amarie1 Posted April 19, 2023 Report Share Posted April 19, 2023 I’m drycamping for the first time, 4 days in a state park. I don’t know how long my batteries will last without having to run the generator, so I’m trying to be very miserly with what 12v items I use. If I turn on the water pump, does it draw electricity immediately, and all the time? Or only when I use it, that is, when I turn on a faucet or flush the toilet. If it draws all the time, then I should turn it off at night and when I leave for a hike, right? Thanks for any info, AM Quote 2018 Forest River Sunseeker 2290SC 25 feet, Chevy Express 4500 "Angie" (short for Angel) Link to comment Share on other sites More sharing options...
sandsys Posted April 19, 2023 Report Share Posted April 19, 2023 I always left mine on except on the rare occasion I was hooked up to city water. Linda Sand Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Chad Heiser Posted April 19, 2023 Report Share Posted April 19, 2023 The water pump only draws power when it actually runs. There is nothing wrong with leaving it on the whole time. Some people do turn them off when they leave their rig just in case a line breaks or something so the pump doesn’t create a flood while your not around. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Danfreda1 Posted April 19, 2023 Report Share Posted April 19, 2023 We do like chad said, we turn off the water pump whenever we leave during the day. We also only turn on gas water heater in the morning before showers then turn it off to save propane. Quote Link to comment Share on other sites More sharing options...
lenp Posted April 19, 2023 Report Share Posted April 19, 2023 Make sure your pump isn't burping occasionally - a sign there is a slow drip someplace or the check valve in the pump is leaking. If it is burping, it is using some battery power but not a lot. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Will B. Posted April 19, 2023 Report Share Posted April 19, 2023 Ours is either enabled via a digital control panel (annoying), or outside by the water connections and leveling jack controls. I have a perma-sticky-note that says "Turn Off the Water Pump". Lifting the jacks is the last thing we do, and I don't want to forget. All that to say: definitely turn it off while you're in motion! While boondocking, it's fine. If you're going to leave for the day, not a bad idea to turn it off. If a leak were to happen or something go nutso, at least you wouldn't flood your rig or the bays. Quote 2018 Grand Design Momentum 399TH • 2019 Ford F-350 (DRW) 2016 Harley-Davidson Heritage • 2013 Harley Sportster with a sidecar Web: https://MyRVRadio.com • Facebook: https://fb.com/MyRVRadio Link to comment Share on other sites More sharing options...
Kirk W Posted April 19, 2023 Report Share Posted April 19, 2023 (edited) I just leave my pump on all of the time unless we leave for an extended period. Chad gave a good response. As to the water heater, you will save very little propane by turning that off between uses since the water cools down and uses nearly as much propane to heat back up as it would have used if left on. Our first 2 winters of fulltime we were in the same location and the first I left mine on all of the time and the second I only turned it once each day. The second winter my propane lasted 2 days longer than the first on an ASME tank that held 60#.(about 15 gallons) Edited April 19, 2023 by Kirk W Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
sandsys Posted April 19, 2023 Report Share Posted April 19, 2023 5 hours ago, Kirk W said: I just leave my pump on all of the time unless we leave for an extended period. Chad gave a good response. As to the water heater, you will save very little propane by turning that off between uses since the water cools down and uses nearly as much propane to heat back up as it would have used if left on. Our first 2 winters of fulltime we were in the same location and the first I left mine on all of the time and the second I only turned it once each day. The second winter my propane lasted 2 days longer than the first on an ASME tank that held 60#.(about 15 gallons) In my van, I had an electric 2.5 gallon water heater. I could turn on the power for 10 minutes then turn it off and the hot water would be a perfect temperature to shower without adding cold. No wasting water trying to get the mixture right. Not a typical situation but something to think about. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
lappir Posted April 20, 2023 Report Share Posted April 20, 2023 Depending on how much hot water you use. Put a timer on my water heater and set it for 30 minutes. In about 10 minutes I hop in the shower and turn on the dishwasher. If I'm using my water pump the low flow shower head causes the pump to cycle very often. Same with the dish washer when filling. If I'm running both the pump runs constantly to fill the dish washer as I'm showering and washing my hair. Have plenty of hot water for both things and even a bit of warm water in the evening when I get home. My propane now lasts a lot longer than when I just left the heater on all the time. It's the only thing that currently uses propane. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
folivier Posted April 20, 2023 Report Share Posted April 20, 2023 I've always just turned the water pump on when using water. Off all other times. Had a friend who was driving to a great boondock spot and figured he could stay a week or longer. Unknown to him his wife had left the bathroom faucet slightly running. Yep, got to his spot, set up, went to take a shower and the water tank was about empty. And the waste tank was about full. Had to find a place to dump and fill. And lost his spot! Quote Back on the road again in a 2011 Roadtrek 210P 2011 Tahoe 4x4, 2006 Lexus GX470, 2018 Ranger XP1000, 2013 RZR 570LEhttp://finallynewellin.blogspot.com/ Link to comment Share on other sites More sharing options...
