The sea salt we use has 530 mg of sodium in 1/4 tsp. Either way, that's too much sodium to add in addition to the sodium that's already in most foods...and it would probably take more than 1/4 tsp to salt a cutting board. Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
lappir Posted June 27 Author Report Share Posted June 27 So, part of the reason I use the Salt is to prevent items I'm cutting from sliding around on the board. I'm surprised at how much it helps. What I'm cutting I will also be adding salt to most of the time, so I just adjust the amount to suit me. (My taste buds). What other spice do you use to provide the replacement for "Salt". If it's a coarse grind that's solid it might work. The other reason for using salt is to inhibit most bacteria growth. Most don't like the high sodium as your husband's Doctor it seems. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Chalkie Posted June 28 Report Share Posted June 28 On 6/27/2024 at 8:43 AM, LindaH said: My husband is on a low-salt diet because of heart failure, so salting a cutting board would be a big NO for us. Just 1/4 tsp of regular table salt has 590 mg of sodium! The sea salt we use has 530 mg of sodium in 1/4 tsp. Either way, that's too much sodium to add in addition to the sodium that's already in most foods...and it would probably take more than 1/4 tsp to salt a cutting board. This is why I only use Kosher salt in cooking. It has even less sodium, or at least the Morton brand does. I use as little salt as I can while cooking and if a seasoning has monosodium glutamate in it, no salt at all. If, once on the table, food seems to need a "little more" we use one of the Mrs. Dash mixes. Quote Link to comment Share on other sites More sharing options...
sandsys Posted June 28 Report Share Posted June 28 2 hours ago, Chalkie said: This is why I only use Kosher salt in cooking. It has even less sodium, or at least the Morton brand does. I use as little salt as I can while cooking and if a seasoning has monosodium glutamate in it, no salt at all. If, once on the table, food seems to need a "little more" we use one of the Mrs. Dash mixes. For a few months I was on a very low salt, low fat, reduced calorie diet. I started having dizzy spells; the doctor monitoring the program had to reduce my blood pressure meds because my pressure had dropped so far. It appears, though, that reducing salt intake a lot can cause thyroid problems so keep an eye on that, please. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
