Myth Busters
rickeieio
Octane numbers relate to knock or pre-ignition, that has no bearing on power.    Knock or pre-ignition has several factors, compression is one, chamber shape and mixture are others.     Modern engines with knock sensors can adjust for different grades of fuel.     With lower octane fuel developing lower power in these engines due to ignition timming/mixture changes to allow for the lower grade fuel.    The flame rate or how fast the fuel burns is really the detail behind octane numbers
At high altitude the air is less dense therefore naturally asperated engines don't produce the same pressue they would at sea level.     Lower compression allows for faster combustion hence lower octane fuel.    In aviation the development of piston aero engines can be traced to octane.    The Big American Radial engines, RR and, Allison V12's of WWII were designed to use 115/145 octane fuel.    These engines are suppercharged, they still run on 100LL agas but at much lower power than they are rated at.    The Germans did not have high octane fuel and their engines were either larger displacement or lower powered than the allied forces because of this.
  • Replies 252
Posted Images
On 3/18/2024 at 1:54 PM, noteven said:
Myth: a diesel engine has to roll coal black clouds of smoke to produce sufficient power to move a pickup twuck
False. I actually don't see that much anymore.
